Old 07-26-2020, 09:39 PM #1
cwilliams563's Avatar
cwilliams563 cwilliams563 is offline
cwilliams563 has a spectacular aura about cwilliams563 has a spectacular aura about cwilliams563 has a spectacular aura about
LED load resistors for DRL’s crazy hot
Just put in one LED for the front DRL/Turn signal bulb on passenger side of my 08 SR5 with DRL’s, got a pair for both sides. It is a single action LED (single filiment bulb) which also is the turn signal. This thing is crazy hot, got over 370* in less than 10 minutes. After about 20 minutes we’re over 400*.
Is this normal? Is this ok to use for a DRL to where it’s always on? Or are they only to be used on flashers to where the lights are intermittent?
I don’t want to start a fire or anything. I can’t imagine how hot it’s going to get after being on for a couple hours in the AZ heat. I didn’t see much at all about the heat for these things. Is this kind of heat normal? Are people just mourning them to the metal somewhere and not worrying about it? The wires for the bulbs and the resistor were only like 78* which was the same as everything else, just the resistor was crazy hot. Never heard that part about it researching previously.
My build thread https://www.toyota-4runner.org/4th-g...ml#post3520544
2008 Titanium Metallic 4WD 4Runner V6 SR5| Satoshi Grille mod|17x8 Level 8 MK6 wheels, 275/70/17" Falken Wildpeak tires| Front-Bilstein 5100's set at 0 with ToyTec branded Eibach silver springs and 1/2" ToyTec spacer driver side, 1/4" ToyTec spacer passenger|Front Diff. drop spacer kit|sway bar relocate kit| Rear-Fox 2.0Resi and ToyTec superflex black springs|Tyger Bull bar with LED's/Lund HX tube side steps
2021 Subaru Crosstrek Limited in Crystal White Pearl
cwilliams563 is offline   Reply With QuoteReply With Quote
Old 07-26-2020, 10:03 PM #2
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
i would take it out, swap with led flasher relay, and get the 8 pin to 12 pin harness to use with the led flasher relay, i only saw one person did the harness and relay change, another way is to take apart the flasher relay and grind out the load resistor bar.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
Old 07-27-2020, 11:36 AM #3
That’s initially what I was wanting to do when I was researching solutions to hyper flash. Most information I had read about people’s experience was the problems they had with the flasher replacement and most recommended the resistors instead I’d thought. They said if the blinkers worked the hazards had issues, sometimes them not turning off completely and staying on afterwards. Something like the lights may stay on too or not have the auto function work or turn off after a few minutes. They talked about weird other problems as well, especially with the DRL’s. I was thinking the relay swaps were for NON-DTRL’s, at least what I saw. Other things I read initially too that I’m not recalling right now.
I’ll have to look back in to it again. I’ll check out the grind down portion again as well. I recall seeing that option too initially a couple months ago.
crazy , heat , hot , led , resistor
FS: Peak 7443 Amber LED bulbs, Morimoto LED Load Resistors - $40 - Pittsburgh, PA 97BlackAckCL For Sale: Non-T4R Items 15 01-30-2020 12:21 PM
FS: 4x Morimoto 40w HD load resistors for LED $10 each. - Brea, CA mikeySA For Sale: Non-T4R Items 2 04-16-2019 07:18 PM
Resistors do not fix rapid blink. TOY2G 5th gen T4Rs 14 01-03-2019 08:56 PM
