Old 07-29-2020, 11:53 PM #1
Drak's Avatar
Drak Drak is offline
Real Name: Doug
Drak is on a distinguished road
Drak's Avatar
Real Name: Doug
Anyone Know the Size of the Stock JBL Amp?
Hey Guys.
I'm getting ready to pull the trigger on an entire new sound system for the old '03 'Runner.
New wiring, receiver, front and rear door speakers, amp, and a sub.
The amp I'll be using is the JL Audio RD900/5.
I'm going to build a custom box to hold a 10" side-firing sub as a few others have done before.
I've got most of my bases covered I think.
My question is this:
I (hopefully) want to use the same space/area the stock JBL amp sits...
Right next to the sub...
To put the new amp.
But I don't know the area dimensions and was curious if anyone happened to know.
An odd question, for sure.
Or...what locations, if not where the JBL sits, have others mounted their amps?
I'd like to be reasonably prepared before I start pulling panels and get some nasty surprise.
Oh, an additional weirdo question:
I read somewhere that the 4Runners have a dual antennae plug setup that doesn't like to mate too well to aftermarket receivers.
Any word up/thoughts/ideas on that data?
Thanks for any thoughts/info.
2003 Imperial Jade 4Runner Sport Ed.
Drak is offline   Reply With QuoteReply With Quote
Old 07-30-2020, 11:19 AM #2
ads2539's Avatar
ads2539 ads2539 is offline
Real Name: Howard J. Turkstra
ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough
ads2539's Avatar
My JBL amp is 9”x6”x1 9/16”, not including the mounting brackets. I don’t know the exact dimensions of the area, but there was a little more room where the amp sits.
My aftermarket amps and cd changer are on the floor of my cargo area. I use the rear shelf to hold cargo. The amps and cd changer are under the shelf.
I used an adapter cable so that the two Toyota antennas would merge into my aftermarket head unit’s one jack. I don’t get very good radio reception, but I don’t listen to the radio a lot. I haven’t tried dealing with the reception issue yet.
2004 Limited V8 4WD 183k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
ads2539 is offline   Reply With QuoteReply With Quote
Old 07-30-2020, 06:28 PM #3
Drak's Avatar
Real Name: Doug
Drak's Avatar
Real Name: Doug
Thanks!
Most appreciated.
Old 07-30-2020, 08:33 PM #4
Kryptoroxx's Avatar
Kryptoroxx Kryptoroxx is offline
Real Name: John
Kryptoroxx has a spectacular aura about Kryptoroxx has a spectacular aura about
Kryptoroxx's Avatar
Real Name: John
You're going to want a digital amp for sure. They run a little cooler than the class a or ab hybrids.
Sent from my SM-G986U using Tapatalk
98 Toyota 4runner 3rz 5spd 4x4 - Sold Build Thread
06 4runner 2uz Build Build Thread
Instagram: @Kryptowerkz
Kryptoroxx is offline   Reply With QuoteReply With Quote
Old 07-31-2020, 02:09 PM #5
P_nlsn's Avatar
P_nlsn P_nlsn is offline
Real Name: Parker
P_nlsn has a spectacular aura about P_nlsn has a spectacular aura about
P_nlsn's Avatar
Real Name: Parker
I saw someone already answered the size of the amp, but the area where the amp mounts is roughly 11" wide, 7.5" tall, and 2" deep - maybe give or take a few 1/8ths
I decided to mount my JVC KS-AX3205D amp under the passenger seat
https://www.toyota-4runner.org/3474151-post2.html
I didn't encounter this problem, nor have I personally heard about it, but that's not to say it's not a possibility for other makes/models
4wd V6 '03 Sport w/ 340k miles (175k engine swapped @ 326k) // 3" Suspension Lift + 3" Body Lift on 35" K02's
@toto.runner // Build Thread // Engine Swap Write-Up
P_nlsn is offline   Reply With QuoteReply With Quote
Old 07-31-2020, 02:16 PM #6
riverwolf riverwolf is offline
riverwolf is on a distinguished road
The OEM radio uses a diversity tuning system...fancy way of saying it has 2 antennas and the electronics pick the one with the strongest signal at any given time. You can see the antennas in the two rear side windows. You may be fine connecting just the primary to an aftermarket radio or you may benefit from the ?AC Delco? "Y-adapter" that will let you combine both antennas into one connector (reverse splitter, essentially). One of the antennas has a non-standard connector so you also need an adapter to convert it to a standard interface.
The other radio problem people have is the 4Runner also has a signal amplifier in the antenna chain. If your radio harness doesn't include a turn-on lead for the signal amplifier, you'll get poor to no reception.
Searching the forum should turn up multiple discussions for all of these topics and more. After 17 years, if it can be done to the 4th gen, someone's already done it and has the t-shirt to prove it.
2003-2022: '03 Limited V8 4x4 - Galactic Gray Mica
2022-Present: '21 Nightshade 4x4 - Magnetic Gray Metallic
riverwolf is offline   Reply With QuoteReply With Quote
Old 07-31-2020, 05:59 PM #7
Drak's Avatar
Real Name: Doug
Drak's Avatar
Real Name: Doug
Excellent information and thanks.
I know, right?
That's one reason I love my 4Runner so much.
In between my old Pathfinder Sport and the 4Runner, I had a Rodeo for a bit.
Literally near nothing on that car as far as DIY 'been there done that' information.
With the 4Runner, I don't think I've ever run into something that wasn't documented a hundred dozen times over.
Interesting about the antennae signal amplifier, that answers a question I had read about somewhere else.
That after putting a new receiver in, their signal was crap no matter what they tried to do, splitting, y-cables, they still had terrible reception.
The whole shooting match arrives Monday from Crutchfield.
Receiver, amp, front and rear speakers, and 10" sub.
Old 07-31-2020, 06:06 PM #8
Drak's Avatar
Real Name: Doug
Drak's Avatar
Real Name: Doug
I did figure that much out (Class D amp)
I downsized the amp from my original choice based on size alone.
I really, really want it to fit in the same location.
I think the one I chose should work OK there.
In case anyone's interested:
Receiver: Sony XAV-AX1000
Amp: Soundstream Picasso Nano PN5.64OD
Speakers: JL Audio C2650 (6.5" component w/ separate crossovers)
Sub: JL Audio 10W3V3-2
I'm building my own custom side-fire box for the sub, much like I've seen demonstrated here.
Because you guys have done it all already!
I don't know who did this, but I got this pic from right here on the forum.
Should look familiar to someone...
Old 08-01-2020, 10:44 PM #9
cwilliams563's Avatar
cwilliams563 cwilliams563 is offline
cwilliams563 has a spectacular aura about cwilliams563 has a spectacular aura about cwilliams563 has a spectacular aura about
For the Diversity antenna as has been said already has the 2 antennas imbedded in each rear window, they look like defrosters and that’s what I thought they were initially.
There are 2 connectors for the antennas, 1 large and 1 small. The large is just the regular size that will fit into your radio. Most people just use the large only. The most important thing is to make sure you have power to the powered radio antenna. It is the plug in my 1st pic with the white foam around it.
I ran mine for a while with just the std. one connected and got decent reception. I ordered a Y splitter all in 1. All posts I’d seen have 2 parts, a y splitter with 2 large female ends then a large to small female adapter. I found an all inclusive one. I installed the splitter and used both antennas and don’t see a difference over just the large one only. Doesn’t matter much as I’ve installed my XM antenna since and only listen to XM any more. Sorry the pics are so dark and crummy.
My build thread https://www.toyota-4runner.org/4th-g...ml#post3520544
2008 Titanium Metallic 4WD 4Runner V6 SR5| Satoshi Grille mod|17x8 Level 8 MK6 wheels, 275/70/17" Falken Wildpeak tires| Front-Bilstein 5100's set at 0 with ToyTec branded Eibach silver springs and 1/2" ToyTec spacer driver side, 1/4" ToyTec spacer passenger|Front Diff. drop spacer kit|sway bar relocate kit| Rear-Fox 2.0Resi and ToyTec superflex black springs|Tyger Bull bar with LED's/Lund HX tube side steps
2021 Subaru Crosstrek Limited in Crystal White Pearl
cwilliams563 is offline   Reply With QuoteReply With Quote
amp , jbl , question , sits , stock
BF Goodrich KM3 in stock stock size.. tls3601 5th gen T4Rs 10 07-17-2020 02:07 PM
Caster question for stock supension and stock size tires... FrontRange4Runner 5th gen T4Rs 5 03-27-2014 02:53 PM
Tire Rub, Stock size and stock rim screeves 5th gen T4Rs 2 12-10-2013 02:38 AM
BFG T/A KOs in stock size; do they rub? 36bound 5th gen T4Rs 3 05-13-2012 11:08 AM
Stock Rim Size 95 vs 96+ djrazr 4th Gen T4Rs 1 03-03-2008 05:01 PM
