Old 09-09-2020, 02:57 PM #1
bricew25 bricew25 is offline
bricew25 is on a distinguished road
Engine Whine, Idler Pulley or Water Pump?
Noticing a whine thats pretty loud coming from the engine bay. When I first start the vehicle its pretty loud and will fluctuate and eventually even goes silent. Sometimes if its whining, I can hit the gas and it will stop until the RPM's come back down. While driving I can hear it whine and will change frequency as I apply gas. It comes and goes throughout my driving. After my drive I parked the car in the driveway and the noise was gone and I assume it would start up once I started to drive again. Also, as the vehicle shifts gears you can hear the whine come and go as it goes from 1st to 3rd..
Ive read some other posts about water pumps and Idler Pulleys. I assume I would have to start taking off the serpentine belt to narrow this down, but I wanted to see if anyone else could diagnose this from the way the sounds changes in relation to the throttle. Would both idler pulley or water pump be affected by how much gas is given? Maybe its neither of them?
Any other way to check before having a shop look at it?
Thanks,
bricew25 is offline   Reply With QuoteReply With Quote
Old 09-09-2020, 04:53 PM #2
MikeinNH67's Avatar
MikeinNH67's Avatar
I would check out the idlers first as they make noise when they are getting tired but also the alternator can do it. Easiest thing is to pull the belt and spin everything touched by the belt except the crank pulley. Should be no noise, should be smooth and no slop.
All of the items that touch the belt except the crank pulley can make noise that changes with engine speed including the AC compressor. They all have bearings that can dry/wear out. Even a worn out belt can make this noise.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 09-09-2020, 06:42 PM #3
Drcoffee's Avatar
Drcoffee Drcoffee is offline
Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice
Drcoffee's Avatar
Do a cold start, and one at a time spray wd40 into each pulley bearing Until the noise disappears. Just dont spray the belt. The tensioner pulley seems to fail quicker. You can press in new bearingS 6203RS x2 into the pulley $8 each. All the others have unique bearings. The two upper idlers use koyo 6302RMX $14 each
6203-2RS C3 SKF Double Sealed Bearing 17x40x12 (mm) | eBay
Idler Pulley/Bearing Failure, what to do: | Page 10 | Toyota FJ Cruiser Forum
If it turns out to be the tensioner pulley, you dont need to, and dont want to replace the whole tensioner mechanism. Just replace the pulley. The bolt is reverse threaded on just this one pulley, so the rotation doesnt loosen the bolt. Torque it to 30ft#s. The lower. Pulley is 40ft#s and the two upper pulleys are 29ft#s.
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
Drcoffee is offline   Reply With QuoteReply With Quote
Old 09-09-2020, 08:16 PM #4
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Thanks,
Best bet is to go to the auto part store and for around $10 buy yourself a mechanic's stethoscope and use it carefully to pinpoint where the whine is coming from, everyone should have one in their toolbox!
2004 Limited V8
Old 09-12-2020, 07:31 PM #5
Bogrun's Avatar
Bogrun Bogrun is offline
Bogrun will become famous soon enough
Bogrun's Avatar
I had a pretty annoying engine whine for quite a while and decided to replace the idler pulleys as well as the pulley for the tensioner (which I believe was the one making the noise).
Really made more of an improvement than I thought it would. That whine really made the truck seem kind of weak and wimpy and would turn some heads when driving around my neighborhood. Not to mention that first start up without the whine is just a great feeling!
If you've never replaced them I'd definitely start there as they're all relatively inexpensive to replace. Just remember that the tensioner pulley is left-hand threaded so it's right-loose, left-tight
Bogrun is offline   Reply With QuoteReply With Quote
Old 09-13-2020, 09:35 PM #6
Nahrah's Avatar
Nahrah Nahrah is offline
Nahrah will become famous soon enough Nahrah will become famous soon enough
Nahrah's Avatar
Right!! The noise was so horrible that it was noticible and caught peoples attention. Mine turned out to be a combination of idler pulleys, tensioner pulley and my alternator bearings were shot, that was causing the noise so check that too. Now its quiet and smooth sailing.
Current - 21 TRD ORP, Method 316 on 285/75/17 Toyo MT, Bilstein 5100’s OME 885/889, Spc UCA
Old(still in the family) - 07 Sr5 V6 2wd, Bilstein 5100's, Ome 884/895e, TRD ORP wheels, SPC UCA and CBI front skid plate.
Nahrah is offline   Reply With QuoteReply With Quote
Old 11-17-2023, 10:21 PM #7
Team4runna Team4runna is offline
Team4runna is on a distinguished road
I just got this insane whining noise at 9500 miles on the odometer. It is driving me absolutely crazy.
Team4runna is offline   Reply With QuoteReply With Quote
gas , idler , start , water , whine
Anyone ever get crap stuck behind your water pump pulley? capri_auto 4th Gen T4Rs 5 12-24-2019 05:10 PM
Engine Whine After Water Water/Mud Exposure - Alternator??? Patton 3rd gen T4Rs 9 05-04-2016 10:42 PM
Engine whine - oil/water pump, or worse? climberbry 4th Gen T4Rs 10 07-29-2014 12:03 PM
camshaft pulley and water pump 01thunder 3rd gen T4Rs 4 07-15-2013 12:27 AM
Clutch Fan Idler Bracket (false water pump) skozzy Classic T4Rs 0 07-02-2007 06:19 AM
