Old 08-07-2020, 08:33 AM #1
drallan drallan is offline
drallan is on a distinguished road
Intermittent steering wheel vibration when braking
I did the front pads and rear rotor/pads on my mother-in-laws 04 v8 a few weekends ago. In talking with her the other day she mentioned that every now and then she will get a shaking in the steering wheel when braking, but only when slowing from like 60 to 40. Below that it goes away, and isn't consistent. It may happen just once a day. I gave it a test drive but was unable to recreate the issue. Any thoughts?
I've done some research and because there were no noticeable issues prior to brake job I don't suspect it is due to bushings, ball-joints or cvs, but it could be. Everything felt tight but I didn't do a super thorough inspection. Also, besides rear pads being worn to the metal and starting to gouge rear drivers rotor, i didn't see any indication of stuck caliper or uneven pad wear.
The one thing I am leaning towards is that I think the pads we put on the front were ceramic (carquest wearever platinum ceramic) and I would assume the rotors were standard steel rotors.
Could putting new ceramic pads on old steel rotors cause a problem? I've done some searching and it looks like there could be some sort of temperature related uneven distribution of the ceramic coating that occurred during break-in (no real break-in process was followed) which might explain the intermittent nature of the vibration.
If this is in fact the case. Is there anyway to re-coat or redistribute the ceramic coating?
Will the problem eventually go away?
Should I just replace the rotors with new ones?
Do I need new pads as well?
Should I put semi-metallic pads back on?
I'd like to do the job just once more.
Any suggestions?
drallan is offline   Reply With QuoteReply With Quote
Old 08-07-2020, 10:06 PM #2
T4Rmiller T4Rmiller is offline
T4Rmiller is on a distinguished road
does the pedal vibrate also or just the wheel? I just replaced both front axles for a similar vibration (wheel only)
T4Rmiller is offline   Reply With QuoteReply With Quote
Old 08-07-2020, 10:22 PM #3
CarlosV CarlosV is offline
Real Name: Carlos V.
CarlosV will become famous soon enough
My experience, not much help.
A few months back I changed my front OEM pads (no shaking, but thin) with locally available "American Black" metallic pads ( I suppose somebody is going to set on fire a couple of buildings because of the name) and resurfaced the original OEM rotors (they looked like new after).
Did poor break-in. Couple of weeks later same problem as yours, steering shake (not brake pedal) when breaking down from around 40mph.
Shaking didn’t go away so after 2-3 months, new Brembo rotors and Akebono ceramic pads with proper break-in (empty streets due to COVID).
Since, now 2 months later there hasn’t been any shaking. Improved breaking.
Got the feeling proper break-in made the difference.
Maybe having resurfaced again the original rotors and proper break-in would have fix the problem.
Gold 2003 4Runner SR5 V6 2WD A340E
Grabber A/T, Brembo rot, Akebono pads, Optima batt, HKB Volt. booster, Buffalo Bayou recovery
Sony XAV1000, LED interior and reverse, Weathertech, Flux-Turbocharged tire valve caps.
CarlosV is offline   Reply With QuoteReply With Quote
Old 08-15-2020, 10:34 PM #4
himeeto69 himeeto69 is offline
himeeto69 is on a distinguished road
Any suggestions?
I have a similar vibration when braking. Thought maybe it is worn rotors. Hopefully it isn't too involved.
himeeto69 is offline   Reply With QuoteReply With Quote
Old 08-17-2020, 03:52 PM #5
knarfwhite knarfwhite is offline
knarfwhite is on a distinguished road
Sounds like front rotors are bad. If it happens only sometimes it may be only after the rotors have heated up. I changed my front rotors and pads and a few months later developed intermittent vibration. The difference is mine was vibrating without braking. Sure enough it was a sticking caliper. The calipers are a real common 4Runner problem. I've changed 3 out of 4 in past year.
knarfwhite is offline   Reply With QuoteReply With Quote
Old 08-17-2020, 04:09 PM #6
riverwolf riverwolf is offline
riverwolf is on a distinguished road
FWIW, I'm like 99% certain that the 4th Gen OEM pads are ceramic, so that's not likely your problem. It's a simple bad interface between new pads and old rotors...unless the intermittent vibration was there before and your M-I-L hadn't noticed because she wasn't paying special attention until you touched her truck. Without putting them on a dial indicator, you'll never know for sure. Same work plus a few bucks just to go ahead and swap the rotors before the new pads get mated to the bad rotors.
I went Akebono Ceramics (possibly the OEM for Toyota) with Centric rotors, myself when I got tired of a brake vibration that showed up before I even hit 80k. I think my "warped" front rotors were caused by letting the dealership do a few tire rotations where they likely applied uneven and/or too much torque to the lug nuts. I hate letting anyone touch my vehicles for service...
Good luck.
2003-2022: '03 Limited V8 4x4 - Galactic Gray Mica
2022-Present: '21 Nightshade 4x4 - Magnetic Gray Metallic
riverwolf is offline   Reply With QuoteReply With Quote
ceramic , pads , rear , rotors , uneven
Intermittent steering wheel vibration when braking mmt 4th Gen T4Rs 3 04-05-2019 12:10 AM
Braking shakes steering wheel? Silvergrowler 4th Gen T4Rs 16 08-30-2014 03:42 PM
Shaky steering wheel when braking GmuasRunner 4th Gen T4Rs 6 07-02-2013 10:11 AM
Braking vibration, intermittent problem gdewet 3rd gen T4Rs 12 05-28-2009 11:02 AM
Steering wheel vibration when braking... hekili Problems & Warranty Issues 6 06-25-2005 11:38 PM
