Old 08-28-2020, 06:39 PM #1
jmriott jmriott is offline
jmriott is on a distinguished road
2006 V8 Sport XREAS to Bilstein 4600 Conversion
Completed my conversion Wednesday.
I am super happy w/ the results. No more shimmy at low & hi speeds over mild bumps, no lane jumping on curves w/ road joints, rails the corners & very little body roll. Super smooth on hi speed straights.
I highly recommend the swaybar bushing & Bilstein route.
I took a stepwise approach to the conversion as I was unsure if I should replace the XREAS system instead of going Bilstein. In addition I was unsure if the XREAS shock were still in good shape. I had read a lot of comments about the 4600's being too harsh......not the case at all. They are firm but It rides really well over bumps of all types.
Car has 110k miles w/ mild offroad use in Colorado & Utah. No undercarriage rust. None of the shocks were leaking....but they were shot!
1st - Replaced the swaybar bushings last year. Low speed rear & front clunk was eliminated, but other symptoms remained.
The bushings are different diameters for the different 4th Gen models, so measure carefully before you purchase them. I put a lot of effort getting to the V8 Sport bushings.
Amazon.com: Energy Suspension 85140G Sway Bar Bushing: Automotive
Amazon.com: Whiteline W21105G Sway Bar Mount Bushing, Black: Automotive
2nd - 4 new Michelin Defender LTX M/S 265/65 R17 w/ new sensors
3rd - 4 new takeoff 5th Gen Toyota SR5 rims 17X7 w/+15mm offset
The original rims were Toyota 4th Gen 17X7.5 w/ +30mm offset These came original on the car.
4th - 4 new Bilstein 4600 shocks w/ 2 KYB top mounts for the front struts.
I disconnected each shock at the quick disconnect joint. I estimate a drop of fluid came out of each joint for those interested. I sealed off all 4 joints & left the central part of the XREAS system in place. I zip tied the front tubing to the frame on each side to eliminate any rattles. The rear are fixed & do not require zip ties.
#1 Shocks and Struts Superstore - Shockwarehouse.com
Total costs include a new spare tire/sensors/certificates from Discount Tire
Bushings 36.00
Tires 1500.00
Shocks & Mounts 424.00
Rims 300.00
2260.00
2006 V8 Sport     XREAS to Bilstein 4600 Conversion-img_7056-jpg  2006 V8 Sport     XREAS to Bilstein 4600 Conversion-img_7057-jpg  2006 V8 Sport     XREAS to Bilstein 4600 Conversion-img_7058-jpg
jmriott is offline   Reply With QuoteReply With Quote
Old 08-28-2020, 07:47 PM #2
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Yep, did same suspension plus FJ springs on my '03 V8 and Michelins, very happy.
Old 08-29-2020, 11:08 PM #3
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
i would of swapped out the springs too, but good work, go thing i didnt keep my stock springs when i did the bilstiens swap, looks a little low and worn.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
bilstein , bushings , front , shocks , xreas
Bilstein 4600 cangler 4th Gen T4Rs 14 02-13-2024 10:18 AM
Bilstein 4600's - lift? MetalT4R 3rd gen T4Rs 10 04-17-2017 02:56 PM
4600 Bilsteins on XREAS suspen Runner Bandido 4th Gen T4Rs 13 05-19-2015 11:50 AM
Bilstein 4600 4wd vs. 2wd? 2k1 3rd gen T4Rs 3 02-19-2014 10:28 PM
