Old 07-30-2020, 09:29 PM #1
montijo505's Avatar
montijo505's Avatar
4th gen LBJ part #
Does anyone by chance have the actual part number? Basically I'm trying to see if amayama.com can sell them from across the pond, but they couldn't locate my VIN in their parts catalog apparently. I've looked all day to no avail, called some local dealerships and the kids on the phome had no idea what I was talking about.
If you guys want someone to direct the pitch forks at, it's @y=mx+b for setting me on this wild goose chase.
Old 07-30-2020, 09:47 PM #2
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
In b4 pitch forks lol
I can call McGeorge and see, they know me now because I just had to buy 4 diff seals lol
Referencing this post here: Whiteline Lower Control Arm Bushing Tutorial (120+ Pictures)
Heres the quote to reduce clicking and redirecting
Originally Posted by y=mx+b View Post
OEM LBJ Loop-Hole
So, I was browsing around TacomaWorld for fun and stumbled into a Whiteline Bushing thread. There was a guy that was able to get OEM LBJs imported from Japan or UAE through a 3rd party exporter. I don't know if the Tacoma and 4runner LBJs are interchangable, seems they have different part numbers at the auto parts stores. Regardless, the same method could probably be used to get OEM 4runner LBJs. Just thought I would want to pass this along to anyone interested in this option.
The post is #29 in this thread: Aftermarket lower control arms - which one is better?
y=mx+b is offline   Reply With QuoteReply With Quote
Old 07-31-2020, 02:27 PM #3
montijo505's Avatar
montijo505's Avatar
Anyone? I got an email back saying because my VIN isn't in their system, they are unable to search the catalog for that part.
Is someone else willing to try submitting an inquiry with their VIN and see if they have success? Website is amayama.com
Sent from my SM-G986U using Tapatalk
Old 07-31-2020, 03:13 PM #4
djpope09 djpope09 is offline
djpope09 will become famous soon enough
I made an account and submitted an inquiry with my VIN number. I'll let you know if I get a response.
djpope09 is offline   Reply With QuoteReply With Quote
Old 07-31-2020, 06:03 PM #5
montijo505's Avatar
montijo505's Avatar
Thanks!
Old 08-01-2020, 04:59 PM #6
y=mx+b's Avatar
y=mx+b's Avatar
I called McGeorge Toyota Parts to ask about lower ball joint PNs, hoping they could get the PN even though we can't get them in the US. No luck, they said only available as whole LCA.
I have a sacraficial VIN that came with a junkyard part I got, so I'll check amayama.com
Old 08-18-2020, 08:49 PM #7
This is the response I got from amayama. This does not seem helpful unless I'm reading it wrong. The link just takes you to the part diagram, but there is not part number for the LBJ.
Inquiry #11016082
9017116050---NUT, CASTLE (FOR FRONT LOWER BALL JOINT RH)
9017116050---NUT, CASTLE (FOR FRONT LOWER BALL JOINT LH)
FRONT AXLE ARM & STEERING KNUCKLE | 4RUNNER GRN215L-GKPGKA GRN21#,UZN21# | JTEBU14R248026114 | Toyota | Genuine Parts Catalogs | PartSouq Auto Parts Around the World
Thank you
Old 08-18-2020, 09:05 PM #8
montijo505's Avatar
montijo505's Avatar
Yeah that's just the castle nut lol.
Old 08-18-2020, 10:51 PM #9
CJFONNER CJFONNER is offline
CJFONNER is on a distinguished road
Sankei 555 makes the oem lower ball joints for our vehicles. Napa sells them, and they can normally be found new on eBay as well. Sorry I don’t have part numbers, but they were fairly easy to search and find.
CJFONNER is offline   Reply With QuoteReply With Quote
Old 08-19-2020, 09:41 AM #10
JONBOY345 JONBOY345 is offline
JONBOY345 has a spectacular aura about JONBOY345 has a spectacular aura about JONBOY345 has a spectacular aura about
It's PN SB3842
Link to NAPA: https://www.napaonline.com/en/p/ATMSB3842
Not sure if they're selling the Senkei parts under a different name or not, but from what I was able to determine, it should be the same as the Senkei parts.
Here's a link to the Senkei Part on Parts Souq: SB3842 555 BALL JOINT, Price: 17.97$, Weight: 0.712kg - PartSouq Auto Parts Around the World
Disclaimer: This is from some google-fu-ing... I have no personal experience with these parts, but seems like the right PN from verifying several different parts sites.
'09 V8 Limited | Dobinsons Lift | Front: 3" - C59-302 + GS59-220 | Rear: 2.5" - C59-675V + GS59-701 | Tires | Ridge Grappler 275/65/18XL | Wheels | Method Standard Machined Finish 18x9 -12 offset | SPC UCAs | DT Long Tubes | GSport 2.5" Cats | DT Y-Pipe | Magnaflow Cat Back | 2.5" Vibrant Ultra Quiet Resonator
JONBOY345 is offline   Reply With QuoteReply With Quote
Old 08-19-2020, 09:49 PM #11
This is the one you want. Make sure it specifically says “Sankei 555 Brand” in the Important Info field. There are other parts manufacturers that use the 555 castings, but are inferior parts. Sankei 555 is the highest quality and the machining and finish on all their parts is incredible. They are top notch parts.
avail , called , day , local , part
Toyota Online Part Diagrams and Part Numbers - Now Available to Public gamefreakgc 3rd gen T4Rs 17 01-14-2024 08:56 PM
Part number and source for fender flare part Kyngfish 3rd gen T4Rs 12 12-29-2023 05:25 PM
How can i find the part name/ catalog number for a specific part 9405t4r 5th gen T4Rs 2 07-13-2019 08:53 AM
Can't find a part number on a bolt, dealer part guy was an idiot yota-runner 3rd gen T4Rs 8 02-02-2016 08:00 AM
1998 4Runner Shifter Bushing and Seat Part (Canada). Can I use 2nd Gen Part? nobb 3rd gen T4Rs 6 02-03-2013 11:11 PM
