Old 08-11-2020, 12:46 AM #1
derekl123's Avatar
derekl123 derekl123 is offline
Real Name: Derek
derekl123 is on a distinguished road
derekl123's Avatar
Real Name: Derek
Slow Tapping Noise on Cold Start
Hello all,
Been recently dealing with a slow tapping noise on cold start (doesn't seem to happen when starting in hot weather or having driven prior). Sometimes presents as a squeak instead of a tap. Seems to be coming from the driver side cylinders. Slows down a bit when in gear and goes away after a minute or two or once I start driving. Noise seemingly started to happen a few hundred miles after I changed spark plugs and drive belt. Rechecked spark plug gaps and tried swapping plugs and coil packs on each side, noise still remains. Oil level is good. No CEL or codes and haven't noticed any performance issues. Don't think it is an exhaust manifold leak after checking with smoke machine and stethoscope. Any thoughts?
Video: 1GR Tapping Noise
2008 4Runner Sport V6 4WD White
derekl123 is offline   Reply With QuoteReply With Quote
Old 08-11-2020, 03:13 AM #2
MrSeth's Avatar
MrSeth MrSeth is offline
Real Name: Seth
MrSeth is a jewel in the rough MrSeth is a jewel in the rough MrSeth is a jewel in the rough MrSeth is a jewel in the rough
MrSeth's Avatar
Real Name: Seth
Sounds like either a cracked exhaust manifold or bad exhaust manifold gasket! When it heats up, the metal expands and stops the tick noise.
2006 Shadow Mica SR5 v6
1" BL, Fox Racing UCA's, RC 3" N3 Lift, Rock Trix RT110 -12 Wheels, 315/70R17 Goodyear Territory MT, Tacoma Front Bumper, 5th Gen 4R Tire Carrier, Big Lion LED's
MrSeth is offline   Reply With QuoteReply With Quote
Old 08-11-2020, 07:59 AM #3
Kingstonlake's Avatar
Kingstonlake Kingstonlake is offline
Real Name: Paul
Kingstonlake is on a distinguished road
Real Name: Paul
Same here. Positive its an exhaust manifold leak. AT about $1500 to fix its just something I'll learn to live with.....
2002 4Runner SR5 Sport 95K
2003 4Runner SR5 270k
Kingstonlake is offline   Reply With QuoteReply With Quote
Old 08-11-2020, 08:31 AM #4
JONBOY345 JONBOY345 is offline
JONBOY345 has a spectacular aura about JONBOY345 has a spectacular aura about JONBOY345 has a spectacular aura about
Until it eventually burns up a valve and then you're looking at double that minimum.
'09 V8 Limited | Dobinsons Lift | Front: 3" - C59-302 + GS59-220 | Rear: 2.5" - C59-675V + GS59-701 | Tires | Ridge Grappler 275/65/18XL | Wheels | Method Standard Machined Finish 18x9 -12 offset | SPC UCAs | DT Long Tubes | GSport 2.5" Cats | DT Y-Pipe | Magnaflow Cat Back | 2.5" Vibrant Ultra Quiet Resonator
JONBOY345 is offline   Reply With QuoteReply With Quote
Old 08-11-2020, 01:26 PM #5
derekl123's Avatar
Real Name: Derek
derekl123's Avatar
Real Name: Derek
I've recently been dealing with a P0430/P0174 codes. I checked with a smoke machine for any vacuum/exhaust leaks and only found one where the manifold joins the 2nd cat. Replacing the gasket sealed it up.
Old 08-15-2020, 09:57 PM #6
himeeto69 himeeto69 is offline
himeeto69 is on a distinguished road
Does this mean you think there's more than just an exhaust leak?
himeeto69 is offline   Reply With QuoteReply With Quote
Old 08-16-2020, 07:56 AM #7
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
What he means is with an exhaust leak if it's severe enough it can can damage a valve if cold air gets in contact with a hot valve.
But I've never heard of an exhaust leak causing a burnt valve, only warping a valve, but the result is the same, you lose the power from that cylinder.
2004 Limited V8
noise , plugs , slow , spark , start
Cold start engine noise cb_avatar 4th Gen T4Rs 40 02-11-2022 06:55 PM
Underfoot vibration at start up, shutoff and slow acceleration + whirling noise at 30 bigskyeric 4th Gen T4Rs 1 05-04-2018 03:56 PM
Strange noise on a cold start Foques 5th gen T4Rs 13 11-17-2015 12:15 AM
Squeaky noise on cold start ups medicrn 4th Gen T4Rs 3 10-09-2012 09:15 AM
Tapping Noise in Brake Pedal Cold Start kenm09 4th Gen T4Rs 4 09-29-2012 11:13 AM
