Old 08-14-2020, 05:08 AM #16
46runner's Avatar
46runner 46runner is offline
46runner has a spectacular aura about 46runner has a spectacular aura about
46runner's Avatar
Congrats on finding a good frame! As for plugs I ended up changing the boots too since they were cracked. I have a write-up with pics. The link is in my signature.
Sent from my Pixel 2 XL using Tapatalk
46runner is offline   Reply With QuoteReply With Quote
Old 08-14-2020, 05:11 AM #17
46runner's Avatar
46runner's Avatar
DIY: Spark plugs and ignition coils - Toyota 4Runner Forum - Largest 4Runner Forum
Old 08-25-2020, 06:55 PM #18
Sean7 Sean7 is offline
Sean7 is on a distinguished road
Originally Posted by Drak View Post
What a great find!
Awesome catch, I'm sure you'll love it.
Thank you I do, been putting a lot of miles on it recently
Originally Posted by jewski_brewski View Post
Nice find! I'm your neighbor to the north and was also struggling to find a rust-free 4th Gen near me. I ended up finding a clean 2005 SR5 V8 in Missouri with only 109,000 miles. I've done a lot of work to mine in the month that I've owned it: changed the timing belt (Aisin kit purchased from Rock Auto), coolant flush, installed NGK iridium spark plugs, new PCV valve, replaced the cabin air filter, new tires, replaced a roof rack end cap that was causing a leak, replaced light bulbs, put in WeatherTech floor mats, and just changed engine oil for the first time tonight. I went with Napa full synthetic 5W-30 (since it was on sale and is re-branded Valvoline) and a Toyota OEM filter. Tomorrow I'll be swapping rear brake rotors and changing differential fluid.
That seems pretty high to me... as previously mentioned, undercoating means nothing if they don't spray the inside of the frame. From the pictures, yours looks almost completely rust free. In that case, it might be worth it for you to have the undercarriage sprayed and sealed. In my case, my undercarriage has some minor rust so getting a professional undercoating would most likely just conceal any problem areas. After doing a lot of research, I think I'm going to use a product called Fluid Film on my undercarriage. It's a seasonal application that will protect your undercarriage from midwestern road salt, and runs about $10 a can.
Thank you and glad you were able to find yourself a clean 4Runner too! You've done so much work too it already, I have majority of the things you mentioned on my to do list as well. I've been reading more and more about fluid film as well and it seems to be a good option. I have to figure out the best way to apply it and clean up the surface rust a bit before hand.
Originally Posted by little_titan View Post
Hard to say if $675 is worth it. Youre gonna have to do some more research or talk to old timers who can look under your t4r and make recommendations.
Hopefully, they have their own car they did it to 5-10years ago and dont mind showing you what it looks like now... that might be the convincing I would need.
Im going try fluid film, just a path that will hopefully work for me. Just need to find a guy in chicagoland area with a shop and air compressor that can do a good fluid film job on my t4r.
I agree with you and thanks for your input. Please let me know if you manage to find someone. I'm currently looking as well and waiting on a few more quotes. If not, I'll have to do it myself somehow.
Appreciate it and thank you for the link!
Sean7 is offline   Reply With QuoteReply With Quote
Old 08-25-2020, 08:08 PM #19
Today I finished installing a new Android based head unit (Atoto S8 Ultra) and a new sub since the original JBL sub was blown. I decided to go with the MB Quart DS1-204 sub and so far it's working great.
Here are the wiring harnesses and parts I used in case someone else is looking into using this radio (for JBL system):
- Metra 95-8210 Double DIN Installation Kit
- Metra TYTO-01 JBL Amplifier Interface Harness
- Metra Axxess ASWC-1 Universal Steering Wheel Control Interface
- Metra 70-8114 Steering Wheel Control Wire Harness with RCA
To get the steering wheel buttons to work right with the S8 model, make sure to set the wiring harness radio input setting to 22. This took me a while to figure out as the Axxess manual only mentions the settings going up to 18 only. I had to call their tech support to find out that it actually goes up to 23 now.
Ruby - 2006 V8 Sport-20200805_165015-jpg  Ruby - 2006 V8 Sport-20200817_144328-1-jpg  Ruby - 2006 V8 Sport-20200821_141214-jpg
Old 08-25-2020, 08:17 PM #20
Also does anybody know what these pieces are for? I found them underneath the carpet when installing the sub. Should I be concerned?
Are they spacers for the suspension?
Ruby - 2006 V8 Sport-20200820_175442-jpg  Ruby - 2006 V8 Sport-20200820_175448-1-jpg
Old 08-26-2020, 12:38 AM #21
little_titan little_titan is offline
little_titan is on a distinguished road
Look like random washers? Def not suspension spacers...
Will see, i may end up doing the fluid film myself too.
little_titan is offline   Reply With QuoteReply With Quote
Old 09-10-2020, 02:16 PM #22
Today I changed the oil with Pennzoil Platinum high mileage 5w-30 and the oem filter at 169,974 miles. I'm debating whether I should replace every 5K miles or go higher.
Does anyone know if a 2003 V8 airbox will fit the 2006 V8 models? My airbox front clips are broken off and the previous owner just drilled a screw into the box to close it. I've found one in decent condition and was going to buy it, however, the seller mentioned that the 2003 airbox does not fit the 2006. How true is that? I figured I will get the box replaced once I tackle the spark plugs.
Old 09-16-2020, 06:54 AM #23
SkolVikes SkolVikes is offline
SkolVikes is on a distinguished road
Nice !!!
SkolVikes is offline   Reply With QuoteReply With Quote
4runner , found , lot , ruby , wife
Ruby Tuesday - rad4runner's Mods and Restoration RAD4Runner Classic T4Rs 309 03-06-2022 08:22 PM
FS: 4th Gen OEM Sport Roof Rack off a 2006 Sport Edition - NY tri-state $50 picked up dmf For Sale: T4R Items 6 09-23-2016 11:29 AM
Hawkmanjr's Maintenance/Build Thread 'Ruby' hawkmanjr 3rd gen T4Rs 7 06-01-2016 12:00 AM
Will 2006 17" SR5 wheels fit 2006 Sport? brighton Engines / Suspension / Wheels / Tires / Audio / Accessories 4 12-01-2011 10:10 PM
