Thread Tools Rating: Thread Rating: 5 votes, 4.00 average. Display Modes
Old 06-20-2022, 05:44 AM #61
Real Name: Skip
AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of
Real Name: Skip
Originally Posted by Ethingnow View Post
Hello everyone I just bought a 2008 Toyota 4Runner v8 with only 28k miles on it. Any recommendations on what I need to do to it? As far as maintenance. Bought from Toyota dealership so oil change done. Any help would be greatly appreciated since new to all this
Sounds like you've found a great T4R, although it's has about 60,000 miles left before a regular timing belt replacement, i would recommend considering replacing the timing belt as soon as you can because of the age factor, as mentioned with the tires rubber deteriorates with age and at 14 years old I would say it's at the end of it's life, but I could be wrong, no way to know for sure, but if it breaks the engine is toast, you should be able to get it replaced for under $1000.
2004 Limited V8
Old 06-20-2022, 11:43 PM #62
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
This is a good point too, get that belt changed!
Didn't think about that because I am a wee V6 peasant lol
y=mx+b is offline   Reply With QuoteReply With Quote
Old 06-22-2022, 05:21 PM #63
Ethingnow Ethingnow is offline
Ethingnow is on a distinguished road
Thumbs up
So I just got the Toyota service report and the good news is the timing belt was just replaced in may. When should I replace it next? Every 70,000 miles? Also a big question I have is they didn’t replace the water pump. Should I do that right away? Or it’s not a huge thing to be concerned about?
Ethingnow is offline   Reply With QuoteReply With Quote
Old 06-23-2022, 06:05 AM #64
Real Name: Skip
Real Name: Skip
The timing belt should be replaced very 90,000 miles, normally I would recommend replacing the water pump anytime you replace the timing belt because it's about the same amount of work involved to replace it as it is to replace the timing belt, but with only 28,000 miles on the vehicle I wouldn't worry about the water pump as it doesn't deteriorate with age, if you ever notice the coolant constantly being low then I would have the water pump checked for leaking.
Congratulations on finding a great T4R!!
2004 Limited V8
Old 07-18-2022, 10:51 AM #65
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has much to be proud of Bluesky 07 has much to be proud of Bluesky 07 has much to be proud of Bluesky 07 has much to be proud of Bluesky 07 has much to be proud of Bluesky 07 has much to be proud of Bluesky 07 has much to be proud of Bluesky 07 has much to be proud of Bluesky 07 has much to be proud of
Bluesky 07's Avatar
@y=mx+b - can you kindly add this thread on cleaning the throttle body by @CJ3Flyr to the 1GR section of the directory?
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 07-20-2022, 08:09 PM #66
y=mx+b's Avatar
y=mx+b's Avatar
Thanks, added!
Old 07-29-2022, 11:45 AM #67
rresch rresch is offline
rresch is on a distinguished road
Thanks
This is very usefull. Thanks
rresch is offline   Reply With QuoteReply With Quote
Old 08-23-2022, 11:48 PM #68
kcirtap813 kcirtap813 is offline
kcirtap813 is on a distinguished road
is the 1000$ price for the belt only or the belt as well as the waterpump job?
kcirtap813 is offline   Reply With QuoteReply With Quote
Old 10-16-2022, 08:56 PM #69
bearisasquare's Avatar
bearisasquare bearisasquare is offline
Real Name: Topher
bearisasquare is on a distinguished road
Real Name: Topher
Just wanted to say, thank you! Your tutorials are great and thank you for taking the time to put all of these together for the community.
2009 Limited 4WD V6 Shadow Mica
ICON Stage 2 Kit SCS Ray10 17x8.5 BFG KO2 285/70r17
Rago Modular Storage Panels & Ditch Brackets * Prinsu Rack * Baja Designs Sqaudron Sports
KC Hilites Cyclones under hood * Blue Sea 12 Circuit Fuse Block * White LEDs Interior
Kenwood DMX906S Kenwood X802-5 Amp Infinity Front REF-6530cx & Rear REF-6532ex Pioneer TS-A2000LD2
bearisasquare is offline   Reply With QuoteReply With Quote
Old 10-30-2022, 11:33 PM #70
Jcmeadows82 Jcmeadows82 is offline
Jcmeadows82 will become famous soon enough
@y=mx+b
Guide: Starter, Knock sensor, SAIP replacement 2UZ-FE VVT-i
Jcmeadows82 is offline   Reply With QuoteReply With Quote
Old 01-16-2023, 12:35 AM #71
timbird1219's Avatar
timbird1219 timbird1219 is offline
Real Name: Tim
timbird1219 is on a distinguished road
Real Name: Tim
Maybe someone here can help me out a bit. I was driving home and hit a deer in my 03 T4R it took out a chunk of the left of my front bumper to include to turn signal and fog light, headlights are fine and other fog light works fine too. But now none of my turn signals or hazard lights work. Can anyone give me a hint on what it might be?
timbird1219 is offline   Reply With QuoteReply With Quote
Old 01-16-2023, 06:26 AM #72
Real Name: Skip
Real Name: Skip
Possibly have the turn signal wire on the collision side that is grounded out and blew a fuse.
2004 Limited V8
Old 01-16-2023, 03:36 PM #73
Real Name: Tim
Real Name: Tim
I figured that problem out this morning it ended up blowing the fuse for the signals so that’s no issue now the issue is finding a cheap replacement bumper like I’m thinking of making a steel tube bumper now
Old 01-16-2023, 03:37 PM #74
Real Name: Tim
Real Name: Tim
Old 01-16-2023, 03:37 PM #75
Real Name: Tim
Real Name: Tim
I think I came out fairly lucky compared to lots of other people
4runner , auto , diy , replace , toyota
3rd Gen FAQ, Tutorials, & Documentation Reference v2 BrianSD_42 3rd gen T4Rs 117 10-30-2022 11:17 PM
Best 5th gen picture threads linked here renau001 5th gen T4Rs 7 05-31-2016 10:29 AM
Any tutorials on using the T4R 4WD system? el_kab0ng General Discussions 13 01-01-2016 03:19 PM
Light Mount Picture threads Stuck CAPS 4th Gen T4Rs 19 10-03-2013 10:12 AM
Any Writeups/Tutorials on How to Do a Power Steering Flush? 415runner562 4th Gen T4Rs 2 08-09-2012 09:47 AM
