Old 10-14-2020, 06:50 PM #16
The G-Man The G-Man is offline
Real Name: Gary
The G-Man is on a distinguished road
Real Name: Gary
Originally Posted by Captsolo View Post
Every time I read this symptom I think of a "head gasket" leak. I just went to my 4runner, popped the hood, and looked at the coolant overflow catch canister, and it was at the same level it has been for the last 6 months.
That means I don't have coolant going/leaking into my heads!
Congrats... mine uses up the reserve tank
The G-Man is offline   Reply With QuoteReply With Quote
Old 10-15-2020, 09:31 AM #17
Captsolo Captsolo is offline
Captsolo will become famous soon enough
Check for hydrocarbons in the coolant. http://www.agcoauto.com/content/imag...carbon_tes.jpg
Amazon.com: Block Tester BT-700 Combustion Leak Test Kit in Hard Case - Made in USA: Automotive
Captsolo is offline   Reply With QuoteReply With Quote
Old 10-15-2020, 11:00 AM #18
at least read the thread before posting...
Update to this saga, just did another pressure test. Pumped up to 16 psi and it held no problem for 15 minutes and I looked around and found no leaks at all.
Then I warmed the engine up and performed the the combustion leak block tester. The fluid stayed that nice dark blue, so I don’t think I have a head gasket leak.
I did replace the radiator cap with a new one, I guess we will see how that goes.
But all this kinda still leaves me scratching my head? I suppose I could pull the thermostat and test that. Does anyone have other thoughts? Maybe I should just replace the water pump?
Old 10-15-2020, 08:48 PM #19
Real Name: Gary
Real Name: Gary
Yeah dude you’re adding negative value here.
If you go and watch the 3 videos from Schrodinger’s Box, you’ll find that it’s possible to pass that test but still have a leaking HG.
Old 10-16-2020, 01:54 PM #20
Snipermunro Snipermunro is offline
Snipermunro is on a distinguished road
Maybe a blown head gasket
I had the same problem with coolant leak, found out it was a head gasket
Snipermunro is offline   Reply With QuoteReply With Quote
Old 10-18-2020, 06:47 AM #21
earthrealm earthrealm is offline
earthrealm will become famous soon enough earthrealm will become famous soon enough
Sorry I never replied. I sure had that same symptom... used the coolant funnel and when burping just random slow bubbles and they never stop.
Today I got a CEL when starting. It was cool, high 50s F. Stumbled a bit then CEL with VSC/Traction off (not really sure why traction control is affected?)
Anyways, hit up O Reily's on my way home to use the code reader, and sure as shit just as I suspected P0306 (Cylinder 6 Misfire), and P0456 (Evaporative Emission Control System Very Small Leak).
Came home and searched YouTube one more time because once again, my block test came back negative. And the very helpful Schrodinger's Box channel came in clutch... took 3 30 minute videos but are all very educational for anyone with a 4th Gen V6, especially 2003-2006.
2004 Toyota 4Runner P0306 Misfire Diagnosis - YouTube
04 Toyota P0306 Pt2-Can Compression Test Lie? - YouTube
04 Toyota P0306 Pt3 -Art of Puzzle Solving - YouTube
Now I am convinced I have a HG leak. I think the course of action I will take is to use BlueDevil radiator flush and leak fix fluid. A user here, can't remember his handle here, but Dylan from the YouTube channel Trail Benders Overland used it and posted a very good video of it
How to fix your Head Gasket for $100 with Blue Devil Head Gasket Sealer! - YouTube
Anyways, that video is far from the only Blue Devil success story, just the only 4th gen T4R that I could find.
might be in the same boat, have an 05 with 172k miles,the reserve tank reduces by half an inch in 6 to 9months, i suspect a hg leak, however, no misfire as well
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto......sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
earthrealm is offline   Reply With QuoteReply With Quote
Old 10-18-2020, 08:46 AM #22
I like the Blue Devil idea.
earthrealm; 1/2 inch isn't enough loss to tell you much. Could be evaporation.
Just don't let it overheat. Keep an eye on the temp gauge.
My 2005 V6 4runner has never had an overheat (150,000) miles. I lift the hood to look at the water/coolant in the overflow tank every week.
One overheat can ruin an engine.
Old 10-18-2020, 05:28 PM #23
Real Name: Gary
Real Name: Gary
Yep, so I did that yesterday. Takes about a full day.
Drain, remove thermostat then fill with water. Run 10 minutes
Cool.
Drain, fill with radiator flush. Run 10 minutes
Cool.
Drain, fill part way with water, slow pour of blue devil, run 50 minutes.
Cool.
Replace thermostat (I used a new one with new housing due to bending the old one getting it out of housing)
When I started this morning engine ran butter smooth and no water fall noise. Topped with Zerex Asian vehicle antifreeze and burped.
Took for a spin to O Reilly’s to clear the fault code and then to the car wash to spray off mud from under rear skid plate that I now have access to since the front skid is off.
Planning on running for about a week to see what happens, then a drain and fill of antifreeze to make sure I have the right ratio before a freeze comes (probably will still be a couple months before that here in Mississippi)
Old 10-19-2020, 05:30 PM #24
newton22 newton22 is offline
newton22 will become famous soon enough
I used BlueDevil in August before I ever got any codes and misfires. My coolant temps were hot though (over 200 degrees in Texas summers at red lights). I figure the earlier I did it, the better it worked.
Well, I'm not convinced my HG is entirely sealed but it did slow down the leak. Honestly I'm driving around perfectly fine right now. No codes, no hiccups, coolant temperature stays at 180 degrees all day.
If temps don't hold, I'll just replace the HG. Big job but I like this truck.
2004 SR5 4WD | 5100s | Level 8 MK6s
newton22 is offline   Reply With QuoteReply With Quote
Old 10-19-2020, 08:09 PM #25
Drcoffee's Avatar
Drcoffee Drcoffee is offline
Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice
Drcoffee's Avatar
Has anyone tried the Bars Head Gasket sealer with carbon fiber. It works in all coolant types.
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
Drcoffee is offline   Reply With QuoteReply With Quote
Old 10-20-2020, 02:18 PM #26
I don't like the idea of particles as it might clog passages and the heater core. BlueDevil is purely chemical.
Old 10-20-2020, 11:13 PM #27
Real Name: Gary
Real Name: Gary
Same.
Old 10-29-2020, 07:32 PM #28
Real Name: Gary
Real Name: Gary
So it has been about 2 weeks since I put the Blue Devil in. I drove it to work every day for a week (the T4R isn't my usual DD) and I had no waterfall sound, no CEL/misfire/rough idle. I'd say the stuff is effective. It's cooler this week and I need to go to Lowe's and do some yard work so I'll keep this updated.
Now my big thing to tackle is the noisy idler pulleys, so now I have those on order and a new water pump because I fear I'll find evidence of that failing, and when a new one is $95, might as well for piece of mind.
coolant , drive , radiator , system , tank
need help - bleeding coolant system problems madmanhiker Classic T4Rs 18 06-22-2017 09:39 PM
Need help changing/flushing coolant system acronin2 4th Gen T4Rs 34 01-12-2017 06:23 PM
Seeking coolant system advise cj80cruiser 3rd gen T4Rs 16 09-19-2011 04:41 AM
2000 4runner - Iginition System Issues and Security System emtnscs New Members 0 10-12-2010 11:15 AM
coolant system flush..... kennyb3030 Maintenance/Detailing 5 02-21-2009 10:11 AM
