Old 09-05-2020, 07:52 PM #1
JT_4Runner's Avatar
JT_4Runner JT_4Runner is offline
Real Name: Justin
JT_4Runner is on a distinguished road
JT_4Runner's Avatar
Real Name: Justin
Fitting Relentless Fab Predator bumper with a 1.5” BL
I have a 1.5” BL to help with the fitment of my 35s and want to purchase the Predator front bumper from Relentless Fab. I asked if they could fab me up a bumper that would incorporate the BL and was told no. So now I ask, does anyone have ideas on how to install the bumper in a manner in which reduces the gap from the body lift?
2007 Limited V6
ICON 2.5 Ext. RR CDC
MetalTech Stage 5 LT
SCS SR8 Dark Matte Bronze 17x8.5
JT_4Runner is offline   Reply With QuoteReply With Quote
Old 09-05-2020, 11:12 PM #2
ads2539's Avatar
ads2539 ads2539 is offline
Real Name: Howard J. Turkstra
ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough
ads2539's Avatar
If the Predator bumper attaches to the frame like the stock bumper does, I think you can mount it an inch higher. It’s not 1.5”, but it’s better than 0”.
I did a 1” body lift with the stock front bumper, and I was able to mount the stock front bumper an inch higher so it looks normal.
I’m not familiar with the Predator bumper, so I may be wrong. I know there are other front bumper manufacturers who will customize bumpers for 4R’s with a 1” body lift, so there might be more to it than I am aware of.
2004 Limited V8 4WD 183k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
ads2539 is offline   Reply With QuoteReply With Quote
Old 09-05-2020, 11:51 PM #3
montijo505's Avatar
montijo505's Avatar
This is odd as most all the ones I looked at when shopping around all had 1" BL options.
Sent from my SM-G986U using Tapatalk
Old 09-06-2020, 12:32 AM #4
ads2539's Avatar
ads2539's Avatar
I’ve seen a couple without the BL option, and wonder why they don’t offer it.
Old 09-06-2020, 01:41 AM #5
mysticz's Avatar
mysticz mysticz is offline
mysticz has a spectacular aura about mysticz has a spectacular aura about
mysticz's Avatar
Most bumpers already have the drilled slots in the mount base to adjust. I have seen guys with 1.5-2" BL install Shrockworks, Demello. 4x4Labs and etc. with no issues.
How much of gap do you want? a good size gap works great for when your doing trails with lots of flexing and also helps when you winch, at times if you winch to hard you bend your mount and the bumper tweaks up.
Something similar happen to my bumper on the driver side, I have only a 1"BL with a 3.5" SL, take my advice never winch someone stuck in a mud pit.
2005 T4R Silver SR5 V6 4wd with Mods.
mysticz is offline   Reply With QuoteReply With Quote
Old 09-06-2020, 02:25 AM #6
mysticz's Avatar
mysticz's Avatar
Here it shows my mounts and the adjustable points on both bumper and mount.
Old 09-06-2020, 02:26 PM #7
JT_4Runner's Avatar
Real Name: Justin
JT_4Runner's Avatar
Real Name: Justin
To my knowledge the bumper mounts directly to the frame rails where the factory crush bar would normally mount via 3 bolts on either side. As simple as it is I had not thought about just raising the bumper up and utilizing only 2 of the 3 mounting bolts on either side. Any thoughts on whether that would cause the bumper to fail or rather bend easier when wenching?
I managed to find a video of a guy installing the same bumper on his truck. I’ll attach pics.
2007 Limited V6
Old 09-06-2020, 02:33 PM #8
JT_4Runner's Avatar
Real Name: Justin
JT_4Runner's Avatar
Real Name: Justin
@ what are your thoughts on utilizing only 4 of the 6 mounting bolts due to moving the bumper upwards to reduce the gap? I’m fine with there being some gap I just don’t want a huge gap and the bumper to look out of place. At the end of the day I want the bumper to still be able to retain the full form and function (strength of the mounting to the frame).
Here is a pic of the mounting points on the bumper itself
2007 Limited V6
Old 09-06-2020, 03:14 PM #9
montijo505's Avatar
montijo505's Avatar
It looks like you'd have to drill a hole for the third bolt anyway, if you're able to move it up in the first place.
Old 09-06-2020, 03:41 PM #10
ads2539's Avatar
ads2539's Avatar
With the stock front bumper, I’m using just 4 of the 6 mounting bolts without issue. It might be a problem with a heavy offroad bumper or if winching.
A few posts up, there’s a pic of a bumper that bent from using a winch.
Old 09-06-2020, 03:59 PM #11
JT_4Runner's Avatar
Real Name: Justin
JT_4Runner's Avatar
Real Name: Justin
I saw that, which I think could be an issue regardless of how it’s mounted whether I were to use 4 bolts rather than the 6. I suppose I could mount the bumper with 4 bolt and weld a sort of tab onto the bumper below the bottom slot on each side to allow the placement of 3 bolts on each side.
2007 Limited V6
Old 09-06-2020, 04:41 PM #12
montijo505's Avatar
montijo505's Avatar
Another thing to consider is if the winch plate will have clearance if you move it up. I'll go snap a pic of mine since I don't have a winch yet so you can get an idea.
Old 09-06-2020, 11:05 PM #13
JT_4Runner's Avatar
Real Name: Justin
JT_4Runner's Avatar
Real Name: Justin
I’m glad you mentioned that. Looking forward to the pics
2007 Limited V6
Old 09-07-2020, 12:47 AM #14
montijo505's Avatar
montijo505's Avatar
I forgot today, sorry. I'll do it in the morning.
1.5” , bumper , fab , predator , relentless
Relentless Fab "Predator" Front Bumper Pics mysticz 4th Gen T4Rs 2 01-11-2020 02:25 AM
Relentless Predator front bumper San Diego Gabex35 For Sale: T4R Items 0 04-01-2019 05:33 PM
Relentless Fab Front Bumper dctacoma 4th Gen T4Rs 16 02-15-2018 05:18 PM
Relentless Fab Bumper t4rtaco 3rd gen T4Rs 14 02-06-2016 02:48 AM
Relentless Fab. New Front Plate Bumper MattJakobs 3rd gen T4Rs 22 12-08-2015 11:02 AM
