Old 08-28-2020, 11:42 PM #1
kc15842 kc15842 is offline
Real Name: Kevin
kc15842 will become famous soon enough
Real Name: Kevin
No transmission after engine swap
I rebuilt the engine so it was down for about 6 months. The automatic trans worked fine prior to and the install went pretty easy. The torque convertor seemed correct and bolted up fine. The motor runs fine, no noises. The gear indicator shows the proper gear and I believe all connections are solid.
I have nothing, no forward or reverse. No funny sounds, nothing.
The FSM has a note about resetting the ECU after a trans or motor swap. I have the same engine it was just disconnected for awhile.
Anyone ever deal with something like this?
Its an 08, 4.0
1987 22R-E, SR5. 5 Speed, 31's BFG A/T, stock wheels. 4.56 Gears, Rear Detroit locker Front True Track. 1.5" BJ Spacers & Extended Shackles in the rear.
1992 3.0, SR5. 5 Speed. 31's BFG M/T, stock wheels. 4.30 Gears-NON ADD- manual hubs, Elocker, 1.5" BJ Spacers, Moog springs w/ spacers. Sold
kc15842 is offline   Reply With QuoteReply With Quote
Old 08-29-2020, 02:57 AM #2
royal T4R royal T4R is offline
royal T4R will become famous soon enough royal T4R will become famous soon enough
I may not be much help here as im still new to the runners but ive pulled apart other cars in the past.
Same motor and same trans so you know everything works. You said that the gear indicator shows the proper gear.
If you shift it to neutral are you able to push the rig at all or is it stuck in park with the entire trans locked up? I know it sounds time consuming but id make sure that all pigtails are in the correct location, id follow the harness to make sure nothing is kinked and id reset all ECUs in the vehicle.
Good luck and hopefully someone with more knowledge will chime in.
royal T4R is offline   Reply With QuoteReply With Quote
Old 08-29-2020, 09:28 AM #3
Real Name: Kevin
Real Name: Kevin
The truck has all 4 wheels off the ground. I did check that park was park and the drive shaft are not locked out of park. Your plan is good, I'll check all connections here shortly.
Old 08-29-2020, 12:44 PM #4
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
please keep us posted!
Old 08-29-2020, 02:10 PM #5
Real Name: Kevin
Real Name: Kevin
Well, during the swap I had drained the trans oil and cleaned the screen. Drained it early on and then once I pulled the pan which was maybe 3 months later and once again more oil. When I filled it I think I put in about 3.5 qts.
So today I ran it and got the trans fluid up to 115 and removed the over flow plug, Nothing.
I added about 2 qts and it drips from the overflow tube. Went thru the gears and funny thing, RPM's dropped and I now have fwd and reverse.
I'll go thru the level check again tomorrow and see how things go,
I have the rear drive shaft out replacing the center bearing so Its front wheels only for the first test drive tomorrow.
Thanks for the suggestions. Its the little things that get you.
engine , fine , gear , motor , trans
Transmission fluid magically overfilled after engine swap? gamefreakgc 3rd gen T4Rs 17 01-17-2019 08:40 PM
Transmission Swap or Differential Swap: Two hurting 3rd Gen T4R SteelRunner 3rd gen T4Rs 12 09-10-2014 11:00 PM
engine/transmission rebuild vs swap opiatet1 Classic T4Rs 2 02-23-2014 11:31 AM
my 92 budget build. engine swap and front end swap? bhenry92 Classic T4Rs 4 08-06-2013 05:42 PM
94 4runners-engine swap, or front end swap? pats for sale as well jimmy94 Classic T4Rs 7 05-16-2011 09:48 PM
