Old 09-07-2020, 01:22 PM #1
keithyota keithyota is offline
keithyota is on a distinguished road
Does they ride soft and move a lot on the road?
Just got a 2007 that had new suspension components installed not long ago. 128k miles.
I notice on the road it is soft riding (much softer than old 99) and it tends to not hold a line, like it enjoys being blown around on the road.
I know some tires are cupped on back, which is why suspension was updated. Tires were fairly new Michelin's.
Do these things ride soft like that or did they possibly install wrong suspension components?
I'll get it checked out at shop just in case...I did not have it inspected, I did check myself and didn't notice at the time driving.
keithyota is offline   Reply With QuoteReply With Quote
Old 09-07-2020, 03:32 PM #2
Update
It's not XREAS, it's the standard suspension option, I see nothing broken underneath.
Old 09-07-2020, 05:15 PM #3
RonJR RonJR is offline
Real Name: Ron
RonJR has a spectacular aura about RonJR has a spectacular aura about RonJR has a spectacular aura about
Real Name: Ron
Check the alignment, specifically the caster. Does it have a lift? Even with small lifts, these things like to max out at about 1.5-2 degrees of caster, which is not enough for it to track nice and straight. You want 2.5-3.5 degrees for good tracking, and that's hard to get without aftermarket upper control arms if its been lifted at all.
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
RonJR is offline   Reply With QuoteReply With Quote
Old 09-07-2020, 09:11 PM #4
gaber6 gaber6 is offline
gaber6 has a spectacular aura about gaber6 has a spectacular aura about
Even with my daystar 2.5 level kit and no caster correction (stock uppers) it is not tight on the highway.
I'm going to lower it back to stock instead of getting uppers, mainly as I don't need the lift, and would like less wear and tear on other items, and I drive mostly highway.
gaber6 is offline   Reply With QuoteReply With Quote
Old 09-08-2020, 05:11 PM #5
update
Toyota checked out. The aftermarket suspension is "quickstrut" not the orignal with fluid loop between shocks. I didn't know that was case on Limiteds. Also noted front and rear sway bars were a bit worn and may be contributing, does make a "knock" which means there is play.
Said it drives ok for age. one Toyota rep suggsted KYB might help.
will try replacing sway bars first...
Old 09-09-2020, 10:06 AM #6
pauldub pauldub is offline
pauldub will become famous soon enough
Don't replace the sway bars. They don't wear out but the bushings and links can.
pauldub is offline   Reply With QuoteReply With Quote
Old 09-10-2020, 03:13 PM #7
Went to rockauto and bought some new sway bar links and bushings and KTB shocks to replace monroe quickstruts. never liked monroe ride on other cars. old stuff isn't broken but was reported as worn. hopefully helps.
Old 09-11-2020, 11:43 AM #8
zig553's Avatar
zig553 zig553 is offline
zig553 is on a distinguished road
zig553's Avatar
Could be as simple as needing new tires. I've had tires that looked okay from the outside but were around 8-10 years old and drove terribly. Once I put a new set on it drove like a new vehicle.
zig553 is offline   Reply With QuoteReply With Quote
Old 09-11-2020, 04:29 PM #9
chompster4runner chompster4runner is offline
chompster4runner will become famous soon enough
I can vouch this. I had KO1 put on as soon as I bought the 4Runner. Drifted and pulled everywhere. Then one tire hit a metal object on the corner forcing me to buy KO2 because the original was long gone. Then got into an accident and insurance wanted to replace one of the old with new KO2 so I paid for the other so all 4 tires are new KO2. Still rode like crap. Stiff sidewall means stiff ride with the bilstein 5100. Drift and pull on the freeway. 4 months ago I replaced them with general grabber atx standard load. Ride like a stock truck immediately. A bit softer and not like a slam Honda Civic. 99% of the crab walk or pull is almost gone. The 1% that is left is wind. It would still push the truck around on the freeway. I miss the look of the KO2s tho.
2022 Toyota 4Runner TRD OFF ROAD PREMIUM
chompster4runner is offline   Reply With QuoteReply With Quote
components , notice , road , soft , suspension
Best single KDSS-compatible suspension option for slight lift, soft ride 1996_Valencia_Owen 5th gen T4Rs 52 09-09-2018 01:05 PM
Best soft pack cooler for a long road trip RedST4R Off Topic 12 01-31-2017 12:50 AM
FS Adicted Off Road Plate bumper and Soft topper SMSmitty For Sale: T4R Items 4 11-09-2015 11:08 PM
2nd Annual Spring Break Soft Road Meet March 14 2015 at Northwest OHV Park FernandoDLT Texas & Oklahoma 0 01-07-2015 10:24 PM
I'm going soft- want my 4R to ride like a GX jakehere 5th gen T4Rs 20 12-02-2012 02:07 AM
