Old 07-30-2020, 08:49 PM #1
Steve Theodore Steve Theodore is offline
Steve Theodore is on a distinguished road
Weight reduction and 4th generation 4Runners
Although I already know for a FACT that this will not be a popular topic here whatsoever, please excuse my intrusion as I drop just a few tidbits of information here. I made these posts somewhat accidentally on the 5th generation sub-forum as they have a thread about it, and I could not easily find a corresponding thread here in the 4th generation section, so I'll start one.
With my 2008 4Runner getting older, I feel like it could get a bit more pep in it's step. Mine has over 170k and I'm the original owner (4.0L V6), but it just doesn't pull highway grades the way it used to and feels a bit tired overall. A little targeted weight reduction could possibly go a long way, but I fully appreciate that most people with these great trucks just don't think that way at all.
I do happen to think that way, but I haven't really devoted much time/effort to my 4Runner over the years to work on these ideas. Here are a few tricks that I have thought of, which may or may not be helpful to others in a similar frame of mind.
Remove OEM roof rack (if it suits your use case)
Remove OEM running boards (if it suits your use case)
Remove OEM tow hitch (if it suits your use case)
Lightweight battery (warning...this can be expensive)
Aftermarket wheels/tires (stock must be reasonably heavy, but this will likely be $$$ too)
Aftermarket lug nuts for wheels
I'm less clear what the stock equivalent parts weigh on this vehicle though, so it's much harder to just declare victory on anything without knowing what it weighs. Even though I'm a weight weenie when it comes to performance, I'll also be the first to tell you that some things are just not worth it.
One thing I've personally noticed is that I've fed my 4Runner 87 octane (always top tier) fuel for nearly it's entire life. It seemed to do fine on this grade of fuel, and some early experiments I ran many years ago seemed to demonstrate no noticeable differences when run on 92. However, just this year I tried again and I feel that even running 89 is helping the vehicle perform much better. This is only based on my own butt dyno and not quantifiable verified, but my butt dyno has 170k of miles of experience and it seems to be a lot happier on 89 octane now. Your mileage may vary (figuratively and literally), but that may be a way to unlock a bit more performance if your vehicle is getting older like mine.
Spare a little humor for a guy like me!
Steve Theodore
2008 Toyota 4Runner Sport Edition V6 4x4
ex-2000 Toyota 4Runner SR-5 V6 4x4 5 speed (R.I.P. old girl)
2012 Lexus IS-F
2001 Lexus IS300 slicktop
Steve Theodore is offline   Reply With QuoteReply With Quote
Old 07-30-2020, 08:51 PM #2
As a very small update to this thread I can now tell you guys that the OEM cross bars for the OEM Sport Edition roof rack weigh 5.5 pounds on my digital scale. Considering I haven't used them even one time in my 12 years of ownership, it wasn't a hard decision to pull them off.
If you need a tutorial video to help, I found this one here:
2006 Toyota 4Runner Sport Edition 4WD - Factory Crossbar Removal - YouTube
Steve Theodore
2012 Lexus IS-F
Old 07-30-2020, 09:04 PM #3
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
Without having already added weight like bumpers, skids, winch, its hard to lose weight.
From bone stock, in addition to what you have listed:
Higher-end racing seats
Remove sunroof
Replace glass with lexan
Titanium exhaust and muffler
Doug Thorley long tube headers remove cats which are fairly heavy though the headers are heavier
Remove spare tire/ spare tire cable winch, and crossmember
Rear seats weigh 84 lbs if I remember correctly from another thread
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 07-30-2020, 10:07 PM #4
Remove sunroof
Thanks for humoring me and adding a few contributions bud, I know it's not a hot topic on these boards...but still fun for me to approach the concept with all of my vehicles. I appreciate it!
Steve Theodore
2012 Lexus IS-F
Old 07-30-2020, 11:24 PM #5
m85476585 m85476585 is offline
Real Name: Matt
m85476585 will become famous soon enough
Real Name: Matt
Just the other day I noticed the rear seats are incredibly heavy. Mine are leather, so probably even heavier. The cloth seats in my Prius are nearly weightless in comparison.
I can't remember if the V6 has an exhaust resonator, but that's a good chunk of metal that's not important.
If you have 4WD and can trade for a 2WD that saves several hundred pounds. Look for manual cloth seats and no sunroof. Or do a manual transmission swap from an FJ.
You could take out any unneeded accessories like the rear cargo deck (if equipped).
If you're in a frigid place you could take out the AC system, but I wouldn't do it otherwise. (And make sure to properly recover the refrigerant if you do).
Some people remove one or more sway bars with no ill effects.
I'm not sure how much different tires vary in weight, but it's worth checking. Obviously load range E or anything like that will be heavy, but I wonder if there's anything much lighter than average highway tires. For what it's worth I've been running stock size highway tires (Michelin LTX MS2) for the last 6 years, and I've gotten everywhere I want to go, on road or off road.
I think there were two battery sizes from the factory. The smaller one is probably fine for most people.
2007 V8 Limited 4WD
m85476585 is offline   Reply With QuoteReply With Quote
Old 07-31-2020, 09:04 AM #6
JuniorPigeon's Avatar
JuniorPigeon JuniorPigeon is offline
Real Name: Aaron
JuniorPigeon has a spectacular aura about JuniorPigeon has a spectacular aura about
Real Name: Aaron
I'll bite! Weight reduction is actually hugely important to me. Especially being at the point I'm at with bumpers, winch, rack, drawers, fridge, dual batteries etc. That was my reason for going with a low pro front bumper, custom rear bumper, and smaller winch with synthetic line. I've gone with F55 aluminum fairlead and Flatlink, as well as a kinetic recovery rope and soft shackles with 2 traditional shackles in an effort to reduce recovery gear weight. I'm sure it's not much but I use a couple of Rotopaxes instead of metal jerry cans and their accompanying mount. The PO had removed the rear seats when building the bed platform and went with aluminum skids.
I'm going from a 295/70 STT Pro on 17x9 XD 301s to a 315/70 Wrangler Duratrac on 17x9 SCS F5s and should drop 10 lbs rotating mass per wheel which I'm hoping will make up for the increase in tire size.
I'm still always looking for ways to cut down more weight. My solar panel covers my sun roof so I'm considering ditching that whole assembly and sealing it up, but I'm not sure that would warrant the effort. All in all though every little bit helps.
2007 4Runner Limited V8
| 2.5 Fox 3" lift w/ remotes & DSC | Dobinson 677V rear | SPC UCAs | 1" BL | SCS F5 | 315/70 DuraTracs | Prinsu full rack | RLC rear bumper/swingout | C4 front bumper | Warn VR8-S | F55 fairlead/Flatlink-E | Rocksteady skids | ARB 2500 awning | Dometic CFX 40W | Partner Steel 22" stove | Adventure Index drawer/sleeping platform | ARB twin compressor | Odyssey 34R dual batteries | Blue Sea SI ACR/fuse panel/USB | Renogy 100W Eclipse | Baja Designs Squadron R & S2 | G5R retrofits | Doug Thorley headers/Y pipe | weBoost OTR |
JuniorPigeon is offline   Reply With QuoteReply With Quote
Old 07-31-2020, 10:22 AM #7
Thanks for a little bit of love on the topic guys...definitely makes me smile!
My factory exhaust actually broke after the center resonator (mid-pipe) and although I have purchased a replacement rear I haven't had it fixed just yet. The lack of the rear muffler portion has never really been that much louder than stock, and it is a fairly significant amount of weight temporarily lost.
Let's just say I'm in no hurry to complete the repair at this point, and I'm not being pressured to do it. Haha!
Steve Theodore
2012 Lexus IS-F
Old 07-31-2020, 01:13 PM #8
randy88fj62's Avatar
randy88fj62 randy88fj62 is offline
randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about
For weight reduction and acceleration performance I'd go with C rated tires as they are lighter than D or E.
Get an injector cleaning service done to make sure you're motor is performing well.
randy88fj62 is offline   Reply With QuoteReply With Quote
Old 07-31-2020, 02:03 PM #9
SherpaEquipmentCo's Avatar
SherpaEquipmentCo SherpaEquipmentCo is offline
official vendor
SherpaEquipmentCo is a splendid one to behold SherpaEquipmentCo is a splendid one to behold SherpaEquipmentCo is a splendid one to behold SherpaEquipmentCo is a splendid one to behold SherpaEquipmentCo is a splendid one to behold SherpaEquipmentCo is a splendid one to behold SherpaEquipmentCo is a splendid one to behold
official vendor
This is how we did 4th gen weight reduction. Then we added a few hundred pounds of steel inside it.
Industry Leading Modular Storage Systems that allow you to Adventure with Confidence.
Our WebsiteOur InstagramOur Facebook
SherpaEquipmentCo is offline   Reply With QuoteReply With Quote
Old 07-31-2020, 05:05 PM #10
Sherpa,
Do you have a build thread for that truck?
Old 07-31-2020, 06:54 PM #11
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
If you are not an off roader like me remove your factory skids and just replace the fuel tank one with an RCI, or other. Check out a new set of wheels and pay attention their weight, don't go with oversize tires, stock 265/65R17 are more than adequate. Install the 3 degree retard cam gears for a little more zip.
And do some of the other suggestions if so inclined.
Old 07-31-2020, 11:35 PM #12
Thank you for the excellent reply!
Steve Theodore
2012 Lexus IS-F
Old 08-01-2020, 02:23 AM #13
Ed_C's Avatar
Ed_C Ed_C is offline
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
Saw the topic, the username, and the signature...of course it had to be the same Steve Theodore from Supraforums
How about compensating for the weight with a 2JZ swap...I'm sure you know a little bit about them
Old 08-01-2020, 03:11 AM #14
duffdog duffdog is offline
duffdog is a jewel in the rough duffdog is a jewel in the rough duffdog is a jewel in the rough
Removing all the airbags would net you around 40lbs of weight decrease. You would not believe how much the side curtain airbag barrels and brackets weigh.
If you are trying to get less parasitic drag on the engine so that you pull hills easier I would look into a custom undersized crank pulley to underdrive the accessories.
2005 Blue SR5 v8
3" suspension lift, 1" body lift, 315's, rear Elocker, on-board air system, slider air tanks, full skid plates, front Demello bumper, rear HMF plate/tube bumper, rear 9000lb hidden winch, front 10000lb winch, dual electric fans (in cab adjustable temp), rock lights, 25W LED projector lights.
duffdog is offline   Reply With QuoteReply With Quote
Old 08-01-2020, 11:07 AM #15
Guilty as charged, and thanks for spotting me considerably away from my natural habitat. Trust me if it wasn't for the complexity of retaining 4WD, which is of course a huge requirement of my 4Runner for wintertime driving, that would be on my wish list!
My wife would NOT be OK with airbag removal as this is the family truckster, but the underdrive pulley is a pretty great idea!
Steve Theodore
2012 Lexus IS-F
4runner , bit , case , oem , suits
Weight Reduction Cadesun 5th gen T4Rs 45 06-01-2021 09:58 PM
Things I like about 3rd Generation 4Runners SURF RUNNER 3rd gen T4Rs 30 01-09-2015 09:18 PM
My Favorite 5th Generation 4Runners 1engineer 5th gen T4Rs 29 09-14-2014 11:43 AM
Anyone tried this new bikini top for 1st generation 4runners? tamarindo2 Classic T4Rs 5 11-18-2008 08:04 PM
re-call on some 1st, 2nd and 3rd Generation 4Runners peter78 4th Gen T4Rs 0 09-07-2005 09:08 PM
