Old 10-09-2020, 08:12 PM #1
FrothyLlama's Avatar
FrothyLlama FrothyLlama is offline
FrothyLlama is on a distinguished road
Power Steering Whine
Flushed and cleaned the Power Steering system today because I was getting a really bad whine and the steering was choppy and the reservoir was black. So I flushed it, removed the reservoir, cleaned it, reinstalled it and then flushed again and topped off with ATF and burped the system. Turned on the 4runner and still had a whine but the steering was smooth as butter.
So where should I go from here? Just let it go? Keep running it until the pump goes? It has 160k miles and I'm sure wasn't flushed many times in its life.
If the pump goes is it going to cause issues like a bad timing belt would? Or would the issue just be isolated?
Sent from my Pixel 3a using Tapatalk
2006 SR5 V8
2.5/2.0" Lift (Dobinson Fronts C59-314, Dobinson C59-327 Rears)
Fuel 17x9 -12 offset D531 Hostage Wheels
265/70r17 Cooper Discoverer A/T
FrothyLlama is offline   Reply With QuoteReply With Quote
Old 10-09-2020, 09:26 PM #2
xtremewlr's Avatar
xtremewlr xtremewlr is offline
Real Name: Todd
xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold
xtremewlr's Avatar
Real Name: Todd
Proper way to bleed the power steering system is to have both front wheels off the ground and crank the steering wheel lock to lock until you have no more bubbles showing up in the reservoir. Leave the cap off while you do this. It is possible you might need to add some more ATF to the system as the air in it escapes. Crank the wheel lock to lock a good 10 times or so and then check. Rinse and repeat until the whine is gone.
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
xtremewlr is offline   Reply With QuoteReply With Quote
Old 10-10-2020, 12:33 AM #3
Hmm, I'll rebleed it in the morning. Only did lock to lock twice and minimal bubbles came up. Hopefully that will solve the problem but I am doubtful as I have a feeling the pump has been damaged due to previous owners neglect of the fluid.
2006 SR5 V8
Old 10-10-2020, 12:36 AM #4
I dont even know I dont even know is offline
I dont even know is on a distinguished road
Honestly as bad as I hate to say this, you may have a bad pump.
Not saying you do but both of my 4runners do this and it’s highly annoying and I’m just too lazy to do anything about it lol
I dont even know is offline   Reply With QuoteReply With Quote
Old 10-10-2020, 09:45 AM #5
are you sure the whine is from the pump? how did you confirm that? there are a few other pulleys in the serpentine drive assembly that can make noise when bearings go bad too. also the alternator.
& if the p/s pump actually fails it wont cause any other problems with the engine, you will just loose all power assisted steering.
Old 10-10-2020, 10:01 AM #6
Yeah, and honestly I'm not too worried about it. The whine is bad but I can easily get over it.
2006 SR5 V8
Old 10-10-2020, 10:02 AM #7
Definitely from the PS pump, it fluctuates according to how much I turn the wheel. When I am at almost full lock it sounds like a band saw.
2006 SR5 V8
Old 10-10-2020, 10:58 AM #8
xtremewlr's Avatar
Real Name: Todd
xtremewlr's Avatar
Real Name: Todd
It seems like it takes forever to get it to stop whining. The method I posted above is straight out of the service manual though. It just takes time and a lot of cranking lock to lock to get it to stop. You don't have to climb in and out of the driver seat every time, just do it thru the driver window.
Old 10-10-2020, 12:25 PM #9
Syr4RinNC's Avatar
Syr4RinNC's Avatar
Theres a few other threads. Ive had a bad PS pump/ whine for a ~ 30 k miles. Its very loud when i start my engine. No other problems, than just loud
Old 10-10-2020, 12:55 PM #10
Did 10 times this morning, had some tiny bubbles and the level of ATF went down maybe just 2-3mm. Still have the whine, thanks for the help, but I do not think it'll go away.
2006 SR5 V8
Old 10-10-2020, 12:56 PM #11
Yeah, I don't think any issues will come of it other than it someday going out. I'm not worried; I'm sure the pump has plenty of life left. It's low on the list of priorities for me.
2006 SR5 V8
Old 10-10-2020, 03:29 PM #12
xtremewlr's Avatar
Real Name: Todd
xtremewlr's Avatar
Real Name: Todd
Dude, I did lock to lock 10 times and repeated that process like 6 or 7 times. Like I said, it takes time to get it to stop.
Old 10-10-2020, 05:19 PM #13
Oh, well you didn't say you did it like 6 or 7 times lol.
2006 SR5 V8
Old 10-10-2020, 05:26 PM #14
xtremewlr's Avatar
Real Name: Todd
xtremewlr's Avatar
Real Name: Todd
Rinse and repeat until the whine is gone. I posted that in my first post. That means keep doing it until the whine is gone.
And now that I think about it, when I did that, the whine never fully went away when it was on jackstands. Wasn't until I dropped it and drove it that the whine stopped. But you HAVE to do the bleed process a lot, not just 10 lock to locks, but multiples of that.
Old 10-11-2020, 10:00 AM #15
Direwolf82 Direwolf82 is offline
Direwolf82 will become famous soon enough
A buddy of mine has the whine going on. Mechanic quoted a new pump, he being thrifty with his money decided to just spend some time and clean the inside of the pump and reservoir. After an hour of scrubbing with a rag on the end of a stick he pulled a bunch of jelled material out and no more whining. Might be worth looking at, not sure if it will apply to your situation or not.
Direwolf82 is offline   Reply With QuoteReply With Quote
flushed , power , pump , steering , whine
Power steering pump V8 whine-rebuild rjb75 4th Gen T4Rs 6 04-10-2017 09:16 PM
Power Steering Whine Cire2 5th gen T4Rs 9 03-23-2016 12:26 AM
Power Steering whine Brian1973 3rd gen T4Rs 4 11-05-2014 07:40 PM
cold start power steering whine twicepipes 3rd gen T4Rs 15 04-13-2014 10:26 PM
