08-02-2020, 07:36 AM
Real Name: Seth
Real Name: Seth
Updated Speedometer Correction?
Hey folks,
I am aware of the 3-wire Speedohealer method of correcting the speedometer when stepping up in tire size... but 1. I don't want to spend $109 and 2. Something just doesn't feel right about making something meant for something else work for this application.
Does anyone know of any updated solutions/ devices?
2006 Shadow Mica SR5 v6 1" BL, Fox Racing UCA's, RC 3" N3 Lift, Rock Trix RT110 -12 Wheels, 315/70R17 Goodyear Territory MT, Tacoma Front Bumper, 5th Gen 4R Tire Carrier, Big Lion LED's
08-02-2020, 08:01 AM
Real Name: Seth
Real Name: Seth
08-02-2020, 11:29 AM
Originally Posted by MrSeth
This is a neat product, I'd definitely be interested in the update. I'm still on stock everything, but eventually I'd like to get bigger tires and don't like the idea of an incorrect speedo. I wonder if it corrects the ODO too?
08-02-2020, 07:48 PM
I love mine, I was able to match the speed perfectly using a sensitive GPS app on my phone for verification.
08-02-2020, 10:19 PM
Real Name: Seth
Real Name: Seth
From what I understand, by fixing the speedo, you also fix the ODO and MPG calculation.
I am excited to see what we can do with this thing and I'll do a reset on the trip ODO and MPG thing to see what changes I get!!!
08-02-2020, 10:52 PM
Good stuff! I’ve been wanting to correct mine for a while, primarily for the odo to correct the mileage. I’ll have to look into these. Let us know how it does for you.
My build thread https://www.toyota-4runner.org/4th-g...ml#post3520544
2008 Titanium Metallic 4WD 4Runner V6 SR5| Satoshi Grille mod|17x8 Level 8 MK6 wheels, 275/70/17" Falken Wildpeak tires| Front-Bilstein 5100's set at 0 with ToyTec branded Eibach silver springs and 1/2" ToyTec spacer driver side, 1/4" ToyTec spacer passenger|Front Diff. drop spacer kit|sway bar relocate kit| Rear-Fox 2.0Resi and ToyTec superflex black springs|Tyger Bull bar with LED's/Lund HX tube side steps
2021 Subaru Crosstrek Limited in Crystal White Pearl
08-03-2020, 02:33 PM
My Kenwood Excelon DMX706S receiver reads the MPH/RPM etc. from the ECU, it corrected that as well! Also, my read out of AVG. MPH is correct now too.
08-03-2020, 08:03 PM
Fixing the speedo will fix the ODO, but not the MPG calculation.
I went with the original speedohealer when I first went up in tire size about 6 years ago. I’ve tested it against a gps and the speed and odometer is spot on. The MPG on the dash is consistent, but not accurate. It’s about 2-2.5 MPG’s every tank.
2005 SR5 V6
URD headers and MAF Cal
AFE Intake
Dobinson, JBA UCA’s, 255/75R17 KO2’s, Level 8 MK6 wheels
08-17-2020, 12:46 AM
Real Name: Seth
Real Name: Seth
So the install took maybe 30 minutes (I used proper joints and heat shrink) and the results are in- ITS PERFECT!!
It is spot on now, for whatever reason my fuel tank capacity (mileage wise) went from being at 275mi until empty to 315mi until empty.
The other thing I like about the unit is that if I go to 37's, I just push some buttons and voila. Same with going back down to 33's.
I finally scratched that itch I couldn't before, and it's great!
10/10 would recommend.
08-17-2020, 04:42 AM
That’s good news! Glad to hear it. I hoed to find a good deal too, but nothing unfortunately that I found. I’ll have to get one. Thanks for reporting back.
08-17-2020, 05:29 AM
you should do a quick write up on how to install it.
08-17-2020, 08:03 AM
Real Name: Seth
Real Name: Seth
Luckily,
@ BlackWorksInc
already did a nice write-up that I followed to do my install!!!
SpeedoHealer v4 in 4th Gen
08-28-2020, 10:00 PM
Real Name: Seth
Real Name: Seth
Update!
Ive driven on the setup for quite awhile now and I love it. My MPG in the city is 14.3 on 35's (it used to show 11.5 to 11.7) and 17 hwy (used to show 13.4)!! A full fuel tank used to show 244mi until empty, but now consistently fills to 330-334
I am also pleased to utilize the Maintenance light feature for accurate oil change intervals again too.
All-in-all, this was more than worth the money to me.
09-03-2020, 07:22 PM
Update!
Glad to hear!
Just to confirm this was the 3 wire Speedo healer universal kit right?
Whytey's 07 V8 Build Thread
2007 Toyota 4Runner Sport Edition V8, Elka 2.5 Suspension, Total Chaos UCA w/ Delta Uniball, Dobinsins C59-677V Rear Coils, Timbren Bumpstops, Prinsu Design Roof Rack, Baja Designs Squadron Sport Fogs, 285/70R17 BFG KO2, Blacked Out TE Rims, Spidertrax 1.25" Wheel Spacers, Satoshi Grill
09-04-2020, 11:05 AM
This was one of those mods that after install, I was kicking myself for not doing it sooner.
Right up there with replacing squeaky blower motor, scratched gauge cluster lens, or squeaky brake pads.
