Old 08-03-2020, 11:21 PM #1
cwilliams563's Avatar
cwilliams563 cwilliams563 is offline
cwilliams563 has a spectacular aura about cwilliams563 has a spectacular aura about cwilliams563 has a spectacular aura about
Front turn signal dual filament socket with 3 wires available?
Wondering if there is a 3 wire dual filament plug that will work and fit for an 06-09 front headlight turn signal. One like a 7443 (same as rear) or a 3157. I have the DTRL’s in my 08 and the glass bulb gets so hot it’s burning the socket and melted the inside of the headlight housing. The bulb was stuck in due to it melting and a regular replacement bulb will not fit back in because it’s now miss shaped.
I want to run LED’s because they will fit where the glass bulb won’t now and they won’t get hot like the glass bulb. I’ve already bought and received my 4 LED’s for front and back and would like to make them work while keeping a DRL function. I will just run the power and ground as the turn signal, bend my tab for the flasher on the DTRL’s, and just wire the other power to an ignition source so I will have DTRL’s and be able to use a resistor for the flashers that won’t get crazy hot due to not being on the whole time.
Looking for a style bulb like this to be able to use
And here’s what mine looks like
Front turn signal dual filament socket with 3 wires available?-83b2bc2a-20b6-477a-b116-f2c0ba0fb78d-jpg  Front turn signal dual filament socket with 3 wires available?-449a6f5c-b636-440c-a6dd-06fe5e916989-jpg  Front turn signal dual filament socket with 3 wires available?-fdcc0149-71e9-4b28-91b8-e4807ea07a55-jpg
My build thread https://www.toyota-4runner.org/4th-g...ml#post3520544
2008 Titanium Metallic 4WD 4Runner V6 SR5| Satoshi Grille mod|17x8 Level 8 MK6 wheels, 275/70/17" Falken Wildpeak tires| Front-Bilstein 5100's set at 0 with ToyTec branded Eibach silver springs and 1/2" ToyTec spacer driver side, 1/4" ToyTec spacer passenger|Front Diff. drop spacer kit|sway bar relocate kit| Rear-Fox 2.0Resi and ToyTec superflex black springs|Tyger Bull bar with LED's/Lund HX tube side steps
2021 Subaru Crosstrek Limited in Crystal White Pearl
cwilliams563 is offline   Reply With QuoteReply With Quote
Old 08-04-2020, 04:52 AM #2
Ed_C's Avatar
Ed_C Ed_C is offline
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
The Flosser brand sockets from this seller may work. As-is the 7443 sockets were an almost direct fit in place of Toyota 7440 sockets, just had to do some minor tab trimming. You'll probably need the 1157 versions since 7440/7443 are physically smaller. https://www.ebay.com/str/formulaj87/...cat=5067193011
Did you do JA's DRL mod to the existing flasher relay?
Old 08-04-2020, 09:47 AM #3
That does look like a similar style, I’ll check them out and see if I can find some dimensions, thank you. Hopefully I can make one work. I’ll look into the 1157 style as well. For the 3157 it seems they come up on superbright led’s for an option in the front so thought maybe they’d work?
No I didn’t do a JA DRL mod for mine. Mine has the DRL’s from the factory. I do have raptor style lights on the front of my Satoshi grille I made now that I installed an on/off switch for so I figured it would be a easy enough to just tie into that and have an on/off function as well for the DRL’s.
Old 08-04-2020, 10:59 PM #4
81runner's Avatar
81runner 81runner is offline
Real Name: Elliott
81runner has a spectacular aura about 81runner has a spectacular aura about
81runner's Avatar
Real Name: Elliott
Oem 81125-35440. Wiring harness and socket for the turn signal. If you trace the wiring back to the main harness, you'll see it just plugs in for easy change out... It's almost like they knew there would be a problem... Get canbus anti-hyperflash LEDs if you are looking to go that way. Easier to just replace a bulb than to splice in a resistor that gets super hot.
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
81runner is offline   Reply With QuoteReply With Quote
Old 08-05-2020, 11:05 AM #5
Ed_C's Avatar
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
But he wants a socket for a dual-filament bulb, which has 3 wires and 3 contacts within the socket (common ground, + for parking/dim filament, + for turn/bright filament)
Old 08-05-2020, 09:40 PM #6
Ed is correct, I was asking for a 3 wire direct fit replacement socket, but am open to alternative ideas and suggestions that are proven to work. I would prefer to keep it how it is and use a Canbus bulb, that would be great if it worked!
Question, would the Canbus bulb get hot like the halogens when on constantly using them for DTRL’s? That’s what burned and melted my existing headlight housing because the halogen got too hot.
For the interim I had to put the 1156 LED that I have in my front passenger side and just deal with the hyper flashing for now so I can at least have a turn signal.
bulb , fit , hot , turn , won’t
Dual Function Corner/Turn Signal LED ngfilla94 5th gen T4Rs 11 09-13-2018 06:47 PM
Front right turn signal mlc2000 4th Gen T4Rs 7 09-24-2017 04:00 PM
Intermittent Turn Signal/DRL Problem with Dual Front Signals gaterose 4th Gen T4Rs 12 08-14-2015 09:26 PM
front turn signal help Ashtonguyton 4th Gen T4Rs 3 12-11-2013 11:29 AM
Front turn signal mod Iron Clad Lou Engines / Suspension / Wheels / Tires / Audio / Accessories 28 10-31-2011 02:16 PM
