Old 09-06-2020, 12:20 AM #1
wjchop wjchop is offline
wjchop is on a distinguished road
Brake pedal went to floor?
Bought my 06 4R not that long ago, bought it with some known issues as I got it for a killer price. One of those issues was shaking while braking, which I did a little research and figured even replacing all components Calipers, rotors, pads, etc would be $500ish front and back. I was going to run to the store today, which requires highway driving, I had no issues backing out of the drive or slowing down at the corner. I come to the stop sign push on the brake and there was very little braking, as I get closer I slap it in Neutral and start pumping the brakes, all the sudden RPMs kick up to 1,700, 4R leaps forward, then RPMs go back down and pumping must have done something as I got it to stop. Ended up taking it back home and taking the wife's suv.
After I got back I did some interwebs searching, it appears this is kind of a common issue, but almost everyone says they got alarms and lights going off before it happened. I got nothing. What I have found said check the Brake motor under the master cylinder and the accumulator, and since I already had the shaking issue further reading on the new issue brought to light the Toyota brake system flaw and it appears many people are putting Tundra Calipers an rotors on to fully solve the shakes. They don't really say what year Tundra, should it be same year as the 4R.
Has anyone done this and have knowledge to share, anyone else experience the brake "failure" issue I did, ultimately what was your fix?
wjchop is offline   Reply With QuoteReply With Quote
Old 09-06-2020, 12:07 PM #2
gaber6 gaber6 is offline
gaber6 has a spectacular aura about gaber6 has a spectacular aura about
Glad you stopped in time.
No need to pump brakes on new cars.
However.
New rotors, calipers and pads are in store for you it seems. Also shocks and struts help keep the tires on the ground.
That MAY have made the pulsing more sensitive to activating the already sensitive abs system on these suvs.
If you hit sand or gravel as approaching a stop and the suspension moves, the abs kicks in for a few seconds with scary brake feel.
I did have ASE training in brake technology back before I decided to not be a mechanic.
gaber6 is offline   Reply With QuoteReply With Quote
Old 09-06-2020, 06:43 PM #3
kc15842 kc15842 is offline
Real Name: Kevin
kc15842 will become famous soon enough
Real Name: Kevin
Shaking while braking in most cases is warped rotors. How many miles on the truck and brakes?
Depending on how easily the pistons retract I may not touch the calipers.
I suggest turning the front rotors and replacing the front pads. Do a break in on the new pads and see how it now stops. Keep it simple and do the front first to se if it takes care of the shaking. If the rears are worn then do the same on the rear.
1987 22R-E, SR5. 5 Speed, 31's BFG A/T, stock wheels. 4.56 Gears, Rear Detroit locker Front True Track. 1.5" BJ Spacers & Extended Shackles in the rear.
1992 3.0, SR5. 5 Speed. 31's BFG M/T, stock wheels. 4.30 Gears-NON ADD- manual hubs, Elocker, 1.5" BJ Spacers, Moog springs w/ spacers. Sold
kc15842 is offline   Reply With QuoteReply With Quote
Old 09-06-2020, 10:46 PM #4
It is right at 150k, my guess is these are the original rotors, but I haven't pulled the wheels off yet to look. Who knows on the pads, but yes I am just going to replace them regardless that way I know what is on there going forward.
As far as the shocks and struts, I plan to do a 3" lift and will just buy a kit that has shocks, struts and springs in it to replace everything. May replace UCAs too, depending how they look.
This is going to be my camping/lake/fishing rig, don't need anything fancy, just functional and looking cool isn't ever a bad thing either.
Old 09-08-2020, 04:43 PM #5
MikeinNH67's Avatar
MikeinNH67's Avatar
Well that's pretty scary, glad all is well. The only time I've seen this on any car was because of a blown brake line. Keep us posted.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 09-16-2020, 09:00 PM #6
OK, well I changed pads, rotors and calipers. Rotors were extremely warped and a couple pistons on the calipers were sticking, so replaced everything. I have bleed these things three times now, and when driving the pedal still goes nearly to the floor before the breaks start slowing the 4R down. They work, but its driving me crazy I have to push the pedal so far down. Is there some kind of an adjustment on these things I don't know about?
Old 09-16-2020, 09:50 PM #7
azgold azgold is offline
azgold is on a distinguished road
I have a 2006 4runner V6 with 223 K miles on it and if your pedal went to the floor it has nothing to do with pads, rotors etc.....
Either your hydraulic booster assembly was serviced and not bled properly, or there is an issue with the booster assembly itself. Pump, motor, accumulator.
These parts can be purchased , but make sure your diagnostic is correct because the parts are pricey if you buy OEM ( which is what you should do)
azgold is offline   Reply With QuoteReply With Quote
Old 09-16-2020, 10:19 PM #8
Berty_K's Avatar
Berty_K Berty_K is offline
Berty_K has a spectacular aura about Berty_K has a spectacular aura about Berty_K has a spectacular aura about
Berty_K's Avatar
FYI, 4Runner (and toyota brakes) are squishy in general. Lots of travel before they start engaging. Driving my wife's CRV is always a transition because of how sensitive her brakes are. Not saying you don't have a problem, but something to consider as you debug.
I went nuts trying to firm up my pedal feel (redid brakes a 2/3 times, bled them, and took it to a mechanic) before just accepting it.
If you Google around, you'll see lots of people share similar thoughts about their "squishy" toyota brake pedals.
'08 Silver SR5 V6 4x4: OEM+
Berty_K is offline   Reply With QuoteReply With Quote
Old 09-18-2020, 01:25 PM #9
toyoman25's Avatar
toyoman25 toyoman25 is offline
toyoman25 is on a distinguished road
toyoman25's Avatar
guess I got lucky with mine....don't have this issue
Toyo is my Name and My Ride
toyoman25 is offline   Reply With QuoteReply With Quote
Old 09-18-2020, 03:29 PM #10
MikeinNH67's Avatar
MikeinNH67's Avatar
Mine doesn't seem very squishy either. At least not after it got new rotors/pads all around and calipers in the front. New brake lines too. Certainly not as hard a pedal as my FIL's CRV but less squishy than my wife's Odyssey.
Mike
03 4runner Limited
Old 09-20-2020, 01:16 AM #11
toyoman25's Avatar
toyoman25's Avatar
Well it's a Honda After all lol
Old 09-23-2020, 11:35 PM #12
MikeinNH67's Avatar
MikeinNH67's Avatar
Ha, I've owned many Hondas, this is the only one that is like this but it seems to be common/normal on that generation Odyssey. It still stops very quickly for a van. Goes quickly too.
Mike
03 4runner Limited
Old 09-25-2020, 07:13 AM #13
Drcoffee's Avatar
Drcoffee Drcoffee is offline
Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice
Drcoffee's Avatar
Its time to replace the flex brake hoses. Two things can happen with them. Either they corrode and close down or get weak and expand under braking. Also, if Im not mistaken, if the pedal goes to the floor, you either have air in the line or the Master cyl has failed. I would start there.
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
Drcoffee is offline   Reply With QuoteReply With Quote
back , brake , issue , issues , rpms
Brake pedal to the floor hallj22 3rd gen T4Rs 25 05-22-2017 04:38 PM
Brake pedal to the floor - still need help Paramedic 3rd gen T4Rs 6 02-04-2017 04:32 PM
Brake Pedal goes to the Floor achha64 3rd gen T4Rs 2 11-28-2014 10:19 AM
Brake pedal goes all the way to floor, etc. ThePizzaGuy 3rd gen T4Rs 7 01-18-2013 09:31 PM
does your brake pedal go to the floor? gonzo 4th Gen T4Rs 34 08-03-2006 01:26 PM
