Old 08-14-2020, 12:47 PM #1
eleven14 eleven14 is offline
eleven14 has a spectacular aura about eleven14 has a spectacular aura about
UCA Installation Question
I've never worked on UCAs but need to upgrade my front springs.
My question is are massive efficiencies to be gained by replacing the UCAs while the shocks/springs are removed? Only asking to decide whether it's worth replacing it all at once or upgrading my springs and making the call on UCAs based on alignment/driveability.
I think I know the answer here but want to hear from those that have actually done UCAs.
Thanks in advance
eleven14 is offline   Reply With QuoteReply With Quote
Old 08-14-2020, 12:57 PM #2
randy88fj62's Avatar
randy88fj62 randy88fj62 is offline
randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about
If you use front lift struts (springs and coils) that are over 2" then you may not be able to get the front aligned. Some trucks can others can't, it really depends on the geometry.
So some people install aftermarket UCAs that move the upper ball joint position to adjust for a lifted suspension. So depending on what you are installing it may be worth upgrading.
randy88fj62 is offline   Reply With QuoteReply With Quote
Old 08-14-2020, 01:39 PM #3
montijo505's Avatar
montijo505's Avatar
I think the question was more along the lines of, should I do it while I have it apart?
It's not a terrible job, really only the long through bolt and the spindle castle nut to get them off. Well other than having to remove the battery on the driver side. No real advantage to doing them at the same time as lift other than the alignment perspective.
Sent from my SM-G986U using Tapatalk
Old 08-14-2020, 02:22 PM #4
Perfect, thanks
Old 08-15-2020, 04:43 PM #5
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
BTW, I have an '03 V8, installed SPC's a few weeks back and did not have to remove, or even loosen battery, the bolt head slipped by with minimal contact with battery, so check it out first.
Old 08-15-2020, 05:29 PM #6
4RunnerAquasport's Avatar
4RunnerAquasport 4RunnerAquasport is offline
Real Name: Brett
4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of
Real Name: Brett
This is on a Tacoma but it's a very similar operation with the 03' to 20' 4Runner.
1988 DLX 22RE AUTO BLACK-"Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
4RunnerAquasport is offline   Reply With QuoteReply With Quote
Old 08-15-2020, 09:15 PM #7
mjg514 mjg514 is offline
Real Name: Matt
mjg514 will become famous soon enough
Real Name: Matt
UCA's would be a good idea if:
- you are lifting the truck close to 3" in the front. UCA's will be key for proper re-alignment.
- you plan on going up to 33" tires. the additional degrees of caster will make these easier to fit/align.
mjg514 is offline   Reply With QuoteReply With Quote
question , replacing , springs , ucas , upgrading
Panhard bar installation question lrc4runner 3rd gen T4Rs 9 07-06-2015 07:08 PM
HID installation question marcel 3rd gen T4Rs 8 12-28-2010 12:01 AM
Jaos Installation Question Jaebster Engines / Suspension / Wheels / Tires / Audio / Accessories 1 06-10-2007 12:49 PM
Question for Installation of Pioneer Z1? HELP! hoch21 Engines / Suspension / Wheels / Tires / Audio / Accessories 1 05-23-2006 11:15 AM
MSD installation question sucurru Classic T4Rs 1 03-29-2006 12:26 PM
