Still not level..
04 sport 4x4 90k. After replacing the struts, shocks, sway bars and sway bar bushings the ride height was 34 1/2 on the driver side for the front and rear.
passenger rear 36 1/4
Passenger front 35 1/2
I went ahead and put a spacer on the driver side front strut last week but of course didn't measure.. I left it in and installed a daystar spacer on the rear spring.
New measurements today
Driver front 35
Driver rear 36
Pass rear 36 3/4
Pass front 36 3/4
Should i worry about that small amount being off? From looking at the back it looks a lot better but I still see the lean a bit.
If I park on even the smallest incline or bump on the left side its still very compressed idk if that's normal for these trucks or not.
I will note that I did replace the LCAs last week, the passenger side one was frozen and did not wanna move up or down when the truck was jacked up.
Also which I'm not sure if its big issue yet, the spacer I put on went on top of the spring with the bump stop in between. When I looked up some info on the install it said for the 4runner the spacer goes inbetween the spacer but there's no way it would have went that way without modifying the space.. Should I do that?
