Old 09-18-2020, 10:01 AM #1
Nuke's Avatar
Nuke Nuke is offline
Nuke is on a distinguished road
Nuke's Avatar
Spark Plug replacement
Sorry, but SEARCH isn't working on my tablet and my laptop crapped the bed...
At what mileage are you guys replacing plugs? I replaced my factory plugs with another set of Denso on my 2008 4.0L, non-modded except CAI, at about 90,000 despite that they still looked good. I have 180,000 and other than my fuel mileage down a tad ( and I suspect not plug related) she runs like a top. I have a fresh set of Denso's but I'm wondering if I should just hold off. At 65 yo, you have to consider reducing the necessary workload...
Rick
'90 T4R - sold at 205,000 miles & '00 T4R - sold at 152,000 miles
'08 Sport 4WD V6, Salsa Red, TRD CAI, Sylvania Silverstar Ultra Low/Hi Beams, Hella Optilux XY Fogs
'19 TRD ORP, Dark Gray Metallic, KDSS, Sunroof, Predator Tube Steps, Sprint Booster V3, S&B Intake
Nuke is offline   Reply With QuoteReply With Quote
Old 09-18-2020, 10:09 AM #2
Zero0575's Avatar
Zero0575 Zero0575 is offline
Real Name: Casey
Zero0575 will become famous soon enough
Zero0575's Avatar
Real Name: Casey
If the V6 is the same as the V8 and uses the iridium plugs, then the interval is 120k miles.
Edit: just did a search and found that the V6 uses copper plugs, so don't listen to me! The copper plugs are recommended every 30k miles, but I think that's a bit ridiculous. But since you're at 3 times the recommended mileage on copper plugs, I would change them.
2007 Limited V8 | 255/70/18 Firestone Destination AT2 | 4xInnovations Weld On Sliders | Victory 4x4 Blitz Bumper | Smittybuilt Winch | OME 885 Front/Toytec Superflex Rear and OME Shocks/Struts | JBA High Caster UCA | Mevotech LCA with OEM Camber Bolts | HCF Delete | Doug Thorley Shorty Headers | Magnaflow HFC | Rear Diff Breather Extension | 20" Spot/Flood | 9" Spots | DD SS3 Yellow Fogs | Amber Grill Lights | Fog Lights Anytime Mod
2009 Subaru Impreza WRX Wagon | Mevotech Aluminum LCA | 24mm Whiteline Front Sway Bar | 22mm Whiteline Rear Sway Bar | Kartboy Endlinks Front and Rear | Perrin Rear Subframe Lockdown Bushings | Stage 1 Tuned | Muffler Delete
Zero0575 is offline   Reply With QuoteReply With Quote
Old 09-18-2020, 10:13 AM #3
firebirdguy is a jewel in the rough firebirdguy is a jewel in the rough firebirdguy is a jewel in the rough firebirdguy is a jewel in the rough
v6 does not use iridium.
Old 09-18-2020, 10:14 AM #4
CookieRoe's Avatar
CookieRoe CookieRoe is offline
Real Name: Ed
CookieRoe has a spectacular aura about CookieRoe has a spectacular aura about CookieRoe has a spectacular aura about
CookieRoe's Avatar
Real Name: Ed
You have the V6, so every 30,000 with "normal" plugs. I get them from Toyota. I like peace of mind. Anyway, some will recommend iridium plugs which you shouldn't do. Those last for 100,000 miles in theory, but our motors are not designed for that. I've seen/heard/read about these (iridium) plugs fouling up. Manufacturer recommends normal copper plugs. I run Denso plugs and/or NGKs (on my other cars). I understand about "work load", luckily the plugs are easy to do on our V6s.
Go ahead and install them, looks like you are overdue.
Good luck
CookieRoe is offline   Reply With QuoteReply With Quote
Old 09-18-2020, 10:32 AM #5
Berty_K's Avatar
Berty_K Berty_K is offline
Berty_K will become famous soon enough Berty_K will become famous soon enough
Berty_K's Avatar
You should change them.
K20HR-U11 (Toyota part #90919-01235)
DIY if you need it here: How To: Spark Plug Change (1 GR-FE) | Tacoma World
Berty_K is offline   Reply With QuoteReply With Quote
Old 09-18-2020, 11:15 PM #6
Nuke's Avatar
Nuke's Avatar
I replaced them at 90,000 miles with K20HR-U11 despite that they looked like they had barely 20k on them. I've put another 90,000 miles on the current set and the engine still runs great. I already have another set on-hand so I'll get around to it. I was simply curious what others are seeing.
FYI, the Denso website list these plug's electrodes as nickel.
Rick
mileage , plug , plugs , runs , set
Spark Plug Replacement wheelds 3rd gen T4Rs 15 05-16-2013 05:21 PM
Spark Plug Replacement Question ts9790147 4th Gen T4Rs 2 09-29-2010 06:02 PM
Spark plug replacement LL21 Maintenance/Detailing 4 01-23-2009 03:04 PM
Spark Plug replacement help Red3.slow Classic T4Rs 6 02-22-2006 01:31 AM
More on Spark Plug replacement ? alotawatts Maintenance/Detailing 2 01-15-2006 12:37 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
