Old 08-30-2020, 09:54 PM #1
sloscheider sloscheider is offline
sloscheider is on a distinguished road
Is there power to the 7-way?
I’m curious if the 4Runner comes factory wired to provide power to the trailer and, if so, is it capable of keeping a battery charged? If I have a battery on my trailer do I need to install an isolator to prevent current from flowing back to the 4Runner?
sloscheider is offline   Reply With QuoteReply With Quote
Old 08-30-2020, 10:50 PM #2
RonJR RonJR is offline
Real Name: Ron
RonJR has a spectacular aura about RonJR has a spectacular aura about RonJR has a spectacular aura about
Real Name: Ron
If the 4runner has the factory tow package (likely if it has the 7 wire connector installed), it has a battery charging wire in the connector. This wire is switched through a 30 amp relay and a 30 amp circuit breaker in the engine fuse/relay box, and is only connected when the ignition is ON. It works well; the trailer is isolated from the vehicle battery when the engine is stopped, and connected for charging when the engine is running.
So basically, everything you need is already in place. Just connect the charging wire to your trailer battery in the trailer harness, and you're good to go.
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
RonJR is offline   Reply With QuoteReply With Quote
Old 09-02-2020, 11:14 PM #3
That's fantastic! Thanks for the information
Old 09-03-2020, 08:35 AM #4
Burt Burt is offline
Burt is on a distinguished road
Yep, the 4Runner is equipped for charging towed camper/boat. Be aware to not connect or disconnect with engine running. Could result in blown fuse. I learned this from experience.
Burt
2008 SR5 V6 4WD
1984 1/2 GT350 Mustang
2019 F250 SuperDuty
Burt is offline   Reply With QuoteReply With Quote
4runner , battery , current , power , trailer
power outlets not producing full charging power outgolfin0 4th Gen T4Rs 9 10-14-2013 12:39 PM
Rear power outlet (cigarette) constant power? Sloan694 5th gen T4Rs 3 06-27-2012 08:41 AM
Added power ports to 1992, constant power surfcitylocal Classic T4Rs 4 07-21-2010 10:44 AM
Power windows, power door locks, sunroof, rear window ALL DEAD JAKE_S 3rd gen T4Rs 2 03-18-2009 12:30 PM
