Old 09-10-2020, 02:42 PM #16
FXFRunner FXFRunner is offline
FXFRunner is on a distinguished road
Originally Posted by BackOff View Post
I have had 2nd gen rear swaybar links on since 2011. On my 4th gen t4r.
Can get them cheap at Rockauto.com
2nd gen 4runner
For 10-20 bucks
Some have reported the moogs flash rusting.
Your alignment numbers look good.
Maybe rotate the tires to see if it helps the wandering feel.
The front you can do a swaybar relocate bracket.
Moves it down and away from your shock a bit.
Saw the reviews on moogs mention the rust. Guess I'll stay away from those. I'm thinking about going no rear links and see how it feels. Shouldn't affect the drive as much as long as the front sway bar is there I'm guessing.
Good call on the tire rotation. Don't think i've done that.
FXFRunner is offline   Reply With QuoteReply With Quote
Old 09-11-2020, 01:38 PM #17
jrm's Avatar
jrm jrm is offline
jrm will become famous soon enough
jrm jrm is offline
jrm's Avatar
in the product description it states that the struts are pre-set @3"s. I'd suggest dropping the front end to 2" to 2.5". Unless your tires wont clear...
jrm is offline   Reply With QuoteReply With Quote
Old 09-11-2020, 01:53 PM #18
Bikeric's Avatar
Bikeric Bikeric is offline
Real Name: Eric
Bikeric will become famous soon enough Bikeric will become famous soon enough
Bikeric's Avatar
Real Name: Eric
I have heard that anything above a 2" will probably require a front differential drop. It is nothing more than a couple of thicker spacers and longer bolts, so installation is a snap. You want that to reduce the angle your front CV joints now have after the lift.
Oops. Just clicked your link and see it comes with diff drop. Carry On.
1984 SR5, 1989 DLX, 2011 SR5 4wd
Bikeric is offline   Reply With QuoteReply With Quote
Old 09-11-2020, 11:35 PM #19
This isn't an issue with the RWD right? I have the 2wd one
Old 09-11-2020, 11:37 PM #20
So the installation is complete and I think I'd like it better at 2.5.
3 Inch looks level but I kinda dont like the amount of space between the tire and the fender. I think it will look better with 2.5. I need to replace ball joint and I'll drop it to 2.5 when I take things apart at that point.
Old 09-11-2020, 11:47 PM #21
Photos, in case anyone is interested in my super stock 4R lol, still dirty from a recent trip
Old 09-12-2020, 06:22 PM #22
Bikeric's Avatar
Real Name: Eric
Bikeric's Avatar
Real Name: Eric
Smile
Correct. You can’t drop the front differential on a RWD
Old 09-13-2020, 05:21 PM #23
Berty_K's Avatar
Berty_K Berty_K is offline
Berty_K has a spectacular aura about Berty_K has a spectacular aura about Berty_K has a spectacular aura about
Berty_K's Avatar
http://<a href="https://ibb.co/kHK3F...order="0"></a>
http://<a href="https://ibb.co/tpMXc...order="0"></a>
Hard to tell, but you might have some reverse rake.
'08 Silver SR5 V6 4x4: OEM+
Berty_K is offline   Reply With QuoteReply With Quote
Old 09-14-2020, 02:12 AM #24
yes I'm going to drop it a bit after it settles. Should've done that before the install but was too excited to get the thing up and running so i left it
2007 V8 Limited / Toytec & Bilstein 3 inch lift
Old 09-14-2020, 02:13 AM #25
I may just a tiny bit yeah. Looking forward to seeing how it settles.
Old 09-14-2020, 11:07 AM #26
Berty_K's Avatar
Berty_K's Avatar
If it doesn't end up settling, I'd recommend getting a rear spacer from Cornfed: Cornfed Suspension Home. Good customer service. They customized my spacers to fix my driver side lean.
Old 09-14-2020, 06:12 PM #27
jrm's Avatar
jrm jrm is offline
jrm jrm is offline
jrm's Avatar
I think it should help matters.
brake , extended , kit , lift , missing
What am I forgetting? (Toytec 3 inch kit) FXFRunner General Discussions 0 09-08-2020 11:50 PM
3 inch ToyTec Bilstein lift kit ? redneckj 3rd gen T4Rs 8 09-15-2016 09:37 PM
Fs ft toytec 2 inch lift calvinv8sr5 For Sale: Suspension/Wheels/Tires 0 06-05-2016 08:45 PM
F/S 3 Inch Toytec Spacer Lift $100 Troutsrunner For Sale: Suspension/Wheels/Tires 7 06-25-2014 10:38 PM
