Old 09-07-2020, 02:24 AM #1
andreylights's Avatar
andreylights andreylights is offline
andreylights will become famous soon enough
Wheel spacers' affect on rollover angle?
Hey all! I am curious to see if someone with more knowledgeable of physics than I am could voice an opinion regards to the rollovers and the width of the wheelbase.
My setup is not ideal, as I believe I have a pretty high COG, since I ran a tall-ish lift of 3" front and rear, on some skinny pizza cutters and do have an RTT on the stock rails. Every time when I go off camber its breathtaking haha. I would think that increasing the distance between the wheels should make the vehicle more stable.
Question is: will 2.5" of difference (I think average wheel spacer is like 1.25"?) make a significant enough impact on stability to offset the price and potential additional wear on the wheel bearings?
PFA
Wheel spacers' affect on rollover angle?-tilt2-jpg
07 SE V6, Front: Dobinsons LT GS59-220 + C59-302 w/ ICON UCAs;
Rear: GS59-575 + C59-677V w/ ICON Trailing Arms; PCK;
Coastal-Offroad bumper and sliders; ASFIR aluminum skids;
255/80r17 Falken AT3W on Toyota Trail edition wheels;
andreylights is offline   Reply With QuoteReply With Quote
Old 09-07-2020, 02:55 AM #2
xtremewlr's Avatar
xtremewlr xtremewlr is offline
Real Name: Todd
xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold
xtremewlr's Avatar
Real Name: Todd
PFA
Won't hurt to be slightly wider but I don't think it will make a huge difference. There's actually not a ton of additional wear on the wheel bearings either.
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
xtremewlr is offline   Reply With QuoteReply With Quote
Old 09-07-2020, 08:12 AM #3
MrSeth's Avatar
MrSeth MrSeth is offline
Real Name: Seth
MrSeth is a jewel in the rough MrSeth is a jewel in the rough MrSeth is a jewel in the rough MrSeth is a jewel in the rough
MrSeth's Avatar
Real Name: Seth
I have noticed a difference with the feeling of being "planted", however, I do not have a RTT.
I'm running 1.25" spacers with a -12mm 9"wide wheel with 315's. I think that the heavier tire/wheelset might be helping me out, but my lift is also taller at 4" suspension and 1.5" Body.
Wide wheels, wide stance, I feel make it more proportionate when looking at dimensions of width vs height. Go taller? Go wider.
Almost done with a 12 hour shift, so that might not make any sense at all.
2006 Shadow Mica SR5 v6
1" BL, Fox Racing UCA's, RC 3" N3 Lift, Rock Trix RT110 -12 Wheels, 315/70R17 Goodyear Territory MT, Tacoma Front Bumper, 5th Gen 4R Tire Carrier, Big Lion LED's
MrSeth is offline   Reply With QuoteReply With Quote
Old 09-07-2020, 05:39 PM #4
RonJR RonJR is offline
Real Name: Ron
RonJR has a spectacular aura about RonJR has a spectacular aura about RonJR has a spectacular aura about
Real Name: Ron
So, lets make a couple of assumptions, and do some quick calculations.
a) assume COG is 30 inches above ground.
b) Track width stock is 63 inches.
In that case, theoretical static (ie, on a tilt table) roll-over angle is atan((63/2)/30)= 46.4 degrees
With the spacers, track width is 65.5, so roll-over angle is atan((65.2/2)/30) = 47.4 degrees.
So, not much difference. Notice a couple of things, though.
1) The static rollover angle is much higher than you think. Most of the weight of the vehicle is engine, transmission, frame, and axles, all of which are mostly well below 36 inches above the ground, thus the estimate of 30 inches for the actual COG. On a stock vehicle, it's probably closer to 26 inches or so.
2) DO NOT rely on these numbers for maximum safe tilt angle when offroading. Dropping your down hill wheels into a hole will start a rolling momentum that can carry you over at much more shallow angles, especially if you have a heavy weight, (i.e., RTT) on the roof rack. Computing the dynamic roll over angle is much more complex, and requires knowledge of moment of roll-over inertia, speed, road surface, etc. Not easy to predict.
I get nervous at about 25 degrees, and prefer not to push it further than that.
One thing I've noticed is that >20 degrees of tilt on the trail seems steep and uncomfortable. However, watching my tilt meter on the highway while going around sharp curves such as a roundabout, I regularly hit 20 degrees on the meter and think nothing of it. So a lot of it is a matter of perception.
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
RonJR is offline   Reply With QuoteReply With Quote
Old 09-08-2020, 03:53 PM #5
AKA "you are overthinking this stuff"? seems like in your opinion its not worth it.
You have noticed a difference after you installed the wheel spacers? Because 315 tires / new offset -- a lot of factors that could influence the judgement. I do agree, tho, wider stance makes the 4runner look so much better.
Thats a great post! Yeah, as I suspected the difference in math is not huge. And of course I fully understand the simplifications what went into the calculations (comparing to the real world), I wanted to know the scale of spacers effect and +/- 1 degree is pretty negligible I am assuming.
distance , make , vehicle , wheel , wheels
***SOLD*** Spidertrax 1.25" Wheel Spacers | Brand New | Black | Set of 4 spacers papadop88 For Sale: Suspension/Wheels/Tires 16 01-09-2020 12:17 PM
Rollover angle delloro 5th gen T4Rs 50 12-09-2017 06:29 AM
Wheel spacers/track width/rollover video Lefty JD 3rd gen T4Rs 26 02-14-2017 10:58 PM
FS:G/2 Toyota 1.25" wheel spacers 2 pairs (4 spacers)-Houston, TX-$125 lhg9105 For Sale: Suspension/Wheels/Tires 4 01-13-2015 08:58 AM
newbie question: do wheel spacers or larger than stock wheels/tires affect safety? jasonlee Engines / Suspension / Wheels / Tires / Audio / Accessories 1 12-07-2004 01:13 PM
