Thread Tools Rating: Thread Rating: 6 votes, 4.17 average. Display Modes
Old 09-16-2021, 01:00 PM #46
Tim Joss Tim Joss is offline
Tim Joss is on a distinguished road
Amazing resources. Thanks so much!
Tim Joss is offline   Reply With QuoteReply With Quote
Old 03-26-2022, 03:29 PM #47
Eagle_1_ Eagle_1_ is offline
Eagle_1_ is on a distinguished road
how many “replies” do i need
trying to start make a post asking for help with potential wiring problem related to headlights and rear lights. says i haven’t reached enough replies to be able to post. is there another way or place to ask my question?
Eagle_1_ is offline   Reply With QuoteReply With Quote
Old 03-26-2022, 04:33 PM #48
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
You need 10-15 comments in order to make your own posts. In order to build up to the 10-15 comments, you can help answer someone elses question in some of the recent threads that you know the answer, or comment on someone's build thread and compliment them on something you liked
You also may be able to search for a similar question that was already asked, and revitalize an older thread to build on the current information there.
y=mx+b is offline   Reply With QuoteReply With Quote
Old 06-01-2022, 06:41 PM #49
ajspencer42 ajspencer42 is offline
ajspencer42 is on a distinguished road
2009 SR5 4Runner Windshield Washer Replacement - Guidance Needed
I have a leaking washer fluid reservoir in my 09 4Runner. Can't find any video tutorials on how to replace... Curious if anyone has any links they can send me? I am about to order an original Toyota part for a replacement for about $80 but open to cheaper non-toyota alternatives if they are suitable. Welcome any thoughts and thank you in advance!
ajspencer42 is offline   Reply With QuoteReply With Quote
Old 06-01-2022, 06:43 PM #50
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
How/where is it leaking, does it have a hole in it or???
2004 Limited V8
Old 06-02-2022, 04:00 PM #51
I haven't gotten down into the engine compartment to see. I just see the fluid leaking onto the concrete. Figured the reservoir needed replacing?
Old 06-02-2022, 04:02 PM #52
I haven't gotten down into the engine compartment to see. I just see it leaking onto the concrete and figured the reservoir needed replacing?
Old 06-02-2022, 04:15 PM #53
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
You might check the tubing that carries the fluid for a loose connection at the reservoir before you replace the tank.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 06-02-2022, 06:23 PM #54
Hi-desertT4R's Avatar
Hi-desertT4R Hi-desertT4R is offline
Real Name: Matt
Hi-desertT4R is just really nice Hi-desertT4R is just really nice Hi-desertT4R is just really nice Hi-desertT4R is just really nice Hi-desertT4R is just really nice
Real Name: Matt
Here is a basic write up for repair of the A.D.D actuator.
No 4WD 4hi and center lock flashing
2007 Titanium SR5 4WD
Build thread: https://www.toyota-4runner.org/4th-g...ld-thread.html
Hi-desertT4R is offline   Reply With QuoteReply With Quote
Old 06-02-2022, 08:51 PM #55
Real Name: Skip
Real Name: Skip
You definitely as mentioned need to check all the tubing for cracks, being loose also check where the little pump is connected to the reservoir, it could be the sealing washer before buying a new reservoir, you of course could have a cracked reservoir in which case you can try to seal the crack with silicone, or maybe even better some Flex Seal, after all they advertise it to stop leaks such as a crack, holes , etc.
If all the above fails to solve the issue, then I would first try and find a used reservoir at a salvage yard, which would be WAY cheaper than a new OEM from Toyota.
2004 Limited V8
Old 06-10-2022, 11:17 AM #56
TheLander TheLander is offline
TheLander is on a distinguished road
Would some one please update the list of DIY drawer plans, is still listed as free, it is currently no longer available for free but for $40, a great value as it takes all the guessing out of DIY systems, just that the description of free is no longer so, thanks
TheLander is offline   Reply With QuoteReply With Quote
Old 06-10-2022, 01:23 PM #57
y=mx+b's Avatar
y=mx+b's Avatar
Thanks, just updated
Old 06-19-2022, 08:29 PM #58
Ethingnow Ethingnow is offline
Ethingnow is on a distinguished road
New here
Hello everyone I just bought a 2008 Toyota 4Runner v8 with only 28k miles on it. Any recommendations on what I need to do to it? As far as maintenance. Bought from Toyota dealership so oil change done. Any help would be greatly appreciated since new to all this
Ethingnow is offline   Reply With QuoteReply With Quote
Old 06-19-2022, 09:18 PM #59
y=mx+b's Avatar
y=mx+b's Avatar
Wow thats low mileage! I'd just drive and enjoy it for now. I might recommend checking out the tires. At 28k, mileage-wise they could be the original tires and may appear to have life left, but age-wise they'd be trashed. You can check for a 4 digit date code on the side of the tire. For example a tire with date code 4616 would be manufactured on the 46th week of 2016. Generally, tires 6+ years old will be no good anymore, regardless of tread depth
I see you're in Chicago. I'm in the Peoria area, so kind of close by. There are a few Toyota FB groups for the area if you're into that. I was trying to get some 4runners together this summer to do something- wheeling, meetup, etc but still a work in progress
Old 06-19-2022, 09:44 PM #60
y=mx+b's Avatar
y=mx+b's Avatar
Find me on Facebook Elie Mounsef
Try these:
GXOR-IL: GXOR - IL
Chicago 4th gen 4runners: Chicago 4th Gen 4runners
Chi Town Off-Road Toyotas: 登录 Facebook
Illinois Overlanders & Adventure: Illinois Overlanders & Adventure
4runner , auto , diy , replace , toyota
3rd Gen FAQ, Tutorials, & Documentation Reference v2 BrianSD_42 3rd gen T4Rs 120 09-19-2023 06:32 PM
Best 5th gen picture threads linked here renau001 5th gen T4Rs 7 05-31-2016 10:29 AM
Any tutorials on using the T4R 4WD system? el_kab0ng General Discussions 13 01-01-2016 03:19 PM
Light Mount Picture threads Stuck CAPS 4th Gen T4Rs 19 10-03-2013 10:12 AM
Any Writeups/Tutorials on How to Do a Power Steering Flush? 415runner562 4th Gen T4Rs 2 08-09-2012 09:47 AM
