Thread Tools Rating: Thread Rating: 7 votes, 4.29 average. Display Modes
Old 01-17-2023, 12:35 PM #76
zguy1's Avatar
zguy1 zguy1 is offline
zguy1 has a spectacular aura about zguy1 has a spectacular aura about
zguy1's Avatar
@y=mx+b - I recently replaced my head gaskets and put together a summary of the problem observed, diagnosing it, procedures used, tools, parts and helpful tips. It is not exactly a step by step, but it is my attempt to gather all of the best information I could find and put it in one place. I think it compliments the instructions written by forum member, nossliw. Please feel free to add it if you think it would be helpful.
The thread is V6 engine replacement vs head gasket repair ??? and the summary is at Post 135.
zguy1 is offline   Reply With QuoteReply With Quote
Old 01-17-2023, 02:11 PM #77
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
Thanks for putting this together! Should be added in there now
y=mx+b is offline   Reply With QuoteReply With Quote
Old 01-28-2023, 08:54 AM #78
RayRunner RayRunner is offline
RayRunner is on a distinguished road
Wiring information: Toyota factory wiring manual
This has been very helpful in troubleshooting electrical issue on my 2005 4Runner:
"Toyota Electrical Wiring Diagram 2005 Model"
Pub. No. EWD615U
This is from Toyota Motor Corp and is well worth the price. Add a good digital multi meter (Fluke is my choice) and full set of test leads and you are on your way.
RayRunner is offline   Reply With QuoteReply With Quote
Old 01-28-2023, 09:02 AM #79
Electrical troubleshooting done correctly
For some excellent information on logical automotive electrical troubleshooting using diagnostic tools and wiring diagrams have a look at
ADVANCED LEVEL AUTO - YouTube
This guy (Erik) is an excellent teacher, and a real professional.
Old 01-28-2023, 09:13 AM #80
OBD-II introductory information
You may find this information useful in getting to know your new OBD-II scan tool: I am a DIY guy who just invested in an Innova 5160rs tool and "Haynes Techbook OBD-II & Electronic Engine Management Systems", their publication #1026.
The Innova 5160rs "CarScan Scan Tool Owner's Manual Repair Solutions 2" is available for download (I printed mine) and is thorough at 122 pages. The index in the front of the manual is well done.
Old 03-12-2023, 06:12 PM #81
pltommyo pltommyo is offline
pltommyo is on a distinguished road
I didn't find anything on replacing the front wheel seal (backside on knuckle, part 90316A0001). Mine keep blowing out, then crud destroys the ABS sensors. I just replaced the seals, had everything nice and clean (including CV shaft where it will interface to seal), seal went on flat and tight to back of knuckle, slid CV through and into splines on bearing, torqued to spec, drove about 20 miles and saw the ABS sensor was still warning, so figured it was bad. Took it out (usual method - it snaps in half, then have to drive out from the knuckle hole and clean up mess inside) and saw that the brand new Toyota wheel seal had failed. The spring loop and part of the rubber seal were laying inside the knuckle. Took it back out, put another new one in, and have it reassembled now. At least I have no ABS warnings, but this is the third set of ABS sensors and at least the 4th or 5th set of these wheel seals I have had to replace. Does anyone have any idea what we are doing wrong, what is possibly causing this, or any suggestions? This is really frustrating and expensive!
pltommyo is offline   Reply With QuoteReply With Quote
Old 06-24-2023, 10:28 PM #82
Ur7x2fa8 Ur7x2fa8 is offline
Ur7x2fa8 is on a distinguished road
Keep Air Ride and Delete XREAS?
Does anyone have a tutorial on how to replace the XREAS with normal shocks/struts BUT keep the Rear Air Ride system?
My 2003 V8 Limited has both and the Rear Air Ride system works great and is awesome for heavy loads and towing... But the XREAS system is starting to leak and I would rather switch to more cost effective shocks.
Looking for a aftermarket option that has the compression range needed to work with the Air System.
Can anyone recommend a rear shock for stock ride height?
Ur7x2fa8 is offline   Reply With QuoteReply With Quote
Old 06-26-2023, 04:03 AM #83
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
Can’t help with the Air Ride thing but the suspension link in my sig has info on X-REAS removal. Within the post are links to the FSM files on X-REAS removal and they may have the Air Ride piece.
For stock ride height, many people go with KYB and the Bilstein 4600 is also designed for that. FWIW, I have experience with the 4600s and found it a great shock but of course ride is a subjective thing.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 06-26-2023, 02:05 PM #84
Do we know if the range of travel for the KYB shocks (or the 4600s) are compatible with + 1.6" and -0.8" rear "lift" range you get with the Air ride system?
Old 04-20-2024, 12:22 PM #85
Richmasse Richmasse is offline
Richmasse is on a distinguished road
Thanks
Richmasse is offline   Reply With QuoteReply With Quote
Old 04-20-2024, 12:27 PM #86
Thanks for this
Old 04-23-2024, 06:06 PM #87
Mattmaine1991 Mattmaine1991 is offline
Mattmaine1991 is on a distinguished road
Thanks for the tips
Mattmaine1991 is offline   Reply With QuoteReply With Quote
Old 06-02-2024, 06:41 PM #88
P51Driver P51Driver is offline
P51Driver is on a distinguished road
Looking for the correct procedure for replacing my exterior window weatherstripping on all four doors as well as rear liftgate. Purchased them from my dealership & watched a couple videos then looked into the forum threads here. Didn’t see a good description for the proper removal/installation. TIA 😎
P51Driver is offline   Reply With QuoteReply With Quote
Old 06-02-2024, 08:14 PM #89
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
It's a very easy job, should take 5 to 10 minutes per door if that long.
On the front doors there a "Torx" screw on the inside rear of the door, roll down the window, remove the screw, then using a screwdriver with tape on the blade tip pry up the old weatherstrip/belt until you can pull it with your hand, don't worry if it starts coming apart, just get it all off, as you get it most of the way out pull back on it to get it out from under the mirror, reverse the procedure to install it. i.e. push it under the mirror and then down, reinsert the screw.
The back doors are very similar except the Torx screw is at the front inside of the door, and you have to slide the weatherstripping out from under the triangle window portion.
The rear hatch is easier, no screws, just roll down the window and pry/pull the old one off and then push the new one in place.
Here's search results that may be helpful, only check out the ones for 4th Gens.
https://www.toyota-4runner.org/gsear...123j16999129j2
2004 Limited V8
Old 06-03-2024, 11:53 PM #90
Thanks for the good info on the removal and installation. That seems pretty much what I thought would be the correct approach. Very much appreciate the response.
4runner , auto , diy , replace , toyota
3rd Gen FAQ, Tutorials, & Documentation Reference v2 BrianSD_42 3rd gen T4Rs 120 09-19-2023 06:32 PM
Best 5th gen picture threads linked here renau001 5th gen T4Rs 7 05-31-2016 10:29 AM
Any tutorials on using the T4R 4WD system? el_kab0ng General Discussions 13 01-01-2016 03:19 PM
Light Mount Picture threads Stuck CAPS 4th Gen T4Rs 19 10-03-2013 10:12 AM
Any Writeups/Tutorials on How to Do a Power Steering Flush? 415runner562 4th Gen T4Rs 2 08-09-2012 09:47 AM
