Old 08-31-2020, 03:22 PM #1
SeanWN86 SeanWN86 is offline
SeanWN86 is on a distinguished road
OEM vs Poly pivot/rotation ?
So with factory bushings the rubber slops around, but also takes the pivoting/rotation action.
When you replace the rubber with a poly bushing. The slop goes. But where's the pivot go? Does the bushing slide with the arm and spin on the center sleeve, or vise versa?
SeanWN86 is offline   Reply With QuoteReply With Quote
Old 08-31-2020, 03:39 PM #2
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
The polyurethane bushing is supposed to rotate around a tube inside the bushing. Little grooves in the bushing hold the grease to lubricate the rotation. They have to be disassembled and greased every so often, Whiteline told me 10,000-15,000 miles when I talked with them on the phone, if I remember correctly.
I haven't had a single creaking or annoy noise since switching to poly bushings. Some people have reported increased noise when switching to poly, but I think that is from improper lubrication and fitment.
Shameless plug to my Whiteline Bushing Install Writeup: Whiteline Lower Control Arm Bushing Tutorial (120+ Pictures)
y=mx+b is offline   Reply With QuoteReply With Quote
Old 08-31-2020, 04:18 PM #3
montijo505's Avatar
montijo505's Avatar
I got no noise either, mine is actually quieter now that my lower control arms aren't clunking. Steering is tons better also.
The bonded design fails when we lift the vehicle as it is constantly at max articulation, so they rip/tear.
Sent from my SM-G986U using Tapatalk
arm , bushing , oem , poly , rubber
help me identify/find these parking brake pivot bolts and parts s20004runner 3rd gen T4Rs 0 02-14-2016 01:24 AM
Changing belts. Alternator will not pivot to get belt off! (2.7 4 cyl) 4orRunner Maintenance/Detailing 0 07-18-2015 02:51 PM
Question about Tearing Clutch Pedal Pivot Mounting Plate maximus8633 Classic T4Rs 9 09-25-2010 01:22 AM
Tearing Clutch Pedal Pivot Mounting Plate Tucson T4R Classic T4Rs 3 02-25-2008 06:08 PM
Tearing Clutch Pedal Pivot Mounting Plate Tucson T4R Classic T4Rs 0 02-25-2008 05:37 PM
