Old 08-04-2020, 05:31 PM #1
benztech82's Avatar
benztech82 benztech82 is offline
benztech82 will become famous soon enough
benztech82's Avatar
Pulling to the right
Hey all,
Got this after 3rd alignment attmept. Truck is pulling to the right, not crazy but noticable. I have 5100+ome coils, freedom uca's. Some cheap aftermarket lca's.
Pulling started after lift.
Any ideas ?
Sent from my Redmi 4 using Tapatalk
benztech82 is offline   Reply With QuoteReply With Quote
Old 08-04-2020, 07:20 PM #2
montijo505's Avatar
montijo505's Avatar
Originally Posted by benztech82 View Post
Hey all,
Any ideas ?
Check your right brake caliper, could be frozen and cause the pulling, especially since three alignments haven't fixed it.
Sent from my SM-G986U using Tapatalk
Old 08-05-2020, 04:43 PM #3
benztech82's Avatar
benztech82's Avatar
I replaced brake pads just recently. All caliper pistons pushed right back inside the caliper. I don't see it being a brake pull issue. I did replace lower control arms around 6 month ago and I think that they are not build up to original spec. The thing is that before I had a spacer lift and truck never pulled to the side with those cheap lca's.
Old 08-05-2020, 05:08 PM #4
royal T4R royal T4R is offline
royal T4R will become famous soon enough royal T4R will become famous soon enough
Why did you allow the tech to give you the truck with almost a whole degree of caster between both sides?
Steering Problems: Solving a Steady Pull
I'd check tire PSI and get those numbers a lot closer.
royal T4R is offline   Reply With QuoteReply With Quote
Old 08-05-2020, 10:13 PM #5
benztech82's Avatar
benztech82's Avatar
Tech told me that vehicle either was in accident or something and that's a second alignment shop. And i know that it wasn't pulling during 3 years that i owned it before the lift. I really think it has do with crappy control arms
Once freedom offroad arms went in caster went to higher numbers like it should, but there was still 1degree appart. Tech also told me that if he corrects caster to same numbers, camber is going out of wack.
Old 08-05-2020, 10:44 PM #6
pearlj10 pearlj10 is offline
pearlj10 is on a distinguished road
The caster difference L-R is disturbing. I am not familiar with that brand, but both the upper and lower control arms are vital components and you don’t want to press your luck there. But, also, don’t forget that the rear axle may not be tracking straight after the lift. An adjustable trac/pan hard bar like this will correct it, if that’s the problem. Good luck.
Fully Adjustable Trac/PanHard Bar 4Runner/FJ Cruiser - $225.00 : Sonoran Steel Fabrication LLC, Toyota Truck Parts
pearlj10 is offline   Reply With QuoteReply With Quote
aftermarket , cheap , lcas , pulling , started
Pulling to the Right in 4H CO_Fletch 4th Gen T4Rs 7 11-15-2014 04:00 PM
pulling to the right in 4wd ColoRaider 3rd gen T4Rs 5 03-10-2013 07:18 PM
Pulling To Right In 4HI Cambo 3rd gen T4Rs 8 07-04-2012 05:37 PM
Pulling an F-250 Arcking 4th Gen T4Rs 26 02-19-2011 09:20 AM
