Old 08-03-2020, 05:15 PM #1
Az4runnin's Avatar
Az4runnin Az4runnin is offline
Az4runnin will become famous soon enough Az4runnin will become famous soon enough
Az4runnin's Avatar
Question Anyone Running Smittybilt 2780 2.54 CFM Portable Compressor
Anyone have experience with this Model or any Smittybilt compressor. Any feedback would be great. Thanks
2003 V8 Limited 4x4 Black. JBA UCA's, TRD Pro Wheels. OEM LED Tails, 2012 FJ Springs F/R 5100's F/R 1.75 Cooper AT3 4S 265-70-17. Bye X Reas, Wet Okole Seat Covers Weathertech liners.
Az4runnin is offline   Reply With QuoteReply With Quote
Old 08-03-2020, 06:43 PM #2
ieatfish's Avatar
ieatfish ieatfish is offline
ieatfish will become famous soon enough
ieatfish's Avatar
I'm also curious about this. I've been waffling between the 2780 and Viair 88P.
ieatfish is offline   Reply With QuoteReply With Quote
Old 08-03-2020, 09:43 PM #3
CajunMikeR's Avatar
CajunMikeR CajunMikeR is offline
CajunMikeR is just really nice CajunMikeR is just really nice CajunMikeR is just really nice CajunMikeR is just really nice CajunMikeR is just really nice
CajunMikeR's Avatar
I've got a 2781 mounted under the hood. I've had it for some time, used to use it all the time when I had a F150 FX4. It filled up 34in tires pretty quickly. Just now getting to where I'm about to use it for the 4Runner with a manifold to air up all 4 at once. Not sure how much help I can be, but if you have any specific questions, I'll answer as best I can.
CajunMikeR is offline   Reply With QuoteReply With Quote
Old 08-03-2020, 11:53 PM #4
ieatfish's Avatar
ieatfish's Avatar
I just ordered the 2780. I’ll be sure to post my thoughts when I get it. Still interested to hears other’s thoughts if they have one.
2006 4Runner Sport Edition 4WD V6
Dobinsons 2.5"/1.5" - C59-302, GS59-221, C59-505, GS59-705 | General Grabber ATX 265/70R17 | TPMS Bypass Mod
Custom Storage Box/Sleeping Platform Build | Dedicated Transmission Cooler (Derale D13503) | Demello Offroad Sliders
Old 08-04-2020, 12:00 AM #5
Whytey's Avatar
Whytey Whytey is offline
Whytey has a spectacular aura about Whytey has a spectacular aura about
Whytey's Avatar
I have the 2781 mounted in the cargo area. I added in some standard npt air connectors and a pressure switch so it shuts off when I'm not pumping air (this way I can use a closed air chuck).
The compressor is working great so far.
Whytey's 07 V8 Build Thread
2007 Toyota 4Runner Sport Edition V8, Elka 2.5 Suspension, Total Chaos UCA w/ Delta Uniball, Dobinsins C59-677V Rear Coils, Timbren Bumpstops, Prinsu Design Roof Rack, Baja Designs Squadron Sport Fogs, 285/70R17 BFG KO2, Blacked Out TE Rims, Spidertrax 1.25" Wheel Spacers, Satoshi Grill
Whytey is offline   Reply With QuoteReply With Quote
Old 08-04-2020, 08:03 AM #6
Syr4RinNC's Avatar
Syr4RinNC's Avatar
I did a fair amount of research and this seemed like a good value and people were generally happy with it. I’ve used it a handful of times. Airs up my 265 70 17s from ~24 to 35 psi in less than 10 minutes. No issues w overheating in 90+ degree weather
Old 08-04-2020, 11:06 PM #7
81runner's Avatar
81runner 81runner is offline
Real Name: Elliott
81runner has a spectacular aura about 81runner has a spectacular aura about
81runner's Avatar
Real Name: Elliott
It's fine if you are just using it as is out of the box and don't have huge tires. Doesn't seem to hold up to the heat under the hood too well, I'd recommend spending a little more on the 2781 if you are thinking on board air under the hood
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
81runner is offline   Reply With QuoteReply With Quote
Old 08-05-2020, 12:11 AM #8
Az4runnin's Avatar
Az4runnin's Avatar
I'm not going to onboard air under the hood in Arizona with the temperatures getting 115 in the valley don't trust it.
Old 08-05-2020, 01:45 AM #9
duffdog duffdog is offline
duffdog is a jewel in the rough duffdog is a jewel in the rough duffdog is a jewel in the rough
I have the 2781, its my favorite compressor. I have several of the smaller red 12v compressors, but the big SB is the one I use all the time.
2005 Blue SR5 v8
3" suspension lift, 1" body lift, 315's, rear Elocker, on-board air system, slider air tanks, full skid plates, front Demello bumper, rear HMF plate/tube bumper, rear 9000lb hidden winch, front 10000lb winch, dual electric fans (in cab adjustable temp), rock lights, 25W LED projector lights.
duffdog is offline   Reply With QuoteReply With Quote
Old 08-05-2020, 09:42 AM #10
CajunMikeR's Avatar
CajunMikeR's Avatar
Holds up fine in S. Louisiana summer heat, which is about the same temp and 3-4 times the humidity that you see in AZ.
at least my 2781 does, not sure about the 2780
Old 08-06-2020, 09:28 AM #11
81runner's Avatar
Real Name: Elliott
81runner's Avatar
Real Name: Elliott
So in terms of output, the 2781 puts out 5.65 CFM which is roughly equal to 1hp in the compressor world. The 2780 puts out 2.35 or there abouts, roughly half. Now, the smaller unit (2780) is fine for stock or slightly bigger tires, the 2781 gets there in half the time. This is good to know if you are planning on board air as it will only half to work half as hard to do the same job. Less heat build up, less run time, less time waiting to get back on pavement
Old 08-06-2020, 02:44 PM #12
Az4runnin's Avatar
Az4runnin's Avatar
Thumbs up
I am leaning towards the 2781 for Not that much More than the 2780. Seems like a Very Nice unit. Thanks for all the feedback. I am Running a 275-70-17 so should be perfect.
Old 08-07-2020, 04:34 PM #13
Az4runnin's Avatar
Az4runnin's Avatar
Im Going 2781.
Old 08-10-2020, 07:30 PM #14
ieatfish's Avatar
ieatfish's Avatar
I received my 2780 last night. Comes in a sufficient bag but I transplanted it into a Pelican case I had. I was able to use it this morning to inflate a slow flat in my wife's Sportage. Went from 20 - 30 in about a minute. I want to run some tests on my 4runner when I get a chance but so far it seems well built and was actually quieter than I expected.
I was also able to fit my deflator in the same box so it's easy to toss in as a package when I head out for some fun.
Old 08-10-2020, 08:25 PM #15
Az4runnin's Avatar
Az4runnin's Avatar
Looks like a Nice unit.
compressor , experience , feedback , great , running
Smittybilt compressor on board air t4r_al 5th gen T4Rs 44 05-17-2021 07:36 PM
Smittybilt Compressor mount Brownfaux 4th Gen T4Rs 2 08-02-2020 08:49 PM
What portable air compressor do you use? SavageRunner General Discussions 22 08-12-2017 09:02 AM
Portable Air Tank with Portable Compressor? Stupid idea? subst4nce Engines / Suspension / Wheels / Tires / Audio / Accessories 5 04-17-2011 02:29 PM
need a portable air compressor Big E 4th Gen T4Rs 2 12-06-2005 09:19 AM
