08-03-2020, 05:15 PM
Anyone Running Smittybilt 2780 2.54 CFM Portable Compressor
Anyone have experience with this Model or any Smittybilt compressor. Any feedback would be great. Thanks
2003 V8 Limited 4x4 Black. JBA UCA's, TRD Pro Wheels. OEM LED Tails, 2012 FJ Springs F/R 5100's F/R 1.75 Cooper AT3 4S 265-70-17. Bye X Reas, Wet Okole Seat Covers Weathertech liners.
08-03-2020, 06:43 PM
I'm also curious about this. I've been waffling between the 2780 and Viair 88P.
08-03-2020, 09:43 PM
I've got a 2781 mounted under the hood. I've had it for some time, used to use it all the time when I had a F150 FX4. It filled up 34in tires pretty quickly. Just now getting to where I'm about to use it for the 4Runner with a manifold to air up all 4 at once. Not sure how much help I can be, but if you have any specific questions, I'll answer as best I can.
08-04-2020, 12:00 AM
I have the 2781 mounted in the cargo area. I added in some standard npt air connectors and a pressure switch so it shuts off when I'm not pumping air (this way I can use a closed air chuck).
The compressor is working great so far.
Whytey's 07 V8 Build Thread
2007 Toyota 4Runner Sport Edition V8, Elka 2.5 Suspension, Total Chaos UCA w/ Delta Uniball, Dobinsins C59-677V Rear Coils, Timbren Bumpstops, Prinsu Design Roof Rack, Baja Designs Squadron Sport Fogs, 285/70R17 BFG KO2, Blacked Out TE Rims, Spidertrax 1.25" Wheel Spacers, Satoshi Grill
08-04-2020, 08:03 AM
I did a fair amount of research and this seemed like a good value and people were generally happy with it. I’ve used it a handful of times. Airs up my 265 70 17s from ~24 to 35 psi in less than 10 minutes. No issues w overheating in 90+ degree weather
08-04-2020, 11:06 PM
Real Name: Elliott
Real Name: Elliott
It's fine if you are just using it as is out of the box and don't have huge tires. Doesn't seem to hold up to the heat under the hood too well, I'd recommend spending a little more on the 2781 if you are thinking on board air under the hood
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
08-05-2020, 12:11 AM
I'm not going to onboard air under the hood in Arizona with the temperatures getting 115 in the valley don't trust it.
08-05-2020, 01:45 AM
I have the 2781, its my favorite compressor. I have several of the smaller red 12v compressors, but the big SB is the one I use all the time.
2005 Blue SR5 v8
3" suspension lift, 1" body lift, 315's, rear Elocker, on-board air system, slider air tanks, full skid plates, front Demello bumper, rear HMF plate/tube bumper, rear 9000lb hidden winch, front 10000lb winch, dual electric fans (in cab adjustable temp), rock lights, 25W LED projector lights.
08-05-2020, 09:42 AM
Holds up fine in S. Louisiana summer heat, which is about the same temp and 3-4 times the humidity that you see in AZ.
at least my 2781 does, not sure about the 2780
08-06-2020, 09:28 AM
Real Name: Elliott
Real Name: Elliott
So in terms of output, the 2781 puts out 5.65 CFM which is roughly equal to 1hp in the compressor world. The 2780 puts out 2.35 or there abouts, roughly half. Now, the smaller unit (2780) is fine for stock or slightly bigger tires, the 2781 gets there in half the time. This is good to know if you are planning on board air as it will only half to work half as hard to do the same job. Less heat build up, less run time, less time waiting to get back on pavement
08-06-2020, 02:44 PM
I am leaning towards the 2781 for Not that much More than the 2780. Seems like a Very Nice unit. Thanks for all the feedback. I am Running a 275-70-17 so should be perfect.
08-07-2020, 04:34 PM
Im Going 2781.
08-10-2020, 07:30 PM
I received my 2780 last night. Comes in a sufficient bag but I transplanted it into a Pelican case I had. I was able to use it this morning to inflate a slow flat in my wife's Sportage. Went from 20 - 30 in about a minute. I want to run some tests on my 4runner when I get a chance but so far it seems well built and was actually quieter than I expected.
I was also able to fit my deflator in the same box so it's easy to toss in as a package when I head out for some fun.
2006 4Runner Sport Edition 4WD V6
Dobinsons 2.5"/1.5" - C59-302, GS59-221, C59-505, GS59-705 | General Grabber ATX 265/70R17 | TPMS Bypass Mod
Custom Storage Box/Sleeping Platform Build | Dedicated Transmission Cooler (Derale D13503) | Demello Offroad Sliders
08-10-2020, 08:25 PM
Looks like a Nice unit.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
