Old 08-10-2020, 04:54 PM #1
Kingstonlake's Avatar
Kingstonlake Kingstonlake is offline
Real Name: Paul
Kingstonlake is on a distinguished road
Real Name: Paul
6 hours into a timing belt and “not done yet”
“Having trouble with a bolt that broke“ should be done tomorrow morning. Does this sound reasonable? 2003 timing belt and water pump replacement.
2002 4Runner SR5 Sport 95K
2003 4Runner SR5 270k
Kingstonlake is offline   Reply With QuoteReply With Quote
Old 08-10-2020, 04:58 PM #2
bbix333 bbix333 is offline
bbix333 is on a distinguished road
Yes. I am doing my timing belt right now - consider myself to be very competent and careful and even I rounded one nut and two bolts and almost a third. As usual, the way to get it those busted nuts and bolts off was a torch.
bbix333 is offline   Reply With QuoteReply With Quote
Old 08-10-2020, 07:08 PM #3
Caldizzle's Avatar
Caldizzle Caldizzle is offline
Real Name: Calvin
Caldizzle will become famous soon enough
Caldizzle's Avatar
Real Name: Calvin
Sounds about par for the course...my first time took me about 9 hours, the second time just under 6. Don't forget to put the plastic triangle piece back on the bottom part of the timing cover.
2006 Sport Edition 4x4 V8
Bilstein 6112 w/ King 700# springs (5th clip), Toytec 2" springs in the rear w/ ICON 2.0,
CBI single hoop front bumper, Smittybilt 9500 XRC, RCI steel full skid package, 285/70r17 BFG KO2s on TRD Offroad wheels
Caldizzle is offline   Reply With QuoteReply With Quote
Old 08-10-2020, 09:31 PM #4
rdruss's Avatar
rdruss rdruss is online now
Real Name: Ron
rdruss's Avatar
Real Name: Ron
I have an '03 V8 too, I let the dealer do the timing belt last time, but to answer your question, yes, 6 hrs. doesn't sound bad and a broken bolt on an '03 sounds par! I just broke four last week, three of four on the rear sway bar bushing brackets and one of two on the fuel tank straps!
rdruss is online now   Reply With QuoteReply With Quote
Old 08-11-2020, 12:13 AM #5
jewski_brewski jewski_brewski is offline
jewski_brewski is on a distinguished road
It took my brother and I almost two whole days to change mine... we took our time and stopped intermittently to watch YouTube videos on the next steps. We also ran into a problem with tightening the crank pulley as I didn't realize you need a special tool to hold it. Lucky for me, my engineer dad quickly fabricated one out of a steel bar. It was such a relief to finish that job.
jewski_brewski is offline   Reply With QuoteReply With Quote
Old 08-11-2020, 07:09 AM #6
Real Name: Paul
Real Name: Paul
Fair enough. My only concern was I dropped it off Friday after making the appointment 3 weeks earlier. Told him I’ll be gone for the weekend so I don’t need it for the weekend. When we came back Sunday afternoon it hadn’t moved from where I parked it. Called Monday morning and he said they just started it. Ok.... He called about 2pm and said they were putting it back together and the fan bearing was squeaky and they were already in there and could get one for $175. I said pass. About 5pm I called and asked if he was saying it pretty much done and ok to pick up. He said no. They leave at 4:30 and they had trouble with a bolt that broke and it should be done in the morning. The skeptic in me thinks he’s getting the $175 either way... I just don’t understand quoting 4 hours and more than likely getting a bill for 8 hours. Mechanic told me he’s done plenty of 4.7’s, did one on a Sequoia couple days earlier.
Old 08-11-2020, 09:30 AM #7
The G-Man The G-Man is offline
Real Name: Gary
The G-Man is on a distinguished road
Real Name: Gary
He should only be billing you for the book time. One tough bolt shouldn’t be enough to warrant charging more on the labor end.
The G-Man is offline   Reply With QuoteReply With Quote
Old 08-11-2020, 10:56 AM #8
Real Name: Paul
Real Name: Paul
Guy just called and said they were done. I asked for the total and he said $377.24 which is extremely reasonable. A bargain really. I did ask when I dropped it off I wanted to see the pump and belt as I wasn’t sure when it was last changed. We’ll see if they saved it.
Old 08-11-2020, 12:37 PM #9
377 for the labor? I'd say that's pretty fair. All in I will probably have about 6-7 hours into changing it myself. Only 76000 miles on mine right now and the water pump gasket was leaking in two spots.
belt , pump , reasonable , timing , water
3rd Gen Timing Marks for Timing Belt Replacement FTW1996 3rd gen T4Rs 4 10-01-2015 04:00 PM
Timing belt? or Timing chain? MNguns General Discussions 3 06-24-2013 12:06 AM
Timing Belt Tensioner: Should I replace it when doing the timing belt change? Lugnutz 3rd gen T4Rs 14 05-12-2011 12:58 PM
Aisin timing belt kits vs. Dayco Timing Belt Kits drz Maintenance/Detailing 1 10-11-2010 06:42 PM
