Old 08-27-2020, 03:48 PM #1
Nuke's Avatar
Nuke Nuke is offline
Nuke will become famous soon enough
Nuke's Avatar
Check engine light, Traction control light, VSC blinking
Check engine light on. Traction control symbol on. VSC OFF blinking.
I had this about 2 years ago on my 2008 but vaguely recall how I resolved it. I think I lubed the fuel cap o-ring but I don't recall how I cleared the lights. I'm working off my tablet (my laptop is fried and I'm currently unemployed) which isn't letting me search. Any help, clarifications, etc is much appreciated.
9/1/20: ISSUE RESOLVED
Going on past experience (aka assumption), i removed and cleaned the fuel cap o-ring as well as the fuel tank filler tube's mating surface. After roughly 4 engine cycles, the idiot lights are off. I plan on lubing the o-ring when I get a chance (aka I was lazy).
Rick
'90 T4R - sold at 205,000 miles
'00 T4R - sold at 152,000 miles
'08 Sport - 178,000 miles & still going strong
'19 ORP - just over 6,000 mi. (garage queen, like my '07 Mustang)
Nuke is offline   Reply With QuoteReply With Quote
Old 08-27-2020, 04:16 PM #2
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
CEL means scan codes, could be anything. VSC and TRAC lights come on with the CEL since something is not right, the computer knows it can't trust the other inputs. Any auto parts store should be able to scan the codes for free
To clear the lights, erase code with code reader or unplug negative battery terminal for 30 minutes or so.
y=mx+b is offline   Reply With QuoteReply With Quote
Old 07-17-2023, 02:07 PM #3
SAJ4r2008 SAJ4r2008 is offline
SAJ4r2008 is on a distinguished road
Thanks for this detailed post. My check engine light came on at same time as traction control light and the VSC was blinking. By googling "2008 4Runner engine light on, traction control light on and flashing VSC", I came right to this thread.
Read through, tried wiping down the gas cap o-ring and the sealing surface and that didn't clear the code. The gas cap looked new as it was pretty clean but the area inside the door was all very dirty. Huh?
Next put some all purpose grease that I use to grease my table saw trunnion on the o-ring and took off the negative terminal to clear the code. Reattached and started up and it cleared the code. Hot damn.
The o-ring mating surface on the tube looks sketchy (disfigured? corroded?) but there is a small bead of grease around the circumfluence. This grease shouldn't be a problem should it?
I'll try hard to not get any of the grease down the tube or on the gas pump nozzle.
Thanks!
I'll update should I have more problems.
SAJ4r2008 is offline   Reply With QuoteReply With Quote
Old 07-17-2023, 03:34 PM #4
TeryT's Avatar
TeryT TeryT is offline
TeryT is on a distinguished road
TeryT's Avatar
Thanks!
You should read the codes it's throwing. (BTW - Last time those lights came on for me, I had to replace catalytic converters. Hope it's not something expensive like that)
2003 V8 4x4 Sport 4Runner TRUCK OF THE MONTH SEPT. 06 - still tows a 25' ultralite Rockwood 2502 travel trailer all over creation!
MODS: GlowShift tranny temp gauge; Hayden 526 tranny cooler/fan combo; Hopkins Insight brake controller; Bilstein 5100 shocks
Hensley Arrow hitching system - quite simply the best for zero sway towing!
TeryT is offline   Reply With QuoteReply With Quote
Old 07-26-2023, 09:01 PM #5
TTucker TTucker is offline
TTucker is on a distinguished road
Dealing with this right now. Took it to the dealer today and they said A/F sensor, bank 1 sensor 1, and bank 2 sensor 1 were bad. No EVAP codes which is what I expected to see.
TTucker is offline   Reply With QuoteReply With Quote
laptop , light , recall , tablet , working
Check engine, traction control, and VSC light on. BCKGUY 4th Gen T4Rs 5 01-31-2023 07:33 PM
2008 4Runner, VSC light flashing, traction control and check engine light solid Swelden1 4th Gen T4Rs 6 09-01-2022 09:08 PM
Check engine along with traction control light came on, no idea why Nmac65 4th Gen T4Rs 11 03-11-2019 11:10 AM
VSC Off, Check Engine light and the traction control squiggly thing again... Nuke 4th Gen T4Rs 22 05-30-2016 09:39 PM
vsc, vsc off, traction control light, check engine lights Dunk50 General Discussions 1 10-26-2011 06:22 PM
