Old 08-14-2020, 07:55 PM #16
xtremewlr's Avatar
xtremewlr xtremewlr is offline
Real Name: Todd
xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold
xtremewlr's Avatar
Real Name: Todd
Originally Posted by Hunter61 View Post
Thanks, that helps a lot. Geez, After trying to sort through all the info here about shocks I was more confused than ever.
Now it's time to find the stuff I need to order.
You're welcome, glad I was able to assist.
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
xtremewlr is offline   Reply With QuoteReply With Quote
Old 08-14-2020, 08:59 PM #17
Az4runnin's Avatar
Az4runnin Az4runnin is offline
Az4runnin will become famous soon enough Az4runnin will become famous soon enough
Az4runnin's Avatar
Save all the Bolts from the X-Reas.
2003 V8 Limited 4x4 Black. JBA UCA's, TRD Pro Wheels. OEM LED Tails, 2012 FJ Springs F/R 5100's F/R 1.75 Cooper AT3 4S 265-70-17. Bye X Reas, Wet Okole Seat Covers Weathertech liners.
Az4runnin is offline   Reply With QuoteReply With Quote
Old 08-14-2020, 09:56 PM #18
The G-Man The G-Man is offline
Real Name: Gary
The G-Man is on a distinguished road
Real Name: Gary
While we are kinda on topic about collapsed xreas. How do you know the system is trash? Like if there’s an obvious leak, that’s easy. But without a smoking gun of a leak how can you tell it’s time to replace?
The G-Man is offline   Reply With QuoteReply With Quote
Old 08-14-2020, 10:15 PM #19
GupsT4R's Avatar
GupsT4R GupsT4R is offline
Real Name: Ken
GupsT4R will become famous soon enough
GupsT4R's Avatar
Real Name: Ken
Good Question im also in the same boat..tho i don't think i have that much sag when compared to other 4th gens without xreas. Ive pretty much made up my mind with the 5100's when i am ready to do suspension.
2008 SE 265/70/17 BFG. SpiderTrax 1.25" Wheel Spacers - Sold
2018 Blizzard Pearl Limited - Stock
GupsT4R is offline   Reply With QuoteReply With Quote
Old 08-14-2020, 10:26 PM #20
Hunter61 Hunter61 is offline
Real Name: Steven
Hunter61 will become famous soon enough
Real Name: Steven
3 things.
#1. the hydraulic lines are corroded to the point where they're about ready to let go anytime soon.
#2. The whole suspension seem "tired".
#3. Is something I forgot to mention earlier. 2 years ago I was driving through Chicago when the lower shock mounting bolt on the rear passenger shock came off and the bottom of the shock was rubbing on my tire. A couple weeks ago that same shock began making noises so I'm guessing the shock was damaged when it came loose and started making the noise just recently.
Hunter61 is offline   Reply With QuoteReply With Quote
Old 08-15-2020, 01:31 AM #21
montijo505's Avatar
montijo505's Avatar
Pretty sure this would fit your 4R. It's from a 5th gen. No association just saw the post on the classifieds. This is everything you would need. It'll be a very mild "lift" as the 5th gens are taller.
Someone correct me if I'm wrong on cross compatibility.
FS: 2016 TEP stock suspension, $100 Seal Beach, CA - Toyota 4Runner Forum - Largest 4Runner Forum
Sent from my SM-G986U using Tapatalk
Old 08-15-2020, 02:33 AM #22
xtremewlr's Avatar
Real Name: Todd
xtremewlr's Avatar
Real Name: Todd
Why?
See the before picture I posted. Seemed to drive fine but the UCAs were pointed up, they should be pointed down with a good, even stock suspension. If you have over 150k miles on the stock XREAS, I would seriously consider changing it.
Old 08-15-2020, 02:55 AM #23
Az4runnin's Avatar
Az4runnin's Avatar
Why?
They are similar to others on the vehicle and can be back ups if you loose some.
Old 08-15-2020, 10:32 AM #24
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
That dealer is a disgrace, to the point you might consider reporting them to Toyota corporate b/c they are tarnishing the company's reputation with "estimates" like that.
The link in my sig may be helpful as it has info, pics, and links from when I changed from worn out X-REAS to a TRD Offroad/FJ setup for $200 total. The ride is terrific on and off the pavement. Search "TRD suspension" in FB Marketplace for example to find sets people have taken off, just be sure they fit (mine is from a 2015 Tacoma and xtremewlr I think has it from a 2019). You might consider Spidertrax spacers too as they widen the stance to what (IMO at least) 4Runners should look like from the factory (more info & pics also linked in my sig).
My YouTube channel is also linked and you can see some of the places I've been on that suspension. A great example is the vid for the 2019 Kentucky Toyota Trail Ride.
I'm also happy to answer any questions as best I can. Good luck and let us know what you end up doing.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 08-15-2020, 02:04 PM #25
eleven14 eleven14 is offline
eleven14 has a spectacular aura about eleven14 has a spectacular aura about
When I pulled mine, the XREAS was still in great shape after 10 years and 110k miles but the springs were absolutely done, especially on the front which accentuated the existing limited squat. System pressure was fine and oil inside looked factory-fresh.
Would have kept XREAS if I could have swapped springs without touching the system but nuked it in favor of FJ springs and 5100s.
Also, OP, never, ever return to said dealer. This is one of the most gratuitous instances of shady dealer gouging I've seen. Inexcusable.
eleven14 is offline   Reply With QuoteReply With Quote
Old 08-15-2020, 09:10 PM #26
himeeto69 himeeto69 is offline
himeeto69 is on a distinguished road
I have a 2004 4runner V8 Sport and am checking out my options for replacing the Shocks/Struts.
I got a quote from my local Toyota dealer for $4,000 to replace the shocks and for $6,000 if I want to ditch the Xreas system and replace the Xreas with normal shocks instead. I asked why do normal shocks cost so much more and he said an adapter is needed in order to use normal shocks on my car.
Adapters? WTF is he talking about? What is so different about these shocks that other shocks need adapters to install?
I actually plan on doing the conversion myself but got curious about what the dealer would charge.
Ridiculous.
himeeto69 is offline   Reply With QuoteReply With Quote
Old 08-15-2020, 11:08 PM #27
Real Name: Steven
Real Name: Steven
For all I knew, all the dealerships charge that. I wish I had gotten a written estimate or I could report them.
Old 08-17-2020, 10:18 PM #28
MikeinNH67's Avatar
MikeinNH67's Avatar
The great thing with these is you can pick what you want, there's lots of options. A few weeks ago I was able to find some strut assembly take-offs from a Gen5. I got them on E-bay for a bit over $140ish including shipping and they look like they are brand new. Amazing how much better it handles bumps and the nose is up where it should be now. All I had to do was shave some metal off the lower mount point on the shock.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 08-18-2020, 04:41 PM #29
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Good question. I bought my '03 used about 6 years ago and it was xreas. When I went to pick it up from dealer the night I bought it they were just putting on a new front shock and told me they are really expensive. At the time I didn;t know what xreas even was!
I had no suspension complaints except I noticed a kind of "hollow" sound in the winter over some bumps. Anyway after joining this forum and reading about better suspension I decided to replace mine "just because".
By that time I knew I had xreas and was ready to disconnect it properly but as I started to remove it I broke one of the lines at shock loose just to see what would happen ... nothing ... the system had no gas pressure. I didn't even know it. So it may not be all that obvious when Xreas goes bad if trhere is no external oil leak.
By the way, the "hollow" sound in the winter is gone too!
adapters , dealer , normal , shocks , xreas
BRO that USER IS A BOT (have you noticed you're talking to a bot?) BrianSD_42 Off Topic 39 10-02-2019 04:50 AM
2way talking? mavrick1903 Off Topic 6 08-31-2018 02:48 AM
Just Talking About My 4runner Spencer 3rd gen T4Rs 7 01-26-2010 01:27 AM
Ford talking to Toyota??? RL Lemke 4th Gen T4Rs 4 12-28-2006 05:22 PM
Toyota Dealer Ad fees & Dealer Holdback Martin8 4th Gen T4Rs 11 04-06-2006 12:51 AM
