Old 08-02-2020, 06:05 PM #1
hankd's Avatar
hankd hankd is offline
Real Name: Harry
hankd is on a distinguished road
hankd's Avatar
Real Name: Harry
2005 v8 getting warm on the mountain
hi folks
this might be an obvious one, but i couldn't find a definitive answer from the other threads i found.
i spend a lot of my summer in the cape breton highlands area of canada, routinely driving up several 1200ft mountains on both paved and gravel roads. it is really really awesome bombing around up here, however the vehicle will consistently reach temps approaching the red line as i get to the top of the mountains. by the time i get to the top of i can coast and the temp goes right back down in about 1-2 minutes. ambient temps have been 80-85. just me in the vehicle, usually with about 200lbs of gear (suitcases, camera equipment, normal stuff). a/c off. i am wondering if this is normal, or if others climb mountains and have the gauge dead center, maybe even with their a/c engaged? i think something else might be amiss because the ac gets really weak when i'm idling even tho i have a brand new ac compressor. so maybe an air flow issue?
i have recently replaced the radiator fan clutch, thermostat and water pump as part of larger maintenance including the timing belt and some other stuff. new pink antifreeze too. mods to the vehicle are 3" lift and rock sliders. tires are p rated 265/70/17.
two things i haven't replaced are the ac condenser and radiator. i was doing a lot of offroading/mudding last year in which i fried my ecu and did a number on most of the pullies/bearings in front of engine. replaced all that stuff and lesson learned. i got a ton of mud in the truck during that time had to wash a lot of mud out of the ac condenser and rad. i am wondering if both those should be replaced (i think they are both original to the vehicle). the fins look mostly ok (some are bent). i was wondering if mud is caked between the condenser and rad. any easy ways to diagnose my radiator or ac condenser before i replace them? is this normal? i feel the truck would overheat if i had a few passengers or i was towing (i don't do either).
any info would be appreciated. i'll keep the thread updated as i move through different approaches to the problem.
thanks!
hankd is offline   Reply With QuoteReply With Quote
Old 08-02-2020, 06:26 PM #2
RedSled's Avatar
RedSled RedSled is offline
RedSled has a spectacular aura about RedSled has a spectacular aura about
RedSled's Avatar
The cost of a new radiator is relatively cheap, i would replace it. Sounds like you just about covered everything else.
2017 Silver SR5 Premium
Vietnam 67-68
Greed and corruption are rampant.
RedSled is offline   Reply With QuoteReply With Quote
Old 08-02-2020, 07:56 PM #3
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Use a bright flashlight at night and see how much light shines through the radiator and AC condenser, it should show a good bit of light coming through when using the light.
2004 Limited V8
Old 08-02-2020, 08:10 PM #4
importman importman is offline
Real Name: Danny
importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough
Real Name: Danny
I would say almost certainly that you need a radiator. I suspect your coolant flow is restricted. New radiator, flush the rest of the system and I bet your problem will be gone.
importman is offline   Reply With QuoteReply With Quote
Old 08-03-2020, 01:48 PM #5
Keros Keros is offline
Keros has a spectacular aura about Keros has a spectacular aura about
I've flogged my truck up mountain passes at 100km/hr with trailers in the dead heat of summer and I've never seen the coolant temp gauge move.
Something is wrong for sure.
importman hit it square: new rad, flush the system until you get clean water out, then new coolant.
There's a prestone rad flush product I've always used whenever I get a new-to-me vehicle. You put it in and drive around for a while and then rinse it out. If the water coming out during flushing is hideous, I use tap water for a while to try to get it clean. Then switch to distilled water at some point. I end up filling up every container I can find with coolant/water/gunk and taking it to recycling.
It's an ugly, time consuming process, but worth it in the end.
Keros is offline   Reply With QuoteReply With Quote
Old 08-03-2020, 01:59 PM #6
JLTD JLTD is offline
JLTD has a spectacular aura about JLTD has a spectacular aura about JLTD has a spectacular aura about
Yup, radiator time. After 15 years you probably have enough scaling built up inside to reduce cooling enough to cause the issue. Seen it in a lot of vehicles - cools fine all winter but come summer it starts to overheat.
As long as your AC blows cold, no need to replace the condenser; or, at the very least do the radiator first then check AC output.
Between outfits.
JLTD is offline   Reply With QuoteReply With Quote
Old 08-03-2020, 03:55 PM #7
randy88fj62's Avatar
randy88fj62 randy88fj62 is offline
randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about
If you're running bigger tires (which it looks like you're running 32's) then you should be monitoring your transmission temperature as well.
Do you have a winch and or lights blocking your front grille? My engine and trans temps are noticeably higher ever since I put lights and a winch in front.
Tires: if you are running E rated heavy tires rather than c rated then you're trying to push heavier tires up those hills and your truck will have to work harder.
randy88fj62 is offline   Reply With QuoteReply With Quote
Old 08-03-2020, 06:51 PM #8
royal T4R royal T4R is offline
royal T4R will become famous soon enough royal T4R will become famous soon enough
BUMP
My V8 started spewing coolant everywhere after I got out to take pictures after a particularly difficult climb. The dash temp gauge was dead center the entire time.
royal T4R is offline   Reply With QuoteReply With Quote
Old 08-03-2020, 07:04 PM #9
xtremewlr's Avatar
xtremewlr xtremewlr is offline
Real Name: Todd
xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold
xtremewlr's Avatar
Real Name: Todd
Originally Posted by royal T4R View Post
BUMP
Fixes already posted in the thread.
Flush the system thoroughly and use new Toyota red/pink coolant or Zerex Asian formula. Make sure the heater is on full hot when you do a flush to get the heater core flushed as well.
Replace water pump with timing belt every time. If you don't know when that was done last, start there. Do the flush first so crap doesn't get in the new water pump.
Replace the radiator if you don't know the history of it. Again, flush first and use new upper and lower hoses.
Check your fan clutch and replace it if questionable.
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
xtremewlr is offline   Reply With QuoteReply With Quote
Old 08-03-2020, 07:15 PM #10
Real Name: Danny
Real Name: Danny
BUMP
Check your radiator cap. If it's not sealing it will allow the coolant to boil out. I replaced mine earlier this summer. I kept smelling anti-freeze and couldn't find where it was going and it was because the cap wasn't holding pressure. A lot of people don't know this but the reason the system has to be pressurized is because pressurizing raises the boiling point of the coolant. And coolant that is boiling cannot cool your engine.
Old 08-03-2020, 08:10 PM #11
hankd's Avatar
Real Name: Harry
hankd's Avatar
Real Name: Harry
thanks folks. fan clutch timing belt and water pump all done within the last month. i am going to have the radiator, ac condenser and rad cap done next week. that should cover all the bases.
no winch or front lights, it's a clear path through the grill. ran a flashlight through it last night, light did get through the rad. but i think it's bad and i think the rad and ac condenser are original on the vehicle. i think one thing that probably happens with these trucks is they get sold at relatively low mileage before the first big scheduled maintenance and then they pass through a few owners and the big maintenance jobs just never get done.
do i need to take the truck in for an ac/recharge when the ac condenser is replaced?
Old 08-03-2020, 08:27 PM #12
xtremewlr's Avatar
Real Name: Todd
xtremewlr's Avatar
Real Name: Todd
Yes. If you are having a shop replace the AC condenser, they should be able to do that. It's part of the job since the system needs to be purged and then refilled when done.
Old 08-04-2020, 06:13 AM #13
Captsolo Captsolo is offline
Captsolo will become famous soon enough
An overheat is something you don't want. I have a 2005 V6 4runner with 150,000 miles and am in the Bahamas (low temp annually 75 degrees / 90 degrees summer).
I've never had an overheat and don't do any special maintenance for the coolant. Original radiator and WP. Replaced radiator cap one time.
4runners hold 2.2 gallons of coolant, and changing it might be smart every 5 years on older car.
Those mountains will "stress" an older (any) car/truck. I'd ask around for advice. I wonder if they have a better/oversized radiator for people in those "rockies".
Keep an eye on it.
I was in Denver where my daughter works for big broker. She drives a 2015 Camry I bought her for graduation - now 6 years old (50,000 miles). As far as I know it has never had an overheat.
Camry runs and starts up like new car. Glad I got her a 4 cylinder Camry. Don't need a 6.
Change the oil and filter every 4000 miles - should help with temps too.
Getting to the "red line" might be normal where you drive.
Captsolo is offline   Reply With QuoteReply With Quote
Old 08-04-2020, 10:05 AM #14
Good call!
I just want to add to this to replace the rad cap with a Toyota cap, not a parts store special. Toyota rad caps are really expensive by comparison but there's a lot to them. I think they're well made in the way the metal is cut, stamped, and put together.
A parts-store special will get you through a bind, but they don't appear to work the same way as a Toyota cap does. And I'd suspect there's legitimate reasons the Toyota is 3-4 times the price.
Old 08-04-2020, 08:52 PM #15
Yes, which is why I suggested only replacing the radiator if the AC is blowing cold.
Too many times I've seen an AC system leak after getting cracked open for the first time.
Between outfits.
condenser , lot , replaced , vehicle , wondering
Only getting warm air Padre 3rd gen T4Rs 4 02-01-2020 05:37 PM
Does your 5th gen. take 20 minutes to warm up? buchaja 5th gen T4Rs 120 01-04-2018 10:45 AM
87 not getting warm Cmwise90 Classic T4Rs 15 01-15-2012 02:30 AM
warm ac simple Problems & Warranty Issues 19 12-31-2008 10:31 PM
Almost Too Warm jpalaska 4th Gen T4Rs 8 12-06-2008 02:38 AM
