Originally Posted by rdruss
I use a coat hanger with a little hook bent in the end, it will break those pieces up as you pull it out of the frame holes. Like you said though, it's a tedious job, I've spent hours just raking a coat hanger in and out of all the holes and the reward is gobbs of rust!
I've also seen some people use a drill-powered auger with a chain attached at the end to break things up but I figured I'd ask here before opening a can of worms and spending more than required.
As the person above mentioned, Eastwood does seem like the way to go- when I have the loose rust cleared out, I will be spraying it down with Internal Frame Coating and then a wider application of Fluid Film.
