Old 08-16-2020, 10:42 PM #1
himeeto69 himeeto69 is offline
himeeto69 is on a distinguished road
Transmission, tires and towing questions
I just bought my 2005 SR5 4WD V8 4 Runner. I have a couple of questions guys. Does it have a transmission fluid dipstick? Can't seem to find one. Is there a link in the forums that has a video link or instructions on how to change the fluid and filter?
2nd question
I have heard that AWD's have to have all four tires changed if one is beyond repair and you cannot just replace one. Is that the case for these? Is it an all-time 4x4 or only kicks in when it needs to?
3rd question
Is there a certain way you have to tow one of these behind you? I know the AWD Honda Pilots have to be towed a certain way. Is it an issue or do you just throw it in neutral if someone is steering or it's on a dolly? Do all 4 wheels have to be on the ground?
himeeto69 is offline   Reply With QuoteReply With Quote
Old 08-18-2020, 10:49 PM #2
m85476585 m85476585 is offline
Real Name: Matt
m85476585 will become famous soon enough
Real Name: Matt
The 4WD system on the V8 models is engaged all the time. There's a Torsen limited slip center differential that prevents it from binding up on the road, and a button to lock it when you need extra traction off road. The V6 4Runners have a 2WD mode, but not the V8. But there's almost no downside to having it engaged all the time.
Never tow one of these on a dolly. The center differential can't be disengaged. I'm not sure about towing with all 4 wheels on the ground, but the owners manual should have a page about it.
After a certain year (maybe 2004?) they switched from a dipstick to a "sealed" transmission. There are threads about changing the fluid, and it's probably a good idea to do if you plan on using it heavily (towing, etc).
2007 V8 Limited 4WD
m85476585 is offline   Reply With QuoteReply With Quote
Old 08-26-2020, 10:35 PM #3
Thank you. I appreciate your answer. I'll check my manual.
Sent from my SM-G975U using Tapatalk
link , question , questions , tires , transmission
06 V8 4R transmission upgrades for towing? vanion2 4th Gen T4Rs 4 07-22-2017 11:27 AM
Towing - Aux Fan for Stock Transmission Cooler Mindflex 5th gen T4Rs 12 05-02-2017 05:25 PM
Large transmission leak after towing ukrunner 3rd gen T4Rs 24 05-18-2015 04:33 PM
Transmission Selection for Towing jed1177 4th Gen T4Rs 11 07-29-2014 09:05 PM
Towing a boat and transmission temp burelom 4th Gen T4Rs 12 06-18-2012 02:22 PM
