Old 09-18-2020, 09:08 AM #1
Zero0575's Avatar
Zero0575 Zero0575 is offline
Real Name: Casey
Zero0575 will become famous soon enough Zero0575 will become famous soon enough
Zero0575's Avatar
Real Name: Casey
Shorted ABS Wire?
Hey All,
A couple of weeks ago, I changed out my front calipers due to one of the pistons being seized and all is working well now. Last night, the VSC Off, skid control, ABS and VSC Trac lights all came on as well as the parking brake light. I'm thinking I stretched one of the ABS Sensor wires and caused a small short, since one of the calipers slipped out of my hand while I was trying to hook it to the frame after removing it from the back of the hub.
There is also some feedback from the radio, which again, leads me to believe that I stretched one of the wires and it is arcing causing that feedback.
I have a code reader, but it doesn't read ABS codes. Also, the codes cleared as soon as I turned the car off and back on. I'm thinking about just ordering the wiring harness for the side that I believe is the issue, and reusing the actual sensor since I believe it is still fine.
Am I headed in the right direction? Anyone have anything similar happen before?
Edit: I did already do a zero point calibration and the check engine light is not on, only the lights I mentioned, just FYI to everyone.
2007 Limited V8 | 275/70/18 Falken Wildpeak AT3W | Spidertrax | 4xInnovations Weld On Sliders | Victory 4x4 Blitz Front Bumper | RCI Skids | TNF Rear Bumper | Smittybuilt Winch | KOYORAD Aluminum Radiator |OME 886 Front/Toytec Superflex HD Rear and OME Shocks/Struts | JBA High Caster UCA | Rebuilt LCA with Superpro bushings + Moog BJ | HCF Delete | Doug Thorley Shorty Headers | Magnaflow HFC | Gibson Catback | Rear Diff Breather Extension | 20" Spot/Flood | 9" Spots | DD SS3 Yellow Fogs | Amber Grill Lights | Fog Lights Anytime Mod
Zero0575 is offline   Reply With QuoteReply With Quote
Old 09-18-2020, 11:54 AM #2
BackOff's Avatar
BackOff BackOff is offline
Real Name: Derek
BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough
BackOff's Avatar
Real Name: Derek
Easy to test.
Multi-meter.
Set on continuity.
Disconect the abs wire plug in engine bay and at hub.
Take a piece of wire and extend one side of the multi-meter wire. (Connect a length to one side of tbe multi-meter) maybe test it to make sure its not a broken length your using.
Dont even have to pull the wire harness out to test.
This make any sense?
I have used this method in the past.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
BackOff is offline   Reply With QuoteReply With Quote
Old 09-18-2020, 12:08 PM #3
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
I had similar experience couple weeks ago but snapped one of my ABS wires in half fooling around with front end. All the dash lights you mentioned came on next drive. Replaced harness ($110) and all ok. Worth doing the continuity test I guess to confirm.
Old 09-18-2020, 02:54 PM #4
Zero0575's Avatar
Real Name: Casey
Zero0575's Avatar
Real Name: Casey
Originally Posted by BackOff View Post
Easy to test.
Multi-meter.
Set on continuity.
Makes sense. I don't have a multimeter - I'll grab one from harbor freight this weekend and give this a try.
$110? I found it for $60 new at a few places online, including TRDshop:
2003-2009 Toyota ABS Sensor Wire 89516-60070 | TRDShop.com
That's where I'll order it from once I confirm my issue.
Thanks guys!
Old 09-18-2020, 11:30 PM #5
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Thanks guys!
A few $ less at other places....
ABS Sensor Wire - Toyota (89516-60070) | Toyota Parts
2003-2009 Toyota ABS Sensor Wire 89516-60070 | DiscMonster
2004 Limited V8
abs , codes , sensor , vsc , wires
2018 Wont Start after a wire shorted Waepek 5th gen T4Rs 12 12-19-2019 01:45 PM
Shorted battery...now no start... airbur 4th Gen T4Rs 31 01-26-2018 08:34 AM
Shorted something... Brilliant 3rd gen T4Rs 5 11-19-2011 02:54 PM
Shorted a wire, now multiple items not working MLSD 4th Gen T4Rs 10 02-22-2009 01:03 PM
shorted wire after LED install hotskillet98 4th Gen T4Rs 0 10-13-2008 10:57 PM
