Old 08-16-2020, 10:46 PM #1
Monty87ls Monty87ls is offline
Monty87ls is on a distinguished road
Lean fix issues.
So I posted about this already but now I have discovered another issues.
So I put a 1 inch daystar lift on the left front wheel and besides the fact it put the front about an inch higher then the rear i was taking a look today and found this!
Seems the studs on the mount have been pushed out. It was not like that when I put it in. Anyone every seen this before?
Sent from my SM-N975U1 using Tapatalk
Monty87ls is offline   Reply With QuoteReply With Quote
Old 08-22-2020, 03:59 PM #2
Anyone with suggestions on how this happened and/or how to prevent it?
I have not taken apart yet to fix but I plan to today or tomorrow.
Old 08-23-2020, 07:34 AM #3
4RunnerAquasport's Avatar
4RunnerAquasport 4RunnerAquasport is offline
Real Name: Brett
4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of
Real Name: Brett
Im not super experienced with something like this, and hopefully someone else will jump in here. You could pull the shock and try to press those back in, then put a tack weld on each one to secure them. Threaded top bolts would be ideal, so upgrading to a Tacoma take off Bilstein shock or similar would be the safest way to go. Maybe that is a Bilstein judging by the color. I thought they were all threaded. Dont drive it too far obviously.
1988 DLX 22RE AUTO BLACK-"Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
4RunnerAquasport is offline   Reply With QuoteReply With Quote
Old 08-23-2020, 11:35 AM #4
Drove a bit because I had no choice and def get some clunking but they haven't moved so far. The shocks are Bilstein 4600 and the mount is a KYB. Those came out after I added the 1 inch daystar lift just on that side.
I screwed on the adapters as tight as I could get them then put it all back together. noticed this days later.
I'm not happy with how the lift made the entire front end go up to 37 and now the back is 36. I think I'm going to put the 1/4 spacer back in and be happy for the winter and maybe replace the shocks again with the 5100 next summer and see if I an even it out that way. Should have done that in the first place!
Old 08-23-2020, 11:37 AM #5
I'm going to put the 1/4 spacer back in place and try use my impact gun to get the studs back into place otherwise go get a new mount.
Old 08-23-2020, 12:53 PM #6
montijo505's Avatar
montijo505's Avatar
Don't know the price difference but I believe people swear by the Toyota top hats because of stuff like this. Might be worth it if it doesn't hold again.
Sent from my SM-G986U using Tapatalk
Old 08-23-2020, 03:50 PM #7
Its def something to consider. Ill get everything together for now and hopefully it stays together. Maybe if I do upgrade to the 5100s ill swap them with toyota ones just to be on the safe side.
Does anyone know can I use the 5100 to compensate for the lean without issues since they are adjustable?
Old 08-23-2020, 04:06 PM #8
montijo505's Avatar
montijo505's Avatar
Where is your lean? Front or back? I believe the difference in the 5100's is quite a bit between settings. They would probably handle differently also on different settings.
Old 08-24-2020, 12:36 AM #9
My lean was the front and back on the driver side.
I installed the front 1/4 spacer first then the 1.5 in the rear but I had to keep messing with it. I think I'm going to kist put the 1/4 back in the front and leave it be.
I am concerned about the rear spacer as the only way I could put it in was the way I found out is the procedure for the fj cruiser so the spacer went on top of the bump stop and not inbetween.
I wonder if I can get away with doubling up the 1/4 spacer?
I also may put some stiffer springs in the rear but idk which ones.
Old 08-24-2020, 06:05 AM #10
cwilliams563's Avatar
cwilliams563 cwilliams563 is offline
cwilliams563 has a spectacular aura about cwilliams563 has a spectacular aura about cwilliams563 has a spectacular aura about
Correct me if I’m wrong here, but if the nuts were tight enough I wouldn’t think the studs could be pushing back down out of the plate. If that is the case I would think tightening them enough would pull the studs back up. After all that’s what’s holding the whole coil assembly up tight from shifting up and down and clanking.
I also installed the KYB top hats on mine due to a lot of people recommending them. Mine came with a set of longer studs that I easily pressed out with a small vise and shorter factory ones just tapped back in.
Those bolts that come with the kyb top hats are excessively long and look like they needs to be tightened more basing by the top protrusion. If you want I can measure or count the threads on the top of mine for a reference to yours’. Here’s mine.
Lean fix issues.-302b3d9d-6b71-47eb-a6fa-48ac0dddfddc-jpg
My build thread https://www.toyota-4runner.org/4th-g...ml#post3520544
2008 Titanium Metallic 4WD 4Runner V6 SR5| Satoshi Grille mod|17x8 Level 8 MK6 wheels, 275/70/17" Falken Wildpeak tires| Front-Bilstein 5100's set at 0 with ToyTec branded Eibach silver springs and 1/2" ToyTec spacer driver side, 1/4" ToyTec spacer passenger|Front Diff. drop spacer kit|sway bar relocate kit| Rear-Fox 2.0Resi and ToyTec superflex black springs|Tyger Bull bar with LED's/Lund HX tube side steps
2021 Subaru Crosstrek Limited in Crystal White Pearl
cwilliams563 is offline   Reply With QuoteReply With Quote
Old 08-24-2020, 10:53 AM #11
I dont remembre if mine came with another set of studs or not. If they did I didn't change them. This all happened after I added the 1 inch spacer so I take it thats its something I did. I screwed that stud extenders on and I though I had them tight enough prior to install as they would not move anymore.
Gonna take it apart today or tomorrow and see what's going on.
Old 08-24-2020, 03:44 PM #12
You think that synthetic spacer could have Just compressed some causing the change in size resulting in the bolts pushing down? I guess it wouldn’t do me any good for me to measure my bolts due to me only having a 1/4” spacer lol.
Old 08-24-2020, 08:48 PM #13
I have no idea but all fixed now. Took out the 1 inch spacer and put back the 1/4 one. there was space between the stud extenders and the hat so thats probably what the issue is but the stud extenders wouldn't go down any further.
I have a pic ill post from my phone. But for now the studs are back in place and im sure will stay that way now. If I do end up replacing the struts again I will replace them with toyota.
Any recommendations on some new springs? I was just gonna do rear but maybe ill do all around? I read fj springs are a nice upgrade or maybe just gem 4runner but from a newer model?
Old 08-25-2020, 12:24 AM #14
Just the pic I mentioned. I think with some type of spacer between the top of the mount and the extender it would prevent that issue.
Old 08-28-2020, 07:47 PM #15
gaber6 gaber6 is offline
gaber6 has a spectacular aura about gaber6 has a spectacular aura about
Just looks like those extenders somehow weren't tight enough and once together pressed the main bolts out. Hopefully you got them pulled back in there. You'll hear it if you didn't
gaber6 is offline   Reply With QuoteReply With Quote
front , inch , issues , lean , put
3rd Gen Lean thirstyturtle 3rd gen T4Rs 30 11-11-2023 08:25 PM
Lean Spacer Issues??? The-Wood 4th Gen T4Rs 8 05-19-2020 04:27 PM
KDSS and spring selection-keep the lean or correct the lean? Catskill4RNR 5th gen T4Rs 22 11-10-2019 11:12 AM
TRD Pro Lean? rasber3140 5th gen T4Rs 19 11-30-2017 12:10 PM
3rd gen - fix your lean! RPS99SHO For Sale: T4R Items 2 03-11-2016 10:33 AM
