Old 09-13-2020, 11:38 AM #1
TheCremePuff's Avatar
TheCremePuff TheCremePuff is offline
TheCremePuff is on a distinguished road
ARB Air Compressor Question
Does anyone have experience with these compressors? I recently installed one and have blown through two air hoses because they are getting too hot melting the hose and then I pops.
TheCremePuff is offline   Reply With QuoteReply With Quote
Old 09-13-2020, 01:50 PM #2
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
ARB dual or single compressors? Are the hoses rated for 150psi? I think most people use stainless braided hoses from the outlet of the compressor to the tank, are you using rubber? Is the compressor in the engine bay?
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 09-13-2020, 03:21 PM #3
It’s the single compressor. It is in the engine bay mounted right where the factory intake would run to the inside of the fender liner. The hose was rated for I believe 300 psi but again it just got so hot right where it runs into the compressor t melted the line. I guess I’ll try a steel braided line. That then runs to the rubber line. Any suggestions on length for the steel line?
Old 09-13-2020, 05:51 PM #4
taxzz's Avatar
taxzz taxzz is offline
taxzz will become famous soon enough taxzz will become famous soon enough
taxzz's Avatar
My ARB single is behind the air filter box. It gets hot but nothing is happening with the house. Mine is a rubber ARB hose that comes with their quick connect kit. I only have steel braided line for the inflator/guage final foot.
I don't let the hose you h the compressor I'd that's what you're having happen.
2007 Limited V8 | Apache AX2 and Dobinson 3" lift
2004 Limited V8 | Dobinson IMS Long Travel 3″ lift w/ SPC UCAs | Yoko 35x12.5/17 | Rear Locker | Front LSD !!!!FOR SALE!!!!
2004 SR5 V6 | Sold
taxzz is offline   Reply With QuoteReply With Quote
Old 09-21-2020, 10:44 AM #5
randy88fj62's Avatar
randy88fj62 randy88fj62 is offline
randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about
Show us a picture of your setup.
Electric air compressors should not be mounted in the engine bay. York compressors were very popular over the years until VIAIR and ARB came out with good setups.
My older ARB compressor has a small manifold on it where my arb air locker lines go then into push on plastic fittings.
My VIAIR compressor has a stainless braided line for the first 12" of the outlet then into standard hoses.
1. Mount the compressor somewhere away from heat such as under the passenger seat or in the back quarter panel. It will also last a lot longer out of the elements.
2. Oversize the wiring to increase the efficiency and run it with the truck on.
3. Stainless braided or higher quality hoses for the output line.
randy88fj62 is offline   Reply With QuoteReply With Quote
air , hose , hoses , hot , melting
Ac Compressor question Greenmachine86 3rd gen T4Rs 14 11-28-2019 12:59 PM
Air compressor question cdiset General Discussions 6 08-10-2017 01:30 PM
ARB Compressor question Okki 5th gen T4Rs 71 03-07-2017 09:30 PM
AC Compressor Oil Question rjaudi 3rd gen T4Rs 8 06-05-2010 11:44 PM
Air Compressor Question greasefingers Engines / Suspension / Wheels / Tires / Audio / Accessories 23 05-09-2005 07:26 AM
