Old 09-01-2020, 01:33 AM #1
PhantomF4E PhantomF4E is offline
PhantomF4E is on a distinguished road
License Plate Lighting Questions
So I've decided to finally replace the license plate bulbs with LEDs seeing as I've done all of the interior lights (to include the glove box light with many thanks to those on the forum that helped me with that information) with new LEDs.
That said, I noticed the plastic lens covers look pretty faded. Can you replace just those or are they told as a whole unit? Anyone done this particular mod in which you had to replace more than just the bulb itself? Thanks for any information.
PhantomF4E is offline   Reply With QuoteReply With Quote
Old 09-01-2020, 04:57 AM #2
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
Go to an online Toyota dealer parts site (McGeorge Toyota is a good one) & look at the diagram for that area. You’ll see what parts can be ordered individually. Personally, mine are cloudy too but the LEDs are so bright that I can’t imagine a clearer lens making a difference worth the trouble of changing them.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 09-01-2020, 05:50 AM #3
cwilliams563's Avatar
cwilliams563 cwilliams563 is offline
cwilliams563 has a spectacular aura about cwilliams563 has a spectacular aura about cwilliams563 has a spectacular aura about
Mine looked pretty cloudy and was kind of thinking the same thing initially. Once I removed mine they cleaned up pretty well and took a lot of the crud off, just a little opaque now and no biggie. The LED’s do just fine shining through there. I’d say try it first after the swap with your originals. If not happy then maybe order them.
The problem I ran into on mine were the screws for them were so rusted, the Phillips head portion basically just crumbled and was heck to get them out. I do need to get new screws for them though. After cleaning and lubing them I was able to get them back in for the interim. Not looking forward to that again lol.
My build thread https://www.toyota-4runner.org/4th-g...ml#post3520544
2008 Titanium Metallic 4WD 4Runner V6 SR5| Satoshi Grille mod|17x8 Level 8 MK6 wheels, 275/70/17" Falken Wildpeak tires| Front-Bilstein 5100's set at 0 with ToyTec branded Eibach silver springs and 1/2" ToyTec spacer driver side, 1/4" ToyTec spacer passenger|Front Diff. drop spacer kit|sway bar relocate kit| Rear-Fox 2.0Resi and ToyTec superflex black springs|Tyger Bull bar with LED's/Lund HX tube side steps
2021 Subaru Crosstrek Limited in Crystal White Pearl
cwilliams563 is offline   Reply With QuoteReply With Quote
Old 09-01-2020, 07:20 AM #4
Zero0575's Avatar
Zero0575 Zero0575 is offline
Real Name: Casey
Zero0575 will become famous soon enough Zero0575 will become famous soon enough
Zero0575's Avatar
Real Name: Casey
+1 exactly for me. Lenses cleaned up well, but the screws were so bad I was surprised I was able to get them out. Lenses cleaned and screws replaced with stainless steel!
2007 Limited V8 | 275/70/18 Falken Wildpeak AT3W | Spidertrax | 4xInnovations Weld On Sliders | Victory 4x4 Blitz Front Bumper | RCI Skids | TNF Rear Bumper | Smittybuilt Winch | KOYORAD Aluminum Radiator |OME 886 Front/Toytec Superflex HD Rear and OME Shocks/Struts | JBA High Caster UCA | Rebuilt LCA with Superpro bushings + Moog BJ | HCF Delete | Doug Thorley Shorty Headers | Magnaflow HFC | Gibson Catback | Rear Diff Breather Extension | 20" Spot/Flood | 9" Spots | DD SS3 Yellow Fogs | Amber Grill Lights | Fog Lights Anytime Mod
Zero0575 is offline   Reply With QuoteReply With Quote
Old 09-01-2020, 07:46 AM #5
Terminator03 Terminator03 is offline
Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough
Yep, screws seem to be the big issue for the lens removal! I’ve been wanting to change mine since I bought the truck, but haven’t messed with them yet because the screws were so rusted they immediately stripped out. I’ll probably end up cutting a slot in them with a small cutoff wheel for removal, but that will likely trash the lenses anyway requiring their replacement as well. One of those things I probably won’t get to until a bulb burns out or something.
2004 black SR5 V8 4WD with TRD dual exhaust, Thorley headers, AFE dry filter, Sprint Booster, Icon 2.0 rear shocks, OME 895E springs, Fuel wheels with 265/70/17 Wildpeak AT3W tires, more to come...
Terminator03 is offline   Reply With QuoteReply With Quote
Old 09-01-2020, 08:31 AM #6
J-Roc's Avatar
J-Roc J-Roc is offline
Real Name: J
J-Roc will become famous soon enough J-Roc will become famous soon enough
J-Roc's Avatar
Real Name: J
Had the same issue when I did mine. Eventually got the rusted screws out and the lenses were pretty bad.
Ordered two new ones through the dealer and they came with new rubber gaskets as well.
2013 Blizzard Pearl Ltd/14’+Tail Light Swap/Anytime Backup Cam/275-55-20 Wildpeaks/TailAsTurn/Triton V3 Switchback Fronts/5100’s/1” Eibach Rear Coils/CaliRaised Ditch Pods&Brackets
Sold-2005 V8 Dorado Gold Pearl Ltd
Retired-1996 Evergreen Pearl Ltd
J-Roc is offline   Reply With QuoteReply With Quote
Old 09-01-2020, 12:01 PM #7
Bluesky 07's Avatar
Bluesky 07's Avatar
+1 on cleaning your lenses before ordering new ones. I actually came back to amend my post and say that only to find others had covered it. Good advice.
Old 09-01-2020, 05:52 PM #8
I appreciate all of the help and advice! I went and bought some LEDs from AutoZone and just took the lenses off to clean. They cleaned up surprisingly well! I think the lights are going to look much nicer in general and so on to my next mini-project.
Going to get a nice license plate frame and some new screws to hold the plate on. The two that are there now are terribly rusted. Probably seems like a silly question, but does anyone have particular screws/bolts they use for their plates? Unfortunately living in NM, it's not unheard of to have your plate taken, so was wondering if there might be any thoughts or recommendations on that.
Anyways thanks again to all who commented!
Old 09-05-2020, 11:44 AM #9
ATOWN4R ATOWN4R is offline
ATOWN4R is on a distinguished road
I actually had to tap mine out because the years were so rusted. A 5 min job turned into over an hour. But, they’re replaced and all good now. LED’s do a great job.
Did you guys do your reverse? So bright backing up after swapping those out.
ATOWN4R is offline   Reply With QuoteReply With Quote
Old 09-05-2020, 01:43 PM #10
4Runner4life98 4Runner4life98 is offline
4Runner4life98 is on a distinguished road
Thumbs up
I have had great luck with a microfiber cloth and some meguiars plast-X polish. Made them look new.
4Runner4life98 is offline   Reply With QuoteReply With Quote
Old 10-12-2020, 10:53 AM #11
This is a very late reply but thanks again to all who responded. I ended up just cleaning the lenses and the housings out really well and it helped a lot. After that I just popped in a new pair of LED bulbs and wow is it bright back there now!
Honestly it's probably a little too bright as my backup camera gets some glare, but I can live with it. It looks really nice I think.
Thanks again!
information , leds , license , plate , replace
License plate mounting plate option Vespula 4th Gen T4Rs 0 02-12-2018 10:36 PM
How Are You Lighting You License Plate On Spare Tire? MaddoxPics 5th gen T4Rs 0 11-22-2017 11:26 AM
3rd Gen Questions about 2nd Gen license plate holder from swing-out tire carrier SURF RUNNER 3rd gen T4Rs 6 06-01-2015 10:03 AM
New Funny Custom License Plate, where to buy front license plate mount spoiler900 3rd gen T4Rs 3 01-04-2013 12:57 AM
license plate lighting RevengEngine 3rd gen T4Rs 5 07-17-2008 02:24 AM
