Old 09-15-2020, 10:52 AM #1
404NotFound's Avatar
404NotFound 404NotFound is offline
Real Name: Chase
404NotFound is on a distinguished road
Real Name: Chase
Squeaky suspension
Hey guys and gals, quick question for my T4R family:
Can anyone give me an idea of some good places to apply grease for my suspension system? Long story short, when I did the XREAS to FJ conversion, she's been a squeaky little whore ever since. Annoying the heck out of me 20,000 miles later. I know there aren't really any zero fittings under there, so does anyone have any ideas where to apply some grease and what kind to use? I'm just tired of my truck sounding like two hobos going at it on an old mattress when I drive down a road with a few bumps, which is everywhere because I'm in Oklahoma. As the coach of the Letterkenny Irish would say: "It's f***ing embarrassing."
Thanks in advance y'all.
Galactic Grey Mica 2005 4Runner SportEdition 4WD 4.0L - C4 Fab lo-pro bumper - Smittybilt winch - Rigid ditch lights - 5100/OME lift - 2017 TRD Off Road Wheels w/ Falken Wildpeak AT3 - Pioneer 8500NEX - 06+ LED Taillights - aFe intake - Weathertech mats
404NotFound is offline   Reply With QuoteReply With Quote
Old 09-15-2020, 11:22 AM #2
Berty_K's Avatar
Berty_K Berty_K is offline
Berty_K has a spectacular aura about Berty_K has a spectacular aura about Berty_K has a spectacular aura about
Berty_K's Avatar
You shouldn't need to grease anything on the suspension. Did you torque everything down correctly and install your bushings/washers correctly?
Try to track down the squeak by having someone rock the car for you. Too many places for a "squeak" to come from.
I had a squeak coming from to top of my front shock tower. The stem was interfering with the top hat due to a missing washer.
'08 Silver SR5 V6 4x4: OEM+
Berty_K is offline   Reply With QuoteReply With Quote
Old 09-15-2020, 12:44 PM #3
Real Name: Chase
Real Name: Chase
That might be what I need to look for then. I know when we installed everything it felt like I was working with a bunch of apes.
Sent from my SM-N950U using Tapatalk
Old 09-15-2020, 05:48 PM #4
MikeinNH67's Avatar
MikeinNH67's Avatar
When everything was tightened down on the suspension was it done with the weight of the vehicle on it? Control arms and such should be tightened at the normal position the car sits at. Mainly spots that have rubber bushings that twist, not needed on ball joints.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 09-15-2020, 11:02 PM #5
Real Name: Chase
Real Name: Chase
Nope it wasn't. I didn't replace the UCAs, should I have?
Old 09-16-2020, 10:23 AM #6
MikeinNH67's Avatar
MikeinNH67's Avatar
No I just didn't know how deep it went. If they had to remove/loosen any of those pieces to do the lift then I would loosen those bolts to let all the rubber bushings get into the loaded resting place they should be before re-tightening. If you look at videos from someone like South Main Auto you will see that he will jack up each control arm before tightening those bolts, otherwise when you put weight on the suspension those bushings will twist and make noise. I'm not saying that is definitely your noise but it could be.
Mike
03 4runner Limited
Old 09-18-2020, 01:46 PM #7
Forum148 Forum148 is offline
Forum148 is on a distinguished road
Can confirm this. I've had squeaking this summer and ended up being my top hat nut was loose. Tightened it down and it stopped. But now I'm befuddled because the bushing isn't being compressed.
06 V8 SR5 --Kings--JBAs--RCI armor--Lil B's--33s--Wheel and Party--
Forum148 is offline   Reply With QuoteReply With Quote
Old 09-18-2020, 03:37 PM #8
Berty_K's Avatar
Berty_K's Avatar
If I were to guess, you're probably missing the highlighted red washer.
The washers supposed to sit on this ridge:
Without the washer, the thicker portion of the shaft ends up jamming into the bushing, preventing the top bushing from compressing.
Old 09-18-2020, 03:48 PM #9
Unhappy
Hmmm I’ll have to check I do believe when I installed everything the bushing was compressed.
Old 09-18-2020, 04:29 PM #10
Berty_K's Avatar
Berty_K's Avatar
May very well have been compressed when you installed, as was the case for me. The shaft gradually ends up sliding further into the bushing.
Old 09-19-2020, 02:42 PM #11
Anthonie's Avatar
Anthonie Anthonie is offline
Anthonie is on a distinguished road
Anthonie's Avatar
I'm glad that you were able to find the solution because I was going to suggested that applying grease to the suspension was not needed.
Anthonie is offline   Reply With QuoteReply With Quote
apply , grease , sounding , squeaky , suspension
Help! Insanely squeaky front suspension! OME BP-51 AZDesertRat Problems & Warranty Issues 7 11-07-2021 01:03 PM
Squeaky suspension FIXED falkon240 4th Gen T4Rs 1 06-04-2018 05:56 PM
squeaky suspension/coil? 08 Hilux Surf 4th Gen T4Rs 2 07-19-2013 02:25 PM
Squeaky UCA's deedst4r 4th Gen T4Rs 12 04-05-2013 11:09 AM
03 4runner squeaky front suspension sshick 4th Gen T4Rs 1 10-04-2008 12:36 AM
