Old 09-20-2020, 07:58 PM #16
Az4runnin's Avatar
Az4runnin Az4runnin is offline
Az4runnin will become famous soon enough Az4runnin will become famous soon enough
Az4runnin's Avatar
Thumbs up
It would be nice to get some Good Sliders and Just be able to pick them up local.
2003 V8 Limited 4x4 Black. JBA UCA's, TRD Pro Wheels. OEM LED Tails, 2012 FJ Springs F/R 5100's F/R 1.75 Cooper AT3 4S 265-70-17. Bye X Reas, Wet Okole Seat Covers Weathertech liners.
Az4runnin is offline   Reply With QuoteReply With Quote
Old 09-20-2020, 09:12 PM #17
JONBOY345 JONBOY345 is offline
JONBOY345 has a spectacular aura about JONBOY345 has a spectacular aura about JONBOY345 has a spectacular aura about
Originally Posted by Bluesky 07 View Post
Looks promising. Where is his shop? The shipping is always brutal on stuff like this.
Checkout Cory Turner/torxfabrication on instagram, he's in the Atlanta Metro area and doing fabrication on toyotas.
I'm planning on going to him for my sliders.
Login • Instagram
TORX_Fabrication
'09 V8 Limited | Dobinsons Lift | Front: 3" - C59-302 + GS59-220 | Rear: 2.5" - C59-675V + GS59-701 | Tires | Ridge Grappler 275/65/18XL | Wheels | Method Standard Machined Finish 18x9 -12 offset | SPC UCAs | DT Long Tubes | GSport 2.5" Cats | DT Y-Pipe | Magnaflow Cat Back | 2.5" Vibrant Ultra Quiet Resonator
JONBOY345 is offline   Reply With QuoteReply With Quote
Old 09-20-2020, 09:17 PM #18
04rnr's Avatar
04rnr 04rnr is offline
04rnr is a jewel in the rough 04rnr is a jewel in the rough 04rnr is a jewel in the rough
04rnr's Avatar
Originally Posted by BackOff View Post
I always wonder about this style of slider with the frame rails being covered with that inner mount plate.
Seems like a good place for the frame to start to rust.
Trapping moisture and road salts between frame and slider frame mount.
Probably just overthinking it.
true, BUT, when you're done mounting them, just throw a quick bead of caulking. You also have to remember, the fram has LOTS of holes anyway, water will get in the frame anyways
2007 Sport.
"Colorado is FULL, try N.M."
"Everyone is an expert"
04rnr is offline   Reply With QuoteReply With Quote
Old 09-20-2020, 10:39 PM #19
duffdog duffdog is offline
duffdog is a jewel in the rough duffdog is a jewel in the rough duffdog is a jewel in the rough
Originally Posted by Epic Ed View Post
Interesting perspective but a bit overdramatic and insulting, with the assumption that someone would be OK with putting sliders on a vehicle just for cosmetics.
This is the same slider design they've been successfully using on 5th gen 4Runners for nearly a year on 4Runners that get wheeled pretty hard. The 4th gen mounting points for a bolt-on solution present some unique challenges. There are several holes through the frame but few that are threaded. As you can see with the image in AutoCad, the mounting plate runs the full length of the slider and will have FIVE frame-thru bolts. No idea how you got the impression there aren't any, but I should clarify that the pics I posted are a tac-welded mock-up and not the finished product. The three support arms will each have a brace to enhance the strength of the mounting arms.
New option for 4th gen sliders - potentially
Engineering doesn't care how you feel.
All noted problems have been solved by All-Pro off road 10 years ago. Your design appears to be a poorly engineered copy. Had you done some type of FEA, you would have discovered that the plate that runs the full length of the sliders will simply warp and pull out the threaded nut-serts on the frame. Additionally, the mounting plates should have bolts that go all the way through the frame, come out the other side and have square backup plates. Thirdly, the front part which would encounter most of the rocks should have 2 bars spaced less than 12" apart to handle the entire weight of the truck without causing metal fatigue along the mounting base. Fourth, using a full length mounting base with only 5 points of contact with m10 bolts will not hold up to a single hit on a rock. And since we are at it, whose idea was it to use 3/8 plate? That should be 1/2 based on the weight of the truck... or did you not actually do any math to determine what thickness of metal might bend based on the torsional load on an extended beam?
Either way, the design sucks, is weak and therefore dangerous and may cause harm to someone. I only post negative things when it is certain that peoples "inventions" may cause injury or death. Outside of that I could care less.
And now back to your regularly scheduled t4r argument about roof rack mounting and aftermarket headlights...
2005 Blue SR5 v8
3" suspension lift, 1" body lift, 315's, rear Elocker, on-board air system, slider air tanks, full skid plates, front Demello bumper, rear HMF plate/tube bumper, rear 9000lb hidden winch, front 10000lb winch, dual electric fans (in cab adjustable temp), rock lights, 25W LED projector lights.
duffdog is offline   Reply With QuoteReply With Quote
Old 09-21-2020, 03:46 AM #20
Epic Ed's Avatar
Epic Ed Epic Ed is offline
Epic Ed will become famous soon enough
Epic Ed's Avatar
I don't know anything about engineering. It's not my design. However, I do know *******s. You're not helpful. You're just a smug jackass.
2007 Toyota 4Runner | Sport Edition | 4WD | Fox 2.5 front | Fox 2.0/OME rear springs | Camburg UCAs | 285/70/17 Bridgestone Dueler Revo 3s on TRD Pro wheels | Westcott Designs Sliders | BD S8 30" light bar | Rigid 10" with C4 bracket in hood scoop | BD Squadron Sport ditch lights
Epic Ed is offline   Reply With QuoteReply With Quote
Old 09-21-2020, 03:20 PM #21
BackOff's Avatar
BackOff BackOff is offline
Real Name: Derek
BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough
BackOff's Avatar
Real Name: Derek
I was thinking rust between frame and the slider mount plate.
RCI has a very similar setup and seems like i have seen at least one other like this too, with that full frame mounting plate.
Just with all the poor old rusted out 4runners i have seen on this site, adding a potential rust zone...
y=mx+b thats not aimed at you.
Might be better to just spray some kind of fluidfilm in there than to try and seal it with caulking, that might just trap moisture.
Maybe clean and paint the frame too? Before install.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
BackOff is offline   Reply With QuoteReply With Quote
Old 09-21-2020, 04:02 PM #22
Agreed.
You could have fooled me about that design not being yours. You have a prototype on your truck, the original CAD file and were explaining the different design features and the reasons why it could not be done in any normal, non-janky way.
How about you remove it, fix the design so that it does not bear the entire weight of the truck on 5 m10 nutserts and then post pictures of the newly updated model.
2005 Blue SR5 v8
Old 09-21-2020, 07:48 PM #23
Berty_K's Avatar
Berty_K Berty_K is offline
Berty_K has a spectacular aura about Berty_K has a spectacular aura about Berty_K has a spectacular aura about
Berty_K's Avatar
Agreed.
Little life tip for you-
Nobody cares how smart you are (or at least how smart you think you are). If you're a jackass, people probably wont listen to you. So, you might as well keep your thoughts to yourself (for my sake and probably most people here).
I'm not planning on responding to you because you don't seem like someone I can have a constructive conversation with, so type away all you want.
'08 Silver SR5 V6 4x4: OEM+
Berty_K is offline   Reply With QuoteReply With Quote
Old 09-21-2020, 09:12 PM #24
Epic Ed's Avatar
Epic Ed's Avatar
Agreed.
You could have fooled me about that design not being yours. You have a ...blah, blah, blah...I have anger issues and my reading comprehension sucks...
Yeah, I gave the full back story in my original post. Feel free to go back and read it. Maybe you'd understand it if I wrote it out in crayon.
Condescending and abrasive is a helluva way to go through life. I don't know how many kids you have, but I'll bet you have at least one who no longer speaks to you. Weren't therapy sessions a mandatory condition for parole? Hope you get the help you need.
Old 09-24-2020, 06:12 PM #25
Epic Ed's Avatar
Epic Ed's Avatar
Got them mounted up today and I'm very please with how they turned out. They tuck up really tight into the underside of the truck providing maximum clearance. I ran some of the objections by the fabricator who designed these and he chuckled. We might arrange for a drop test. I'd be happy to let them use my ride to do a video demo like I've seen some others do.
I can't answer all the technical questions, but I do know they're DOM tubing .120 wall. Price point is $748 naked. $180 for powder coating. Shipping by zip code.
Login • Instagram
Old 09-24-2020, 09:29 PM #26
Az4runnin's Avatar
Az4runnin's Avatar
Thumbs up
Those look very nice. Your Rig looks great man. They are like 10 minutes from my House. Finally a place Local and Close to me.
Old 09-25-2020, 06:04 PM #27
Login • Instagram
And if you are looking for the real deal which isn't a fake copy made from the correct thickness of metal which weighs less, is 5x stronger and doesn't cost an arm and a leg and actually fits on the truck without bending and rusting then click here:
2010-2020 Toyota 4Runner Rock Sliders
Available for the 4th gen as well by request. And no I don't work for All-Pro.
2005 Blue SR5 v8
Old 09-26-2020, 02:57 AM #28
Epic Ed's Avatar
Epic Ed's Avatar
Old 09-26-2020, 09:11 AM #29
FjHugo FjHugo is offline
FjHugo is on a distinguished road
While the approach may be a bit abrasive, I do believe there are some good points here. It is important to protect a consumer from poorly designed products, especially if there is possibility of damage to the vehicle with normal and expected use. I would hope that the gentlemen designing these sliders does have a degree in engineering, and if not he has years and years of heavy duty OFF ROAD experience watching designs fails under stress and many, many revisions before offering a product to the public.
At this point, they look OK, but nothing unique and that isn’t already offered by more reputable manufacturers with much more experience in sliders. Also, what’s with the bolt and piece of metal on the bottom of the frame rail? Isn’t that just asking to be sheared off?
FjHugo is offline   Reply With QuoteReply With Quote
Old 09-27-2020, 01:32 AM #30
I believe the two bottom bolts on the lower part of the frame are a relatively simple attempt to relieve the torsional stress of the arm bending upwards and warping the full length mounting plate away from the frame at the 3 legs. Note that the factory m10 fastener points are not located in the shear zone of the surrounding metal near the 3 welded on legs. Additionally, the gussets have minimal effect on vertical rigidity as they are not attached to any significant structure besides the undersized plate which only has 5 total fasteners to begin with. I find that attempting to "slide" over a rock with downward facing plates and 2 bolts sticking out is counterintuitive. The bolts may catch on a rock and spin the truck along its vertical axis and dump it on its roof, injuring or killing the driver and other occupants.
2005 Blue SR5 v8
business , gen , product , sliders , work
Potentially in the hunt for either 130 or 185 HiLuxer New Members 0 08-11-2014 07:18 PM
Potentially new owner 4th gen soon ! scoobync New Members 3 02-15-2014 07:53 AM
Potentially My New Rig...Anyone With Input?? Johannes Classic T4Rs 1 10-15-2008 05:38 PM
potentially dumb question... 2k1SilverSport 3rd gen T4Rs 4 02-22-2006 09:06 PM
