Old 09-18-2020, 05:33 PM #1
Yuri Yuri is offline
Yuri is on a distinguished road
Help to identify braking line
Hi guys,
I need a little help to identify braking lines. Pics are attached.
It seems "hard" line , and not sure how that happened but it is leaking.
Slowly , but surely . I add braking fluid once per week and it keeps level in Master Brake Cylinder (well, nowadays - once per month, as i am driving very little, but "nowadays is exception).
Also, location seems to me not DIY friendly, so anyone would have any idea how laborious it would be to replace if i would do it myself?
Thanks for any help & ideas.
Help to identify braking line-20200906_174045-jpg  Help to identify braking line-20200906_191326-jpg  Help to identify braking line-20200906_191435-jpg
Yuri is offline   Reply With QuoteReply With Quote
Old 09-24-2020, 05:54 PM #2
MikeinNH67's Avatar
MikeinNH67's Avatar
The bend in the line looks kinda odd so I wonder if someone has already worked on it. Maybe put a new flare on that end but didn't do a good job. It's not too hard to replace because you can just about sit up under there if you remove the spare tire. I've found the easiest way to remove the threaded end is to cut the line close to it and tap a socket onto it. Have your new line prepped and ready to go so you don't lose too much fluid.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 09-28-2020, 10:51 AM #3
randy88fj62's Avatar
randy88fj62 randy88fj62 is offline
randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about
That's an M10x1.0mm flared fitting that goes into a junction.
Given your question I would recommend getting a professional to fix. Won't cost too much and your life is at stake if that fails.
2008 4Runner Sport Edition 4.7 V8 4WD
1988 FJ62 Landcruiser
President LA County Trailcrew 4x4's
https://www.facebook.com/groups/Trailcrew4x4
randy88fj62 is offline   Reply With QuoteReply With Quote
Old 09-28-2020, 11:11 AM #4
Bikeric's Avatar
Bikeric Bikeric is offline
Real Name: Eric
Bikeric will become famous soon enough Bikeric will become famous soon enough
Bikeric's Avatar
Real Name: Eric
If you replace that yourself you will also need to bleed the brakes when you're done. I second the motion that you should probably take it to a brake specialist for repair.
1984 SR5, 1989 DLX, 2011 SR5 4wd
Bikeric is offline   Reply With QuoteReply With Quote
braking , driving , identify , line , nowadays
Rear Center Line installation and other SS brake line info tv4184 4th Gen T4Rs 7 07-10-2023 04:33 AM
Sudden braking problem (when not braking) t4rjc 5th gen T4Rs 18 09-29-2016 09:53 AM
Can You Identify this Line? 3VZE Leaking Coolant. TX_QtPi Classic T4Rs 3 07-23-2014 12:38 AM
Identify this vacuum line! davemw 3rd gen T4Rs 4 04-08-2013 07:26 PM
She pulls to the left when braking harder, but not when normal braking... Goyo 3rd gen T4Rs 6 11-30-2012 08:21 PM
