Old 09-21-2020, 06:36 PM #46
windyhill windyhill is offline
windyhill is on a distinguished road
Wife’s 05 Limited. 240k, has been perfect for 15 years. Makes me sick to think this could have been prevented...
windyhill is offline   Reply With QuoteReply With Quote
Old 09-23-2020, 04:12 PM #47
Terminator03 Terminator03 is offline
Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough
Prevented? Not so much... sure, you can slow it down, but if you reside anywhere where salt is used, then forget about it. I’m convinced that defective, or recycled steel with impurities was used for these frames because I’ve never seen degradation like these exhibit in cars that are in otherwise very good condition with bodies and floors with no rust. I’ve been spent most of my life either involved with or working around auto restoration. In fact, my own frame was sandblasted, primed and painted a few years ago, and several areas rusted through from the inside. This is definitely a case the NTSB should be looking into. I’ve spent the last several days cutting out corroded sections and welding in new sections, plates and gussets to save this truck. The only good part about cutting the frame open is that I can sandblast the inside and coat it properly to add some longevity to the repair work. Once I’m done with all the welding, I also plan to spray some type of oil coating inside as well. Hopefully once I move to GA, I won’t be dealing with road salt anymore which should help as well. I just wish I had known how prevalent this corrosion issue was before I bough my truck. During the repair, I found areas where the dealer (can’t prove it was them, though) had MIG welded thin sheet metal to cover a few bad areas, then used body filler to blend the patches into the frame and repainted everything flat black to disguise the damage, which is why I didn’t catch it when I looked at frame before I bought it. Very shady technique that I highly suspect was done by the used car dealer.
2004 black SR5 V8 4WD with TRD dual exhaust, Thorley headers, AFE dry filter, Sprint Booster, Icon 2.0 rear shocks, OME 895E springs, Fuel wheels with 265/70/17 Wildpeak AT3W tires, more to come...
Terminator03 is offline   Reply With QuoteReply With Quote
Old 09-23-2020, 11:34 PM #48
MikeinNH67's Avatar
MikeinNH67's Avatar
Wow, that is brutal.
Terminator03, that sux that someone bodged yours like that.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 09-24-2020, 11:25 AM #49
Trust me, if I could prove who did it, we’d be having words...
As, I’ve said, it has to be flawed metal because that level of corrosion seems like it’s been sitting n the ocean floor for decades, not just from average winter driving. I mean the freakin Titanic is in better condition than a lot of the frame pics I’ve seen on here!
Old 09-24-2020, 04:19 PM #50
MikeinNH67's Avatar
MikeinNH67's Avatar
Could be, when I cleaned the inside of mine I pulled out like 5 to 10 pounds of sand, I'm sure salt is in there too. There doesn't seem to be much for decent drainage on these.
Mike
03 4runner Limited
Old 09-24-2020, 04:36 PM #51
ThorRides's Avatar
ThorRides ThorRides is offline
Real Name: Todd
ThorRides is on a distinguished road
ThorRides's Avatar
Real Name: Todd
Maybe I'm naïve since I am from and never moved away from the West Coast, but can't people get the DOTs to stop putting corrosive materials on the road? It isn't good for the cars that drive on them or the nearby environment for that matter. It seems like lots of cars have a much shorter life and drivers need both a "winter car" and a "summer car" because of it. I know salt is used a lot, but what about using methanol or some other anti-freeze?
'05 T4R Limited V8 with 4" lift
My Ride
ThorRides is offline   Reply With QuoteReply With Quote
Old 09-24-2020, 08:17 PM #52
Honestly, I believe it all comes down to cost. The salt is relatively cheap compared to other options, and most people view it as a natural element as opposed to other chemicals which leach into waterways and such. Plus, they don’t give a crap about what it does to vehicles.
Old 09-24-2020, 08:20 PM #53
No, that boxed design is terrible, especially since it has dozens of large holes to let sand, water, and obviously salt in, but only a few small places to drain. They should have used a C-channel design so at least you could see if it started rusting and deal with it before it was too late.
Old 09-25-2020, 08:36 AM #54
Ralph Blake Ralph Blake is offline
Ralph Blake is on a distinguished road
I feel Toyota knew their frames would rust, they just felt we put out new models each year and all older buyers are just quickly forgotton.
Ralph Blake is offline   Reply With QuoteReply With Quote
Old 09-27-2020, 02:12 PM #55
flipflopnfly's Avatar
flipflopnfly flipflopnfly is offline
flipflopnfly is on a distinguished road
The frame rails do tend to retain a lot of debris, found that on 4Runners, Tacomas, Tundra. That front radiator support crossmember has poor drainage also. I've found you have to crawl underneath with a spray nozzle and cram it into every opening, get a faceful of water, dirt, gravel but eventually you'll see clean water.
If one has a good frame now do that, then followup with a rust converter. I've used Eastwood
Internal Frame coating before, has good reviews. Eastwood Internal Frame Coating Aerosol Spray (14-oz.) Eastwood has various products for internal and external rust conversion, I'm a fan of Rustoleum rattle can rust converter as mentioned earlier.
Won't help with existing awful flaky rust but helpful to prevent future awful flaky rust.
Donated to SoulDog Rescue - '07 Limited 4.7 4WD | Toytec Boss kit front and rear set to 2.0" in front with standard Superflex 2" lift rear coils | Firestone 9" airbags | 600W Samlex PSW inverter | Slyfox SAIP bypass | Toytec 14" rear brakelines
'08 Limited 4.7 4WD | Toytec BOSS kit front and rear set to 2.75" front standard Superflex 2" lift rear coils | SPC balljoint UCA's | Firestone 9" airbags | Slyfox SAIP bypass | Toytec 14" rear brakelines
flipflopnfly is offline   Reply With QuoteReply With Quote
Old 09-28-2020, 07:34 PM #56
MikeinNH67's Avatar
MikeinNH67's Avatar
So my son recently picked up a pretty clean 06 f150 with a skipping engine problem. Got it because everywhere we looked the frame seemed decent and the price was good. Others we looked at were a disaster with welded frames and bubbling paint. Anyway, while trying to figure out what the former owner bodged on the exhaust we noticed rust holes on the top of the frame in same place the 4runners rust from the AC drain. Ugh, sometimes I want to move. Where's the recall Ford?
The skipping was a bad coil and one that wasn't plugged in well if anyone cares. lol.
Mike
03 4runner Limited
Old 09-29-2020, 08:44 AM #57
Moving seems to be the only way, lol. That’s why I’m glad I’m moving to GA next spring. Have had a house there for a year, but the Covid crap slowed down the move considerably, otherwise I would already be there. I’ve completely cut out and welded all of the bad areas on my frame over the past couple weeks, and was able to clean and coat the inside every well where I cut it open. This week I’m going to spray the NH oil undercoat through the whole inside to hopefully hold it for many years to come, especially once I move to a place where road salt won’t be used!
Old 09-29-2020, 02:52 PM #58
Urbanite Urbanite is offline
Urbanite is on a distinguished road
Originally Posted by y=mx+b View Post
I did the A/C reloaction as well, figure pictures from a few different people can't hurt. I used a 3/8" splice barb and some 3/8" vinyl tubing zip ties to the frame
I went under my truck tying to locate that drainage pipe, but couldn't see it, what side of the truck am I looking at? Thx.
Urbanite is offline   Reply With QuoteReply With Quote
Old 09-29-2020, 02:59 PM #59
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
Passenger side front wheel well. Remove the wheel and should be up in there.
Can kinda see it in the top left here, poking out from just on top of the cat
y=mx+b is offline   Reply With QuoteReply With Quote
Old 09-29-2020, 03:50 PM #60
Thanks for the pic, I now see it. Had you not posted this, I would have been looking for some time to come;)
bad , brace , end , reinforced , side
Can I use rust reform on a small body dent with rust? Nooga_Rock Maintenance/Detailing 3 05-18-2020 02:58 AM
Any rust issues on Gen 5? Beach rust prevention. Fomer_FJ_owner805 5th gen T4Rs 8 09-19-2016 01:08 PM
Rust?!?! DaniFami 3rd gen T4Rs 10 10-18-2012 09:50 AM
Has anyone in the rust belt had luck with a DIY rust inhibitor? MilesRacker 3rd gen T4Rs 5 10-17-2008 02:46 PM
Rust and rust prevention Thai Maintenance/Detailing 0 02-21-2007 10:58 PM
