Old 08-08-2020, 08:06 PM #1
hoffmanmark hoffmanmark is offline
hoffmanmark is on a distinguished road
LCA frustration!!!
So today I tried to replace my LCAs. Everything came loose on both the DS and PS except being able to get the front bushing sleeves out. Has anyone else had this issue?
We tried everything from PB to heat and a mallet. Tomorrow I plan I cutting them off with a saws all. Thanks in advance.
LCA frustration!!!-8d57c919-650e-46c3-afa4-444d54287a34-jpeg
hoffmanmark is offline   Reply With QuoteReply With Quote
Old 08-08-2020, 08:12 PM #2
montijo505's Avatar
montijo505's Avatar
Doesn't even look rusted. Hopefully someone can give advice. I just removed mine but had no issues. Everything pulled right out.
Sent from my SM-G986U using Tapatalk
Old 08-08-2020, 08:15 PM #3
Hunter61 Hunter61 is offline
Real Name: Steven
Hunter61 will become famous soon enough
Real Name: Steven
I did mine last December and had to cut them out with a saws all using these blades. You'll want at least 2 blades:
Diablo DS0608CF 6" Carbide Tipped Reciprocating Saw Blade - - Amazon.com
Here's a helpful video.
Front Lower Control Arm Bushing Replacement (Part 2) - YouTube
Hunter61 is offline   Reply With QuoteReply With Quote
Old 08-08-2020, 10:11 PM #4
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
If you have removed all the cam hardware, then just cut it out. I second the diablo blades, they're the only way to go. My cams were seize, so I cut through everything
Heres a pic of the cam hardware with the rear on the left and the front on the right, just to confirm you have everything before cutting. There is a through bolt with integral cam, cam washer, and nut for the rear. The front has a plain through bolts, cam sleeve, and cam washer with integral nut.
y=mx+b is offline   Reply With QuoteReply With Quote
Old 08-10-2020, 08:09 AM #5
Zero0575's Avatar
Zero0575 Zero0575 is offline
Real Name: Casey
Zero0575 will become famous soon enough Zero0575 will become famous soon enough
Zero0575's Avatar
Real Name: Casey
Same as everyone else, I had to use a sawzall with a carbide tipped blade to cut both of mine out. With that blade, it was easy - just be careful and don't cut anything else in the process!
2007 Limited V8 | 275/70/18 Falken Wildpeak AT3W | Spidertrax | 4xInnovations Weld On Sliders | Victory 4x4 Blitz Front Bumper | RCI Skids | TNF Rear Bumper | Smittybuilt Winch | KOYORAD Aluminum Radiator |OME 886 Front/Toytec Superflex HD Rear and OME Shocks/Struts | JBA High Caster UCA | Rebuilt LCA with Superpro bushings + Moog BJ | HCF Delete | Doug Thorley Shorty Headers | Magnaflow HFC | Gibson Catback | Rear Diff Breather Extension | 20" Spot/Flood | 9" Spots | DD SS3 Yellow Fogs | Amber Grill Lights | Fog Lights Anytime Mod
Zero0575 is offline   Reply With QuoteReply With Quote
Old 08-10-2020, 08:17 AM #6
jcaino jcaino is offline
jcaino will become famous soon enough jcaino will become famous soon enough
If you can't get them to budge with a BFH and heat, cut 'em.
Like others have said, use a blade specifically for cutting steel, take your time and cut straight....it will cut pretty easily.
2003 Galactic Gray Mica Limited V8
Inside: Pioneer AVH-2300NEX w/ backup cam | Dometic CFX3 55im | Custom floor w/ table & drawers
Outside: Hefty Fab Bumper | Warn ZR 10-S | RCI skids & sliders
Electrical: 150w solar panel | Victron MPPT controller | BlueSea breakers and panels
Suspension & Tires: Bilstein 5100's w/ Dobinson c59-314 & c59-329 | 5th Gen Trail wheels & Wildpeak A/T3W 275/70/17
jcaino is offline   Reply With QuoteReply With Quote
Old 08-12-2020, 12:25 PM #7
Chef_Jon Chef_Jon is offline
Chef_Jon is on a distinguished road
I was told my LCA is seized on the PS and would probably need to be cut out to be replaced. Luckily enough it’s seized in spec for my alignment, but if/when I replace it I’ll be in your position.
Chef_Jon is offline   Reply With QuoteReply With Quote
cutting , heat , issue , lca , mallet
Frustration 87pony Feedback on Sellers & Buyers 6 12-29-2017 07:43 PM
Project Frustration 4flyer 3rd gen T4Rs 2 10-08-2016 05:45 PM
Insurance Frustration! Jetboy 5th gen T4Rs 62 07-01-2016 08:12 AM
LBJ frustration... ShooterMcGavin 3rd gen T4Rs 15 03-03-2015 12:32 PM
Belt Frustration ZombieDave 3rd gen T4Rs 2 05-02-2008 12:12 AM
