Old 08-07-2020, 08:54 AM #1
Seasparrow Seasparrow is offline
Seasparrow will become famous soon enough
Where does front differential engage ???
Obviously at the center diff, but read on. It takes a lot for me to get under my truck. I drive up on 4 wide heavy wooden platforms to grease my driveshaft. I forgot to take it out of 4WD and it of course would not spin freely. I got out, took it out of 4WD, turned the shaft to get to the zirks and greased the fronts.
Question, where does it engage? obviously at the center diff but if it spins freely it also has to disengage from the front diff correct? So the question is, what disengages the front diff.
NATO Seasparrow Mk 57 Mod 2 & 3
2004 4th Gen Sport Edition
Seasparrow is offline   Reply With QuoteReply With Quote
Old 08-07-2020, 09:20 AM #2
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
Based on what I understand, ADD (automatic differential disconnect) unlocks the passenger side from the front differential and the front driveshaft is disengaged by the tcase. In my head, the front driveshaft will spin freely by hand in 2wd is because the differential acts like you're stuck: The passenger side output will act like the unstuck wheel and spin because its disconnected within the diff, and the driver side will be the stuck wheel and not move. Seems like there could be a lot of wear on the spider gears in 2wd if the ring gear isn't turning, but they're not under an engine load, so I dunno about that part. Hopefully someone that understands a bit more about ADD will chime in.
Hard to see with these pictures since I was focusing on the CV, but the box with the wires is the ADD actuator. This is viewed in from the passenger side wheel well.
y=mx+b is offline   Reply With QuoteReply With Quote
center , diff , engage , freely , front
Center differential + rear differential + front differential = confusion! badburro 5th gen T4Rs 37 01-29-2019 12:40 PM
Front doesn't engage achha64 3rd gen T4Rs 0 02-15-2016 11:34 PM
Differential does not engage? 2007 4runner 4th Gen T4Rs 1 02-01-2011 06:30 PM
97 4runner differential wont engage buligadima Problems & Warranty Issues 1 11-24-2009 05:42 PM
how to lock center differential and engage 4wd low 007Runner 4th Gen T4Rs 1 12-05-2006 11:10 PM
