06-20-2022, 05:44 AM
#61
Real Name: Skip
Real Name: Skip
Originally Posted by Ethingnow
Hello everyone I just bought a 2008 Toyota 4Runner v8 with only 28k miles on it. Any recommendations on what I need to do to it? As far as maintenance. Bought from Toyota dealership so oil change done. Any help would be greatly appreciated since new to all this
Sounds like you've found a great T4R, although it's has about 60,000 miles left before a regular timing belt replacement, i would recommend considering replacing the timing belt as soon as you can because of the age factor, as mentioned with the tires rubber deteriorates with age and at 14 years old I would say it's at the end of it's life, but I could be wrong, no way to know for sure, but if it breaks the engine is toast, you should be able to get it replaced for under $1000.
2004 Limited V8
06-20-2022, 11:43 PM
#62
This is a good point too, get that belt changed!
Didn't think about that because I am a wee V6 peasant lol
06-22-2022, 05:21 PM
#63
So I just got the Toyota service report and the good news is the timing belt was just replaced in may. When should I replace it next? Every 70,000 miles? Also a big question I have is they didn’t replace the water pump. Should I do that right away? Or it’s not a huge thing to be concerned about?
06-23-2022, 06:05 AM
#64
Real Name: Skip
Real Name: Skip
The timing belt should be replaced very 90,000 miles, normally I would recommend replacing the water pump anytime you replace the timing belt because it's about the same amount of work involved to replace it as it is to replace the timing belt, but with only 28,000 miles on the vehicle I wouldn't worry about the water pump as it doesn't deteriorate with age, if you ever notice the coolant constantly being low then I would have the water pump checked for leaking.
Congratulations on finding a great T4R!!
2004 Limited V8
07-18-2022, 10:51 AM
#65
Real Name: Russell (OB #9908)
@ y=mx+b
- can you kindly add this thread on cleaning the throttle body by
@ CJ3Flyr
to the 1GR section of the directory?
07-20-2022, 08:09 PM
#66
Originally Posted by Bluesky 07
Thanks, added!
07-29-2022, 11:45 AM
#67
Thanks
This is very usefull. Thanks
08-23-2022, 11:48 PM
#68
is the 1000$ price for the belt only or the belt as well as the waterpump job?
10-16-2022, 08:56 PM
#69
Real Name: Topher
Real Name: Topher
Just wanted to say, thank you! Your tutorials are great and thank you for taking the time to put all of these together for the community.
2009 Limited 4WD V6 Shadow Mica
ICON Stage 2 Kit SCS Ray10 17x8.5 BFG KO2 285/70r17
Rago Modular Storage Panels & Ditch Brackets * Prinsu Rack * Baja Designs Sqaudron Sports
KC Hilites Cyclones under hood * Blue Sea 12 Circuit Fuse Block * White LEDs Interior
Kenwood DMX906S Kenwood X802-5 Amp Infinity Front REF-6530cx & Rear REF-6532ex Pioneer TS-A2000LD2
10-30-2022, 11:33 PM
#70
01-16-2023, 12:35 AM
#71
Real Name: Tim
Real Name: Tim
Maybe someone here can help me out a bit. I was driving home and hit a deer in my 03 T4R it took out a chunk of the left of my front bumper to include to turn signal and fog light, headlights are fine and other fog light works fine too. But now none of my turn signals or hazard lights work. Can anyone give me a hint on what it might be?
01-16-2023, 06:26 AM
#72
Real Name: Skip
Real Name: Skip
Possibly have the turn signal wire on the collision side that is grounded out and blew a fuse.
2004 Limited V8
01-16-2023, 03:36 PM
#73
Real Name: Tim
Real Name: Tim
I figured that problem out this morning it ended up blowing the fuse for the signals so that’s no issue now the issue is finding a cheap replacement bumper like I’m thinking of making a steel tube bumper now
01-16-2023, 03:37 PM
#74
Real Name: Tim
Real Name: Tim
#75
Real Name: Tim
Real Name: Tim
I think I came out fairly lucky compared to lots of other people
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
