Old 08-24-2020, 10:03 AM #16
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
Originally Posted by Montego Murph View Post
I might suggest sooner... I did the 5th Gen upgrade just over a year ago and one piston already seized up.
Wow...that’s disappointing.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 08-24-2020, 10:39 AM #17
JuniorPigeon's Avatar
JuniorPigeon JuniorPigeon is offline
Real Name: Aaron
JuniorPigeon has a spectacular aura about JuniorPigeon has a spectacular aura about
Real Name: Aaron
I've heard the same about 5th gen swaps, doesn't seem worth it IMO.
What was your procedure using the Speed Bleeders? I definitely get the idea just want to make sure I have it right. I'm going to order some since I have some ATE fluid on the way.
2007 4Runner Limited V8
| 2.5 Fox 3" lift w/ remotes & DSC | Dobinson 677V rear | SPC UCAs | 1" BL | SCS F5 | 315/70 DuraTracs | Prinsu full rack | RLC rear bumper/swingout | C4 front bumper | Warn VR8-S | F55 fairlead/Flatlink-E | Rocksteady skids | ARB 2500 awning | Dometic CFX 40W | Partner Steel 22" stove | Adventure Index drawer/sleeping platform | ARB twin compressor | Odyssey 34R dual batteries | Blue Sea SI ACR/fuse panel/USB | Renogy 100W Eclipse | Baja Designs Squadron R & S2 | G5R retrofits | Doug Thorley headers/Y pipe | weBoost OTR |
JuniorPigeon is offline   Reply With QuoteReply With Quote
Old 08-24-2020, 10:54 AM #18
Montego Murph's Avatar
Montego Murph Montego Murph is offline
Montego Murph will become famous soon enough Montego Murph will become famous soon enough
Yeah, there doesn't seem to be much of a difference between 4th and 5th gen when it comes to the seizing issue. Oh well. For what it's worth, I bought Centrix calipers from Rock Auto.
Regarding speed bleeders, what size bleeder valve do we need? I wonder if they are the same size between 4th and 5th gen.
Montego Murph is offline   Reply With QuoteReply With Quote
Old 08-25-2020, 07:55 AM #19
Bluesky 07's Avatar
Bluesky 07's Avatar
[QUOTE=JuniorPigeon;3535995]I've heard the same about 5th gen swaps, doesn't seem worth it IMO.
I almost did a writeup - wish now that I had. I followed this post, which has directions from the FSM. The biggest thing is not to let the reservoir run dry and to watch for what is often a very subtle change in the color of the fluid in the tube coming off the bleeder. If your fluid is old, it will be obvious when the new stuff starts coming out but not so much if the current fluid is only mildly discolored.
Because of the corrosive & toxic nature of brake fluid, I strongly recommend 1) some kind of cover around the reservoir & over your fender to catch any drips/spills (puppy training mats are great, or rags, a sheet, etc.), & 2) a through-the-cap bottle with the tube secured. That way, less chance of a spill if it falls over. Beyond what’s shown in the linked pic, put a zip tie “collar” around the tube above & below the hole in the cap and slide them together so the tube is held in place.
Finally, I checked with two local places that take used motor oil & both said it was fine to pour the old fluid in with oil before taking it in for recycling.
@Montego Murph , the ordering info is available on the SpeedBleeders site. Their customer service was excellent btw.
Old 08-25-2020, 04:05 PM #20
Drcoffee's Avatar
Drcoffee Drcoffee is online now
Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice
Drcoffee's Avatar
I got tired of pumping the brakes and finally bought a Motive universal bleeder kit which just has a res cap and hose with chains to secure it. I setup an adapter to connect to my air compressor. After topping off the reservoir, installing the bleeder cap, I turnred the air compressor on and set it for 14#. The starting from the rears and working forward, opened one bleeder screw at a time. Watch the fluid flow until no bubbles remain. Oh so much easier.
You dont need the pump bottle, just the adapter kit. $27
1101 - Round Universal Adapter - Motive Products
Bleeding the master cylinder
How to Replace a Brake Master Cylinder in Your Car (Bleed Brakes) - YouTube
Brake Bleeding Issue!!!-870ff38a-563b-46dd-9f05-51362da3d0f3-jpg
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
Drcoffee is online now   Reply With QuoteReply With Quote
booster , brake , brakes , i’m , pump
Rear brake bleeding issue sdb999 Classic T4Rs 2 12-02-2019 06:47 PM
Rear brake lines exploded while bleeding brake fluid benztech82 4th Gen T4Rs 3 08-11-2017 08:16 PM
Brake bleeding after tundra brake upgrade Cadaverous 3rd gen T4Rs 25 08-11-2017 12:02 AM
brake bleeding issue robstibz 3rd gen T4Rs 7 08-18-2007 07:03 PM
Brake Bleeding - Small Issue bmay Maintenance/Detailing 5 07-25-2006 07:01 AM
