Old 08-14-2020, 02:41 PM #1
Cory619's Avatar
Cory619 Cory619 is offline
Cory619 is on a distinguished road
Cory619's Avatar
Ditch lights recommendation
I am looking for info on ditch light mounts that allow for a flood and direct beam lights. Also what brand of light would you recommend? I've searched the forum but all the threads seem to be old. Looking for up to date installs. TIA
2004 Limited 4Runner, OME 885 5100, BFG 185/75/17
Cory619 is offline   Reply With QuoteReply With Quote
Old 08-14-2020, 05:59 PM #2
06_dark_knight 06_dark_knight is offline
Real Name: Mario
06_dark_knight is on a distinguished road
Real Name: Mario
Were you looking for a mount that can hold 2 lights each?
I have the CBI mounts and I like the way they look and installing them was really easy. As far as light brands go I have some off brand lights that I bought at the off road expo a long time ago and they have worked great so really it’s just a matter of how cool you wanna look in my opinion lol
06_dark_knight is offline   Reply With QuoteReply With Quote
Old 08-14-2020, 07:47 PM #3
mysticz's Avatar
mysticz mysticz is offline
mysticz has a spectacular aura about mysticz has a spectacular aura about
mysticz's Avatar
Just get something similar to a Baja Designs Squadron Driving Combo.
2005 T4R Silver SR5 V6 4wd with Mods.
mysticz is offline   Reply With QuoteReply With Quote
Old 08-15-2020, 01:03 AM #4
KrazedJD's Avatar
KrazedJD KrazedJD is offline
KrazedJD is on a distinguished road
KrazedJD's Avatar
I have CBI Mount and have two 3" cubes ... one pair wide beam (outer) and other spot beam (Inner). They work well no complaints, the lights are Amazon knocks offs and I have had no leaking issues for a year (knock on wood)
KrazedJD is offline   Reply With QuoteReply With Quote
Old 08-16-2020, 10:31 AM #5
Forum148 Forum148 is offline
Forum148 is on a distinguished road
Did you drill a second hole in the CBI bracket to get that to work?
06 V8 SR5 --Kings--JBAs--RCI armor--Lil B's--33s--Wheel and Party--
Forum148 is offline   Reply With QuoteReply With Quote
Old 08-17-2020, 12:48 PM #6
KrazedJD's Avatar
KrazedJD's Avatar
Apologizes for delay I was not around this weekend, Yes I did drill the second hole ... I will try to get a closeup shot if it helps!
Old 08-17-2020, 04:57 PM #7
Baja Designs Baja Designs is offline
Baja Designs will become famous soon enough Baja Designs will become famous soon enough
We're a little bit bias. I would say the majority of our 4Runner customers use our Squadron series on the A-pillar. We have the Squadron Sport (3150 lumens) and the Squadron Pro (4900 lumens). If they're pointed straight, it would best be used as a spot light. That's because we're trying to reduce the hood glare that the light would produce. Hood glare can be extremely annoying or even blind the driver. But if you were using them as ditch lights pointed 45 degree away from the A-pillar, a driving/combo or wide cornering lens would be preferred. Let me know if you have any questions on our brand or any of our products. Thank you!
Baja Designs is offline   Reply With QuoteReply With Quote
Old 08-24-2020, 05:10 PM #8
KrazedJD's Avatar
KrazedJD's Avatar
These are placeholders for when I can afford real good quality cubes (better lumen and light pattern), almost like a proof of concept ... lol. These Amazon cheap units have gone longer than a year and [knock on wood] no issues at all. I agree with the hood glare issue, the inner spots are off axis about 10 degrees while the outer wide beam are out about 30 degrees. Even the spots had a little hood glow when I had them face straight forward. I am happy with the setup, the front facing light bar makes up for the off angled ditch lights!
Here are the shots I promised and was way slow on getting around too!
Old 08-24-2020, 10:16 PM #9
BrunoKnoxville's Avatar
BrunoKnoxville BrunoKnoxville is offline
Real Name: Matt aka Bruno
BrunoKnoxville is on a distinguished road
Are you still able to open the hood with out issue or contact with the lights?
2006 4Runner Limited 4WD V8
2003 BMW Z4 3.0L
2004 4Runner Sport 4WD V6 *Sold* (to my girlfriend)
BrunoKnoxville is offline   Reply With QuoteReply With Quote
Old 08-24-2020, 10:39 PM #10
I've got the CBI ditch light brackets, too. Been pleased with them so far, though they're so simple there's not much to rave or complain about.
For lights, I went with Black Oak LED floods. I use them as ditch/sideshot lights. They're crazy bright and IP69K rated, so nearly completely water and dust proof.
New - 2 Inch Flood or Spot Pod Light: Black Oak LED Pro Series 2.0 - 20w or 40w CREE XM-L2 - BLACK OAK LED
Also, check out CH4X4 for switches... perfect fit, look OEM.
2003 BMW Z4 3.0L
Old 08-25-2020, 06:56 PM #11
KrazedJD's Avatar
KrazedJD's Avatar
Yes, there is about an inch of clearance between hood in upright position and Cube
date , ditch , light , lights , threads
Anytime Control of Mirror Puddle Lights: Use as Ditch Lights ElectroBoy 5th gen T4Rs 29 08-26-2021 08:38 AM
Ditch lights and rear lights JayToo 5th gen T4Rs 1 10-17-2019 12:32 PM
Ditch Lights MT Runner General Discussions 12 09-11-2019 09:49 AM
Ditch Lights: who has them that actually uses them? Dropzone General Discussions 8 03-16-2019 03:50 AM
CBI Ditch lights help??? TheWhighet 3rd gen T4Rs 7 05-03-2015 08:51 AM
