Old 09-12-2020, 03:26 PM #1
FXFRunner FXFRunner is offline
FXFRunner is on a distinguished road
Alignment question: worn camber and caster bolts?
This is something i asked in the general forum but the issue is on a 4th gen so here it goes:
I just installed a 3 inch lift kit with the stock UCA's and ran into the common issue of running out of caster adjustment.
The tech at Firestone was saying that my alignment bolts were spinning but not changing anything so I should get new ones.
Before I run and start ordering parts I wanted to check if this makes any sense to any of you who have experience with this stuff.
Is it possible that the camber and caster bolts weren't doing anything because there is no adjustment left in the UCAs?
Is there really such thing as these bolts being worn?
(Would it make more sense to give the suspension some time to settle before I start correcting things?)
2007 V8 Limited / Toytec & Bilstein 3 inch lift
FXFRunner is offline   Reply With QuoteReply With Quote
Old 09-12-2020, 07:51 PM #2
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
I think you may need a little more information from the alignment tech at Firestone. When they say that turning the cam bolt doesn't do anything, do they mean that no matter how much bolts are adjusted, they won't go into spec OR that the bolts were not able to be turned for an alignment at all? The former is very common with installing a lift over 2", and the latter is pretty common if your 4runner hasn't been aligned in a while and the alignment cams are seized. Unfortunately, there aren't any alignment cams (that I know of) that can fix caster from 3" of lift.
I'd say you definitely need UCAs for a 3" lift and should investigate the alignment cams for seizure. Ask the tech or shop for clarification if you need to
Some seized alignment cam bolt pics for fun:
y=mx+b is offline   Reply With QuoteReply With Quote
Old 09-13-2020, 05:20 PM #3
Berty_K's Avatar
Berty_K Berty_K is offline
Berty_K has a spectacular aura about Berty_K has a spectacular aura about Berty_K has a spectacular aura about
Berty_K's Avatar
I’m guessing they were seized and he went to town on them. Maybe he tore up the bushings, or they were already torn?
Regardless. Sounds like you’ll want new lower control arms. Choice is ultimately yours, but I’d recommend oem, or (if you’re feeling adventurous) put in some whiteline bushings yourself.
'08 Silver SR5 V6 4x4: OEM+
Berty_K is offline   Reply With QuoteReply With Quote
Old 09-13-2020, 05:35 PM #4
y=mx+b's Avatar
y=mx+b's Avatar
Did someone say Whiteline Bushings? Whiteline Lower Control Arm Bushing Tutorial (120+ Pictures)
OP, if you do decide to go the Whiteline LCA bushing route, let me know if you have any questions.
Old 09-14-2020, 01:57 AM #5
Got aligned at the same place 3 months prior and they didnt mention anything about bolts being seized or anything like that. Had the alignment done within spec. I'm guessing "wont go into spec due to lift" is the most likely scenario here. (nothing looks like these photos lol)
I made the mistake of going in right after a fresh install where I netted about 5 inches of lift total. Went from 18 something to 24 something measured at center of hubcap to fender. The front was sagging so I'm guessing this amount of lift is normal before everything settles.
Anwway, I think I'm gonna hope for the best and let the suspension settle for a bit. After that I'll lower the front about a half inch (i dont mind a little rake) and go in for another alignment. At that point if the guy still needs bolts I'll get him new bolts
Old 09-14-2020, 02:05 AM #6
oh mannn, i hope not! I dont think this is the case but I still hope not! lol
Old 09-14-2020, 02:06 AM #7
will do, thank you
adjustment , alignment , bolts , caster , ucas
Caster/camber alignment cam bolts OEM or SPC? ryanlord43 3rd gen T4Rs 8 08-27-2022 03:28 PM
Alignment question: worn camber and caster bolts? FXFRunner General Discussions 9 09-20-2020 06:00 PM
Alignment Camber/Caster Kit jrm 4th Gen T4Rs 12 08-22-2016 12:33 PM
Just lifted, cam bolts are seized, can't adjust caster/camber wtcnbrwndo4u 4th Gen T4Rs 25 08-04-2016 07:18 PM
FREE: XREAS front suspension non leaking, LCA's, UCA's, camber alignment bolts T101 For Sale: Suspension/Wheels/Tires 5 01-29-2016 06:04 PM
